Does TS 16949 require us to have an internal laboratory?
darkafar
TS clause 7.6.3.1 states the requirements of an organization’s internal laboratory.
TS clause 1.2 states, “The only permitted exclusions for this Technical Specification relate to 7.3 where the organization is not responsible for product design and development.”
Clause 7.6.3.1 is not a sub-clause of 7.3, so I thought that TS requires an organization to have an internal laboratory, loud and clear.
Then I read clause 7.6.2, which states, “Records of the calibration/verification activity……shall include….an assessment of the impact of out-of-specification condition.”
By the clause 1.2 rule, this is a requirement. But we have practical difficulty, what if there is no out-of-specification happening during calibration? So I think what clause 7.6.2 actually means is that we should assess the impact of out-of-specification if out-of-specification situation happens.
Back to clause 7.6.3.1, imagine we are a very small factory. Our only process is stamping metal plate. We use caliper to measure the dimensions before and after the stamping. We send our caliper to a qualified external laboratory for calibration periodically. Why do I need an internal laboratory?
So I begin to think that internal laboratory is not a requirement, but an option. The intent of TS clause 7.6.3 is that we need to have laboratory, internal or external, to guarantee measurement traceability. But we don’t have to have both.
What do you think?
Re: Does TS require us to have an internal laboratory?
In the context of an automotive supplier it's hard to conceive that there isn't some kind of I T & ME calibration and/or product testing being performed within that supplier's facilities.
It's very unusual, although entirely possible, that all calibration and product inspections/layouts/functional testing are contracted out. Only in that case would the supplier organization not have to meet the requirements o an 'internal lab'......
darkafar
Are you suggesting we should let laboratory scope includes the on-line inspections?
Now imagine a big factory, which has all kinds of testing, calibrations, inspections, on-line or off-line. Many of my friends prefer to separate the on-line inspection from other types of inspection, testing, calibration, because the environment is different. They call the facilities used for these activities laboratories, but they don’t consider the on-line inspections part of the laboratory activities. Do you think they are wrong?
If you don’t think they are wrong, aren’t we double standarding by requiring the small factory to include on-line inspection into laboratory scope, while not requiring the big factory to include on-line inspection into laboratory scope?
You are correct about the in-process inspections. These are not labs.
I was thinking more about the PPAP-type of inspections and testing. Done before production and often in a 'lab' somewhere. If these are done outside, then no lab is necessary, internally. I guess even if the stampings could be ully dimensionally verified by hand tools, then a lab isn't required, either. Do you not verify any tooling on a cmm or similar? Or is that also sent outside?
darkafar
I think I got what you mean. The layout inspection probably needs to be done off-line in a “laboratory”. Since PPAP says “Inspection and testing for PPAP shall be performed by a qualified laboratory as defined by customer requirements”, I guess even if we use the same caliper, but at different location, we still have a laboratory of some kind
Howard Atkins
Forum Administrator
The definition of laboratory in TS is
3.1.4
laboratory
facility for inspection, test or calibration that may include, but is not limited to, chemical, metallurgical, dimensional, physical, electrical or reliability testing
This includes almost everything
dna_leri
What do you think?
I completely agree with your statement above. There is no requirement to have an internal laboratory - all the required laboratory inspection, testing & calibration could be done by an external qualified laboratory.
That's what I was thinking.......:agree1:
A Does ISO/TS 16949:2009 require us to perform Final/Pre-dispatch Inspection? IATF 16949 - Automotive Quality Systems Standard 5
D Does ISO/TS 16949:2009 require a Records Matrix? IATF 16949 - Automotive Quality Systems Standard 11
I Does TS 16949 clearly require an annual product re-validation? IATF 16949 - Automotive Quality Systems Standard 17
M Does TS 16949 require inspection? Imported parts IATF 16949 - Automotive Quality Systems Standard 9
S Does Subaru require TS 16949 certification? IATF 16949 - Automotive Quality Systems Standard 3
D Does TS 16949 Clause 7.5.3 require our product to have traceability? IATF 16949 - Automotive Quality Systems Standard 31
B Does the ISO/TS 16949 standard actually require the title "QUALITY POLICY" to be used Document Control Systems, Procedures, Forms and Templates 4
