Does TS 16949 Clause 7.5.3 require our product to have traceability?
V
vanputten
#21
I can monitor and measure a process point all day long without knowing who the the raw material supplier is.
I can measure and monitor step 4 of a process without knowing who performed steps 1, 2 and 3. I can monitor and measure step 4 without knowing when steps 1, 2 and 3 were performed, by whom, with what tools or material.
As a community of quality professionals, we really have to try to get out of the "only one, traditional approach" to business and requirements.
I think traceability is incredibly important espeically within the automotive industry supplier chain. But no where does TS 16949 require it, which I believe was the orignal question. If the question is "Is traceability a good idea?", then we have different question to discuss.
bobdoering
Stop X-bar/R Madness!!
#22
For that matter, you can make parts all day without monitoring or measuring any of them. There are some production managers that will support that approach. This could be a new "non-traditional" quality system. Might be worth a shot. Saves lots of trees - so it is ISO 14001 compliant.
Might make corrective actions a little tougher to work through, but if you make all of the parts right you won't have any corrective actions! Problem solved!
Anyone ready to sign up?:cool:
I will forward this suggestion to my SQA.:sarcasm:
Sorin
#23
1.I can monitor and measure a process point all day long without knowing who the the raw material supplier is.
2.I can measure and monitor step 4 of a process without knowing who performed steps 1, 2 and 3. I can monitor and measure step 4 without knowing when steps 1, 2 and 3 were performed, by whom, with what tools or material.
3.As a community of quality professionals, we really have to try to get out of the "only one, traditional approach" to business and requirements.
4.I think traceability is incredibly important espeically within the automotive industry supplier chain. But no where does TS 16949 require it, which I believe was the orignal question. If the question is "Is traceability a good idea?", then we have different question to discuss.
With disregard of any standard:
1.Raw material characteristics/properties are what matters not necessarily who the supplier is.
2.O/c you can measure but how do you record the monitoring?
A simple example...
Assembly 01 is made of parts A and B through 2 steps process for each A and B (a1/a2 and b1/b2) and a final assembly process c.
How will you know, in the event of a need (anything: CPA, NC, CC, time-study, etc), the data needed if there is no traceability involved?
How will you trace data needed if the need arise after X days/weeks/months/years?
3.I am a lil flabbergasted here....traceability is not something that is inter-changeable....you do it or not....how you will do it that's another fish...
4.Traceability have nothing to do with the industry type. If you want to be able to control and improve your business (IMHO) you need to implement a traceability related system. I have, in mind, an endless list of businesses that have nothing to do with automotive and they cannot operate without a traceability system.
BUT...as someone said, it's a choice. And as with any choice there are consequences. Traceability is (again IMHO) a great tool in improving a product/process/business. One can do without, probably, but I would not want to work there (question of choice).
Stijloor
#24
Helmut -
Are there requirements as to the retention times that these recorded lot numbers are supposed to be held? CSRs - Ford for example - talk about "Production inspection and test records (e.g. control charts, inspection and test results)" but don't specify lot number retention.
We are trying to better utilize our system and are looking for an answer to the "how long to keep lot numbers" question.
Thanks.
Hi Kelly,
I would suggest looking at the PPAP manual. The record retention "default" specified there makes sense: "...the life of the part plus one calendar year.."
That, of course, assuming that there are no CSR's associated with lot number records. But you already looked into this.
Hope this helps.
Jan R. (AKA "Stijloor")
P
prototyper
#25
I have been involved with 3 situations which could have resulted in a warranty recall. Good traceability records, combined with good root cause analysis, were able to narrow down the potentially defective parts so far that the recalls were avoided.
Don't waste time arguing which clause says what, keep good records for at least the life of the product and avoid expensive recalls, law suits, etc., unless your product is totally risk free!
V
vanputten
#26
Bobdoering:
You totally misread my posting. Also, re-read the posting to which I am responding. Please try to read a little more critically. :read:
Who said not to montior or measure? :confused: I was responding to a posting that implied traceability is required to perform measuring and/or montioring.
I stated "I can monitor and measure a process..." I did not say "I should." or that "I would." I said that one can perform measuring and montioring without traceability.
Traceability is not required to perform measuring or monitoring. Traceability is not required by TS 16949 unless it is required by the customer. :frust:
AGAIN, TRACEABILITY, MEASURING AND MONITORING ARE ALL GOOD THINGS TO DO IN MOST SITUATIONS.
The "traditions" that I am resisting is the assumption that X, Y or Z is a requirement becasue that is the way "it has always been done." The use of the acronym "SQA" is another example of traditional approaches and assumptions.
Sorin
#27
Given that english is my only 3rd language I tend to do mistake , sometimes, in interpreting the correct meaning of a word.
In this case the word is "(to )monitor".
I looked in dictionary. It means: to watch, keep track of, or check.
