Does TS 16949 clearly require an annual product re-validation?
Stijloor
#11
Dear
how do you interpret the point af the ISO/TS about product layout/product requalification?
In our company we re-qualify our product with a product audit each two years.
Does the ISO/TS clearly require an annual product re-validation?
Paolo
Layout inspection requirements are spelled out in the applicable Customer Specific Requirements (CSR's).
LUV-d-4UM
#12
Some OEMs have a specific specification as to what is to be measured and/or tested every year. As a previous poster quite rightly wrote 'check the CSRs'. Some of them have teeth and cost money!
Annual Layout inspection is conducted only if you have OEM customers that require it.
Golfman25
#13
The problem with blanket requirements is they tend to be over broad. Does everything need to be redone, always? Or can we use some common sense and do that which is important?
LUV-d-4UM
#14
You could ask the customer to waiver this specific requirement clause 7.2.2.1 supplemental:)
#17
I've seen customers who wanted only a dimensional layout annually, and others that required a full Level 3 PPAP submission. If the customer requires annual PPAP (as opposed to just a layout) and uses the AIAG requirements, even a Level 2 PPAP requires all of the relevant elements to be completed, but only some to be submitted. It's important that the requirements are very clear and in writing.
howste
Thaumaturge
#18
Re: How to detail an annual product re-validation on the Control Plan?
I have been out of Automotive Industry for a few years, and recently was made aware of a CSR dealing with an Annual Re-qualification [Re-Validation] that states: "Annual Layout inspection requirements shall be detailed in the suppliers control plan." Would someone be so kind as to describe how this requirement would be detailed in the Control Plan? Is it a step in the Process Flow, and an Operation in the Control Plan that identifies the requirement; OR do you have to identify all the characteristics from the ISIR too? Just wondering?
Thanks for your help in this matter!
Douglas
I usually see a line item in the control plan (at the very end or in a final inspection step) that just says "Full Layout" with a frequency of once/year. Identifying each characteristic in the control plan would be extreme overkill in my view.
J Does anyone have an excel IATF 16949 Internal Audit checklist I could use? IATF 16949 - Automotive Quality Systems Standard 7
L "IATF-Compliant" IATF 16949:2016 certification? What does this mean? IATF 16949 - Automotive Quality Systems Standard 13
M IATF 16949 - 8.5.6.1.1 Providing a list of process controls: Does this requirement add value to QMS? IATF 16949 - Automotive Quality Systems Standard 4
D IATF 16949 - 8.5.2.1 Traceability Plan - Does anyone have an example? IATF 16949 - Automotive Quality Systems Standard 4
B Does Toyota utilize IATF 16949? IATF 16949 - Automotive Quality Systems Standard 4
D Does IATF 16949:2016 Clause 7.3 (now 8.3) Apply to "Grandfathered" Products IATF 16949 - Automotive Quality Systems Standard 4
S Does anyone have any pointers on TS 16949 Internal Auditor Training IATF 16949 - Automotive Quality Systems Standard 4
A Does ISO/TS 16949:2009 require us to perform Final/Pre-dispatch Inspection? IATF 16949 - Automotive Quality Systems Standard 5
J Does TS 16949 audit replacement parts? IATF 16949 - Automotive Quality Systems Standard 2
T If a company becomes TS 16949 certified does it still need ISO 9001 certification? IATF 16949 - Automotive Quality Systems Standard 12
J Does ISO/TS 16949 apply to Proprietary Parts? IATF 16949 - Automotive Quality Systems Standard 4
D Does ISO/TS 16949:2009 require a Records Matrix? IATF 16949 - Automotive Quality Systems Standard 11
V Customer-Specified Parts - What does "customer-specified" in TS 16949 mean? IATF 16949 - Automotive Quality Systems Standard 6
E Does the ISO/TS 16949 scope have to include all processes, even if outsourced? IATF 16949 - Automotive Quality Systems Standard 7
