Does this constitute Nonconformity? Water Testing
JodiB
We perform metals analysis of water samples using ICP. The water comes from oilfield production and isn't the cleanest of water even after filtering. We have a QC run after every 10 samples, and sometimes the QC will fail. When that happens we run the QC again, and if it fails again we do a little cleaning / maintenance on the instrument and run the QC again and that passes. Then we re-run the 10 samples that preceded the failed QC. With me so far?
The report is not issued to the customer, because we're still in the middle of our work. There is no impact on the results, because we re-run the samples preceding the failed QC. The QC failure is somewhat of an "expected event" that is typical given the nature of the samples we run. It simply alerts us that we need to interact with the instrument and re-run the samples.
Is the QC failure a nonconformity?
If so, given the minor nature of this common event that requires no root cause analysis, would a simple logging of each event be sufficient, without a full blown Corrective Action process that involves a CAR, investigation, root cause analysis, etc?
Opinions please!
Opinions please!
I don't know anything about the instrumentation involved, but you say:
  • The "NC" is a common occurrence and
  • It's cured by cleaning the instrument and re-doing the tests.
It seems that there should be some way of anticipating the need for cleaning the instrument. I don't know what's involved with the cleaning, but is it possible just to check the instrument before doing the testing?
JodiB
Jim,
Thanks for taking the plunge..!
Before running the big tray of samples, we do perform certain maintenance steps so that we're starting with a clean slate. However, during the run (over a hundred samples fed through an autosampler) it could become necessary to do it again, but this isn't something we can automatically anticipate. It just depends on the particular samples that are going through on that day.
The QC failure as an alert mechanism that tells us that somewhere in that last batch of samples , things went a little wonky. So we do what's necesssary to get a clean QC and then re-run the last batch. But perhaps that what all QC failures do...
Randy
NC? Naaaa, it's part of the QC process to determine final conformity to whatever the final result is expected/required to be
Sooooo, how's Houston?
K
kaliko81
If I understand correctly, your acceptance systeme is like a go-nogo so the value you get is not statisticaly important, it passes or it fails, you can get a false "fail" but you could never get a false "pass" right? If it is so, I belive your measurment system is acceptable so no NC but not efficient. My 2 cents would be that you determine a cleaning procedure that you could do before taking any measurement or, if it's to long, to expensive or whatever, you determine a preventive maintenance so you need to know when to clen your instrument before getting a false fail.
E Does posting your IFU on your website constitute elabelling? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
M Distribution of OBL Product - Does this constitute manufacturing? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 14
0 To which part of 13485 does this refer? ISO 13485:2016 - Medical Device Quality Management Systems 3
lanley liao Does the customer`s trademark belong to customer-supplied property? Oil and Gas Industry Standards and Regulations 2
H How does a gas turbine work on diesel fuel? Oil and Gas Industry Standards and Regulations 12
G What does performance specification include? US Food and Drug Administration (FDA) 1
W Where does a coatings and paint company fall in IATF? IATF 16949 - Automotive Quality Systems Standard 5
C Does an accessory need an IFU if it use is discussed in the Parent device IFU? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
S How long does it take to register a product with MHRA? UK Medical Device Regulations 3
M Quality Manual - Where does Revision History Section go? Document Control Systems, Procedures, Forms and Templates 8
A Brexit When does the UK responsible person need to be in place? UK Medical Device Regulations 10
N Does anyone have experience of GB/T 34986-2017? China Medical Device Regulations 1
Z Does anyone have experience with EN ISO 17664 ? IEC 62366 - Medical Device Usability Engineering 9
F Does anyone have an ESD quality/cooler talk to share? Training - Internal, External, Online and Distance Learning 4
A What does this line from MDCG 2020-3 (MDR art. 120 substantial change) mean to you? EU Medical Device Regulations 4
T What does AS9100 mean when it says you must establish a process to do X? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 24
L Does a backdate form format can be changed if wrong revision is used? Document Control Systems, Procedures, Forms and Templates 8
B General Motors and Honda Alliance - What does this mean to suppliers? IATF 16949 - Automotive Quality Systems Standard 3
C ISO 13485 :2016 - CAPA - Does every CAPA need to be checked by regulations? ISO 13485:2016 - Medical Device Quality Management Systems 9
A Does ISO 9001:2015 cover all the requirements of ISO 10012:2003? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
N FDA UDI - Label vs. Labeling - Does the insert need to include UDI? Other US Medical Device Regulations 1
A Does anyone have a checklist of API Spec 650 13th Edition? Oil and Gas Industry Standards and Regulations 0
D Does Manufacture can submit CE mark application under MDD with NB for his New product after May 2020? EU Medical Device Regulations 3
A What does this sentence "this symbol shall be used in the orientation shown" mean in ISO 780:2015? Other Medical Device Related Standards 4
L Turkish Requirements - Does the Software need to be translated? CE Marking (Conformité Européene) / CB Scheme 2
J Does Pakistan Medical Device Import License allows parallel import? Other Medical Device Regulations World-Wide 0
BeaBea Interesting Discussion Where Does Marketing/ Advertisement of Products fit in to ISO 9001? Process Maps, Process Mapping and Turtle Diagrams 39
P Does anyone have a API Q1 Documentation Package? Quality Management System (QMS) Manuals 1
N What is our product classification? (Does Unclassified classification still exists) Other US Medical Device Regulations 14
C Does a CE mark infer meeting all applicable standards? CE Marking (Conformité Européene) / CB Scheme 4
N Small Company - Internal audit process - Who does the audit? Internal Auditing 16
J Does anyone have an excel IATF 16949 Internal Audit checklist I could use? IATF 16949 - Automotive Quality Systems Standard 7
A Does AS9100 require traceability to operators performing the work? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
I Does anybody use Detection in medical device Design FMEA? ISO 14971 - Medical Device Risk Management 18
A EN ISO 14971:2019 does not include the Annex Zs ISO 14971 - Medical Device Risk Management 4
Watchcat Does "Similar Device" = "Predicate"? EU Medical Device Regulations 7
Y Does Solidworks (2D/3D drafting modules) need validation? Other Medical Device and Orthopedic Related Topics 5
M Definition Open Audit - What does an Open Audit mean? Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 3
I Does training have to be written? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