I just assume that for the purpose of our debate the meaning that we look at is "keep track" (I really hope is not "watch" :D ).
Without any irony implied I would like to know how a product could be monitored without a tracing system (see pragraph below)
8.2.4 Monitoring and measurement of product
The organization shall monitor and measure the characteristics of the product to verify that product requirements have been met. This shall be carried out at appropriate stages of the product realization process in accordance with the planned arrangements.
NB: emphasis is mine.
I just want to understand (specific example will help, if possible) how I can monitor (and measure) the characteristics of a given product through a process (or the whole manufacturing cycle) if that product is not identified.
Just so that we don't get tangled:it's about the product and not about the process.
Caster
An Early Cover
#28
I sense from the initial post that if there is not a specific requirement, there is no point to implement the idea. Look, there are reasons why these ideas are put in the standards. It is not to be punitive - it is because issues have occurred over and over again, and the best practice to deal with the issues included having these ideas built into the quality system. Traceability is one such idea..
Wow - I pity you, you think just like I do!
I tell people these standards were built up from typical things gone wrong at companies just like ours. If we put some simple things in place to guard against these common problems, we will be better off.
But some people just gotta fight, if it doesn't say it in black and white they ain't gonna do it, and they actually seem to take pride in their (hollow) victory over the standard or the customer.
My brother as a great expression for these people "fill your boots"
V
vanputten
#29
Quality Digest just published an article on Measuring and Monitoring that offers defintions of "Measuring" and "Monitoring." This artilce may help you understand these terms.
I like the concetps that "Measuring" results in discrete values. Monitoring does not necesarily result in a discrete value. Monitoring can be attribute in nature. i will offer, in my opinion, htat most organizations will be effective with both measuring and montioring. I would think that measuring everything would be overkill and waste resources.
http://www.qualitydigest.com/magazine/2008/oct/column/measuring-measurement-equipment.html
I just did a breif review of TS 16949, ISO 9000:2005 and ISO 10012. I did not find any definitions for the terms "Measure" and "Montior."
For a process: Let's pretend that my job is to check a pressure gauge every hour. The gauge is an analog gauge with a needle. The needle must be in the green colored section of the dial. Every hour I look to see if the needle is in the green area on the dial. Do I need to know anything about the previous process steps to "monitor" the needle's location on the dial? No. Is this the most effective way of running a business? Depends. Do I need to know more if I have to solve a problem? Probably. If there is a problem, will I need to know more than the attribute data gained by monitoring? Probably.
For a product: let's opretend that I have a gauge that confirms a product characterisitc is whin a certian range. The gauge does not provide variable data. I tonly tells me if the characterisitic is within a range (attribtue data) My job is to check the characterisitc every 30 minutes. Can I monitor that product characterisitc without knowing the previous steps? All day long. Is this the most effective way of running a business? Depends. Do I need to know more if I have to solve a problem? Probably. If there is a problem, will I need to know more than the attribute data gained by monitoring? Probably.
And finally, the original question was, "does TS has a traceability requirement?" I am trying to answer that question. I am trying to avoid the question, "What is the best way to perform measuring, monmitoring and traceability?" since the answer is specific to the organization and industry. Am I a fan of a compliance approach to requriements? I hate the compliance approach. But the original question appeared to be compliance in nature.
I assume Caster's last posting is not directed at me since I did not ever suggest to only meet the minumim requirements. I tried to describe what the minimum requirements are. That wa the original question.
ralphsulser
#30
I started in quality control 40 years ago and it was always part of the practice to use some type of traceability. That was long before any quality systems standards, except MIL-4858. "It is good to do it to protect your butt"
D Does IATF 16949:2016 Clause 7.3 (now 8.3) Apply to "Grandfathered" Products IATF 16949 - Automotive Quality Systems Standard 4
D What does Zero Defects mean? TS 16949 Clause 7.1.2 AQL - Acceptable Quality Level 6
D Which supplier does clause TS 16949 clause 7.4 refer to? IATF 16949 - Automotive Quality Systems Standard 5
Howard Atkins What does the internal audit procedure for TS 16949 need to include? Clause 8.2.2 General Auditing Discussions 7
