aufa_fadhli
Hi All,
Currently, measurement of torque of cap is conducted manually (twisted by hand). The inspector will twist the part (cap) that attached on torque gauge until loose then record the result. Based on this, my company just design new semi auto torque machine to reduce variance due to different operator. The inspector only put on the machine jig and let the machine twist the cap until loose. Speed of motor will be in fix setting.
Based on ISO 13485:2016 Clause 7.6 Control of monitoring and measuring equipment which states " As necessary to ensure valid results, measuring equipment shall:
a) be calibrated or verified or both......
So, does this new system need validation?, or is calibration enough?. Since ISO only states "be calibrated or verified or both"
If do validation, is Gauge R&R study suitable for this case?
Thanks in Advance
Aufa
Thanks in Advance
Aufa