J Does ISO/TS 16949 require ISO 14001? IATF 16949 - Automotive Quality Systems Standard 19
I Internal Auditor Training - Does TS 16949 Require Formal Training or Certification? Internal Auditing 19
J Should "process maps" be challenged? Does TS 16949 require process maps or not? Process Maps, Process Mapping and Turtle Diagrams 19
apestate Does TS 16949 require all suppliers (vendors) to be ISO 9001 registered? IATF 16949 - Automotive Quality Systems Standard 4
J Does anyone have an excel IATF 16949 Internal Audit checklist I could use? IATF 16949 - Automotive Quality Systems Standard 7
L "IATF-Compliant" IATF 16949:2016 certification? What does this mean? IATF 16949 - Automotive Quality Systems Standard 13
M IATF 16949 - 8.5.6.1.1 Providing a list of process controls: Does this requirement add value to QMS? IATF 16949 - Automotive Quality Systems Standard 4
D IATF 16949 - 8.5.2.1 Traceability Plan - Does anyone have an example? IATF 16949 - Automotive Quality Systems Standard 4
B Does Toyota utilize IATF 16949? IATF 16949 - Automotive Quality Systems Standard 4
D Does IATF 16949:2016 Clause 7.3 (now 8.3) Apply to "Grandfathered" Products IATF 16949 - Automotive Quality Systems Standard 4
S Does anyone have any pointers on TS 16949 Internal Auditor Training IATF 16949 - Automotive Quality Systems Standard 4
J Does TS 16949 audit replacement parts? IATF 16949 - Automotive Quality Systems Standard 2
T If a company becomes TS 16949 certified does it still need ISO 9001 certification? IATF 16949 - Automotive Quality Systems Standard 12
J Does ISO/TS 16949 apply to Proprietary Parts? IATF 16949 - Automotive Quality Systems Standard 4
V Customer-Specified Parts - What does "customer-specified" in TS 16949 mean? IATF 16949 - Automotive Quality Systems Standard 6
E Does the ISO/TS 16949 scope have to include all processes, even if outsourced? IATF 16949 - Automotive Quality Systems Standard 7
J Does my company's Business Plan Contents comply with requirements of TS 16949? IATF 16949 - Automotive Quality Systems Standard 2
J How does ISO/TS 16949:2002 differ from ISO/TS 16949:2009? IATF 16949 - Automotive Quality Systems Standard 43
G Does BSI do ISO 9001/TS 16949 Lead Auditor training? Training - Internal, External, Online and Distance Learning 5
R Does a completed PPAP have to exist for TS 16949 registration IATF 16949 - Automotive Quality Systems Standard 3
E Quality System Software with TS 16949, Does it good? IATF 16949 - Automotive Quality Systems Standard 1
T Does a years worth of prototype manufacturing "count" for TS 16949? IATF 16949 - Automotive Quality Systems Standard 6
B Does TS 16949 standard update by next year? IATF 16949 - Automotive Quality Systems Standard 1
D Does anyone know if there is much difference between TS 16949 and Nadcap. IATF 16949 - Automotive Quality Systems Standard 3
D What does Zero Defects mean? TS 16949 Clause 7.1.2 AQL - Acceptable Quality Level 6
B Does the scope of TS 16949 include 'Trucks' IATF 16949 - Automotive Quality Systems Standard 5
C Does it make sense to hold both ISO 9001 & TS 16949 registrations? World News 16
H Where does the 16949 number in TS16949 come from? ISO Numbering System IATF 16949 - Automotive Quality Systems Standard 1
D Which supplier does clause TS 16949 clause 7.4 refer to? IATF 16949 - Automotive Quality Systems Standard 5
Howard Atkins What does the internal audit procedure for TS 16949 need to include? Clause 8.2.2 General Auditing Discussions 7
A Does ISO 9001 or TS 16949 have any requirement like 777 rules for control charts? Statistical Analysis Tools, Techniques and SPC 12
tony s Does RFQ from mother plant enough to initiate TS 16949 certification? IATF 16949 - Automotive Quality Systems Standard 2
J Process Audit recommendation within ISO TS 16949? Does it exist like in VDA? Process Audits and Layered Process Audits 18
C Auditing a Tooling Shop - Does that area need to be audited to TS 16949 IATF 16949 - Automotive Quality Systems Standard 2
S TS 16949 Compliant Control Plans - Does every item need a record? FMEA and Control Plans 5
A Q1 Revoked. How does this affect TS 16949? IATF 16949 - Automotive Quality Systems Standard 5
J What exactly does 4.2.3.1 "Engineering Specifications" in ISO/TS 16949 mean? IATF 16949 - Automotive Quality Systems Standard 22
M TS 16949 subscribing customers - Does the IATF issue such a list? ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 0
L What does "This applies equally to purchased product" mean? TS 16949 clause 8.3.4 IATF 16949 - Automotive Quality Systems Standard 2
D Does ISO/TS 16949:2002 Address any Environmental Issues IATF 16949 - Automotive Quality Systems Standard 4
H TS 16949 - 7.5.2.1 - Why does TS ask for process validation for all the production? IATF 16949 - Automotive Quality Systems Standard 5
T What does TS in TS 16949 mean? ISO Standards Development Process IATF 16949 - Automotive Quality Systems Standard 11