L What does "This applies equally to purchased product" mean? TS 16949 clause 8.3.4 IATF 16949 - Automotive Quality Systems Standard 2
L TS 16949 Clause 4.2.2 c - Interaction of Processes - What does this mean? IATF 16949 - Automotive Quality Systems Standard 184
J Does anyone have an excel IATF 16949 Internal Audit checklist I could use? IATF 16949 - Automotive Quality Systems Standard 7
L "IATF-Compliant" IATF 16949:2016 certification? What does this mean? IATF 16949 - Automotive Quality Systems Standard 13
M IATF 16949 - 8.5.6.1.1 Providing a list of process controls: Does this requirement add value to QMS? IATF 16949 - Automotive Quality Systems Standard 4
D IATF 16949 - 8.5.2.1 Traceability Plan - Does anyone have an example? IATF 16949 - Automotive Quality Systems Standard 4
B Does Toyota utilize IATF 16949? IATF 16949 - Automotive Quality Systems Standard 4
S Does anyone have any pointers on TS 16949 Internal Auditor Training IATF 16949 - Automotive Quality Systems Standard 4
A Does ISO/TS 16949:2009 require us to perform Final/Pre-dispatch Inspection? IATF 16949 - Automotive Quality Systems Standard 5
J Does TS 16949 audit replacement parts? IATF 16949 - Automotive Quality Systems Standard 2
T If a company becomes TS 16949 certified does it still need ISO 9001 certification? IATF 16949 - Automotive Quality Systems Standard 12
J Does ISO/TS 16949 apply to Proprietary Parts? IATF 16949 - Automotive Quality Systems Standard 4
D Does ISO/TS 16949:2009 require a Records Matrix? IATF 16949 - Automotive Quality Systems Standard 11
I Does TS 16949 clearly require an annual product re-validation? IATF 16949 - Automotive Quality Systems Standard 17
V Customer-Specified Parts - What does "customer-specified" in TS 16949 mean? IATF 16949 - Automotive Quality Systems Standard 6
E Does the ISO/TS 16949 scope have to include all processes, even if outsourced? IATF 16949 - Automotive Quality Systems Standard 7
J Does my company's Business Plan Contents comply with requirements of TS 16949? IATF 16949 - Automotive Quality Systems Standard 2
J How does ISO/TS 16949:2002 differ from ISO/TS 16949:2009? IATF 16949 - Automotive Quality Systems Standard 43
M Does TS 16949 require inspection? Imported parts IATF 16949 - Automotive Quality Systems Standard 9
G Does BSI do ISO 9001/TS 16949 Lead Auditor training? Training - Internal, External, Online and Distance Learning 5
S Does Subaru require TS 16949 certification? IATF 16949 - Automotive Quality Systems Standard 3
R Does a completed PPAP have to exist for TS 16949 registration IATF 16949 - Automotive Quality Systems Standard 3
E Quality System Software with TS 16949, Does it good? IATF 16949 - Automotive Quality Systems Standard 1
T Does a years worth of prototype manufacturing "count" for TS 16949? IATF 16949 - Automotive Quality Systems Standard 6
B Does TS 16949 standard update by next year? IATF 16949 - Automotive Quality Systems Standard 1
D Does anyone know if there is much difference between TS 16949 and Nadcap. IATF 16949 - Automotive Quality Systems Standard 3
D Does TS 16949 require us to have an internal laboratory? IATF 16949 - Automotive Quality Systems Standard 7
B Does the scope of TS 16949 include 'Trucks' IATF 16949 - Automotive Quality Systems Standard 5
C Does it make sense to hold both ISO 9001 & TS 16949 registrations? World News 16
H Where does the 16949 number in TS16949 come from? ISO Numbering System IATF 16949 - Automotive Quality Systems Standard 1
B Does the ISO/TS 16949 standard actually require the title "QUALITY POLICY" to be used Document Control Systems, Procedures, Forms and Templates 4
A Does ISO 9001 or TS 16949 have any requirement like 777 rules for control charts? Statistical Analysis Tools, Techniques and SPC 12
tony s Does RFQ from mother plant enough to initiate TS 16949 certification? IATF 16949 - Automotive Quality Systems Standard 2
J Process Audit recommendation within ISO TS 16949? Does it exist like in VDA? Process Audits and Layered Process Audits 18
J Does ISO/TS 16949 require ISO 14001? IATF 16949 - Automotive Quality Systems Standard 19
C Auditing a Tooling Shop - Does that area need to be audited to TS 16949 IATF 16949 - Automotive Quality Systems Standard 2
S TS 16949 Compliant Control Plans - Does every item need a record? FMEA and Control Plans 5
A Q1 Revoked. How does this affect TS 16949? IATF 16949 - Automotive Quality Systems Standard 5
J What exactly does 4.2.3.1 "Engineering Specifications" in ISO/TS 16949 mean? IATF 16949 - Automotive Quality Systems Standard 22
M TS 16949 subscribing customers - Does the IATF issue such a list? ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 0
I Internal Auditor Training - Does TS 16949 Require Formal Training or Certification? Internal Auditing 19
D Does ISO/TS 16949:2002 Address any Environmental Issues IATF 16949 - Automotive Quality Systems Standard 4
J Should "process maps" be challenged? Does TS 16949 require process maps or not? Process Maps, Process Mapping and Turtle Diagrams 19
H TS 16949 - 7.5.2.1 - Why does TS ask for process validation for all the production? IATF 16949 - Automotive Quality Systems Standard 5
T What does TS in TS 16949 mean? ISO Standards Development Process IATF 16949 - Automotive Quality Systems Standard 11