J Does my company's Business Plan Contents comply with requirements of TS 16949? IATF 16949 - Automotive Quality Systems Standard 2
J How does ISO/TS 16949:2002 differ from ISO/TS 16949:2009? IATF 16949 - Automotive Quality Systems Standard 43
M Does TS 16949 require inspection? Imported parts IATF 16949 - Automotive Quality Systems Standard 9
G Does BSI do ISO 9001/TS 16949 Lead Auditor training? Training - Internal, External, Online and Distance Learning 5
S Does Subaru require TS 16949 certification? IATF 16949 - Automotive Quality Systems Standard 3
R Does a completed PPAP have to exist for TS 16949 registration IATF 16949 - Automotive Quality Systems Standard 3
E Quality System Software with TS 16949, Does it good? IATF 16949 - Automotive Quality Systems Standard 1
T Does a years worth of prototype manufacturing "count" for TS 16949? IATF 16949 - Automotive Quality Systems Standard 6
B Does TS 16949 standard update by next year? IATF 16949 - Automotive Quality Systems Standard 1
D Does anyone know if there is much difference between TS 16949 and Nadcap. IATF 16949 - Automotive Quality Systems Standard 3
D Does TS 16949 Clause 7.5.3 require our product to have traceability? IATF 16949 - Automotive Quality Systems Standard 31
D What does Zero Defects mean? TS 16949 Clause 7.1.2 AQL - Acceptable Quality Level 6
D Does TS 16949 require us to have an internal laboratory? IATF 16949 - Automotive Quality Systems Standard 7
B Does the scope of TS 16949 include 'Trucks' IATF 16949 - Automotive Quality Systems Standard 5
C Does it make sense to hold both ISO 9001 & TS 16949 registrations? World News 16
H Where does the 16949 number in TS16949 come from? ISO Numbering System IATF 16949 - Automotive Quality Systems Standard 1
D Which supplier does clause TS 16949 clause 7.4 refer to? IATF 16949 - Automotive Quality Systems Standard 5
Howard Atkins What does the internal audit procedure for TS 16949 need to include? Clause 8.2.2 General Auditing Discussions 7
B Does the ISO/TS 16949 standard actually require the title "QUALITY POLICY" to be used Document Control Systems, Procedures, Forms and Templates 4
A Does ISO 9001 or TS 16949 have any requirement like 777 rules for control charts? Statistical Analysis Tools, Techniques and SPC 12
tony s Does RFQ from mother plant enough to initiate TS 16949 certification? IATF 16949 - Automotive Quality Systems Standard 2
J Process Audit recommendation within ISO TS 16949? Does it exist like in VDA? Process Audits and Layered Process Audits 18
J Does ISO/TS 16949 require ISO 14001? IATF 16949 - Automotive Quality Systems Standard 19
C Auditing a Tooling Shop - Does that area need to be audited to TS 16949 IATF 16949 - Automotive Quality Systems Standard 2
S TS 16949 Compliant Control Plans - Does every item need a record? FMEA and Control Plans 5
A Q1 Revoked. How does this affect TS 16949? IATF 16949 - Automotive Quality Systems Standard 5
J What exactly does 4.2.3.1 "Engineering Specifications" in ISO/TS 16949 mean? IATF 16949 - Automotive Quality Systems Standard 22
M TS 16949 subscribing customers - Does the IATF issue such a list? ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 0
L What does "This applies equally to purchased product" mean? TS 16949 clause 8.3.4 IATF 16949 - Automotive Quality Systems Standard 2
I Internal Auditor Training - Does TS 16949 Require Formal Training or Certification? Internal Auditing 19
D Does ISO/TS 16949:2002 Address any Environmental Issues IATF 16949 - Automotive Quality Systems Standard 4
J Should "process maps" be challenged? Does TS 16949 require process maps or not? Process Maps, Process Mapping and Turtle Diagrams 19
H TS 16949 - 7.5.2.1 - Why does TS ask for process validation for all the production? IATF 16949 - Automotive Quality Systems Standard 5
T What does TS in TS 16949 mean? ISO Standards Development Process IATF 16949 - Automotive Quality Systems Standard 11
B Does a distributor have to have an ISO 9001 cert to sell to a TS 16949 company? IATF 16949 - Automotive Quality Systems Standard 26
