Double Ended Thread Plug Gauge Calibration
CaliperJim
Hello. We use double ended GO/NO GO Thread Plug Gauges within a handle. Historically, we have serialized the GO gauge and the NO GO gauge with unique IDs. Current State Example: GO side gauge ID 372 and NO GO side gauge ID 402 are installed in same handle, and calibration records are maintained under each ID. The calibration vendor produces a certificate for 372 and a certificate for 402.
I would like to change to one ID and one calibration certificate with separate results for the GO and NO GO gauges. The GO gauge, and NO GO gauge, and handle are considered one measuring tool. As GO and NO GO gauges get replaced, the new gauges are installed in the handle and calibrated under the one tool ID. Are there any problems with switching to one tool ID for GO and NO GO gauges installed in the same handle? Thanks.
ScottK
Not out of the crisis
Not at all. That's how I've always done it and no auditor or regulatory body ever had a problem with it.
Consider it like an Optical Comparator - 3 axis that need to be checked separately, but one calibration sticker on the machine.
Ron Rompen
I agree with Scott. In the past, I have always treated a set of Go/NoGo gauges (thread, diameter, profile, whatever) as a single gauge. As long as your internal procedures don't say otherwise, and you maintain your records correctly, there should be no issue.
I would urge you to document (somewhere) your change in practice, so that if an auditor pulls up 'old' records and tries to correlate them to 'new' records, you can easily explain why there isn't a seamless paper trail.
ChrisM
I've never heard of anyone allocating 2 gauge numbers to a go/no-go gauge, it's always been one number as it is one physical item.
If you have concerns about changing one end, you could always allocate a new gauge number if that should happen, rather than "complicating" your record for the gauge when a change of end occurs
Scanton
Wearer of many hats
We have over a thousand thread gauges
All of our gauges have a unique reference, a “TR” number for a thread ring, a “TP” number for a thread plug.
A typical thread plug (e.g. TP109) will have a “Go” and a “NoGo” end, and both will have separate unique serial numbers.
If one or the other end shows it is well into to its wear allowance after calibration it will be replaced with a brand new end, that will come with a different serial number. The thread plug will still be TP109 but our records will show the transition date, new unique serial number and reason for change for the new end.
This is and has been standard practice for decades and has never been an issue during ISO9001/IATF16949 audits.
blackholequasar
The Cheerful Diabetic
They only way that I would think an individual calibration asset number should be assigned to a plug end is if it is interchangeable with others to make unique combinations based on a job/run. But if, once combined, it does not change again then I always go for the K.I.S.S approach :)
Enghabashy
I see also it's ok , the most detritions/wear are happened in Go ; therefore if we use exchangeable terminal it will more cost effective to safe the scraping of both ,
*evidence for scraping record should be kept for old gauge because the identification is still engraved / labeled in handle or in gauge box
*The uncertainty calculation & MSA should be considering the new calibration certificates of the new Go Gauge also.
dwperron
Both identification methods are acceptable and will stand up to audits. I prefer an identification for the set, but the company I currently work at has always used the identification of each plug method.....
One reason for identifying each plug gauge is that the only way that you are sure that the right gauges are in a handle is to take them out and identify them. You aren't as likely to do that when you treat them as a set - it's just easier to assume that you have the correct set in the handle. We recently got a set back that ended up with two GO gauges installed, so you know that stuff like that can happen.
CaliperJim
Perfect. Exactly how I intend to handle it. Glad there is proof it's acceptable. Thanks
J Screw Thread Inspection Standards? Double Ended Stud Inspection Criteria Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
L Class II (Double Insulated) Power Supply with Output Tied to Earth: FE or PE? IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
Scanton Double Major for the same infraction? IATF 16949 - Automotive Quality Systems Standard 11
U Cpk Calculation - I analyse a double seam cans Manufacturing and Related Processes 15
R IMDS for double sourced component RoHS, REACH, ELV, IMDS and Restricted Substances 3
J Double-Retest of Nonconforming Material to Accept the Material Nonconformance and Corrective Action 5
S Double Thermocouple - Two types, same sheath (AMS2750/Nadcap) Manufacturing and Related Processes 9
S Is double packaging obligatory for surgical single-use scalpels? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
V Difference between a "Double D" slot and a "True Slot" Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
P Lot Acceptance Plan that specifies BS 6001 Double Sampling Plans, general inspection Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
P IEC 60601-1-11 - Conversion to Double Insulation IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
M FDA Submission Printing Format - Is double sided printing allowed? Other US Medical Device Regulations 5
M OC Curves for Double Sampling Plan - How are they Derived? Statistical Analysis Tools, Techniques and SPC 2
R Double Spec'ing in Control Plans FMEA and Control Plans 11
P Understanding IEC 60601-1:2005, Clause 8.1 b) - Short Circuiting Double Insulation IEC 60601 - Medical Electrical Equipment Safety Standards Series 13
I ERP acronym has double meaning in our company Internal Auditing 6
G Double Blister Pack for an Implantable Device Other ISO and International Standards and European Regulations 1
S Do insulation layers in double insulation have sequence requirement? IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
R Calculation Mean for Control Chart -X Double Bar Statistical Analysis Tools, Techniques and SPC 13
M Effect of double ETO (Ethylene Oxide) Sterilization ISO 13485:2016 - Medical Device Quality Management Systems 13
S Double certification 93/42/EEC and 89/689/EEC for gloves possible? EU Medical Device Regulations 4
kedarg6500 Writing the symbol for R bar bar (double bar) in Excel Excel .xls Spreadsheet Templates and Tools 3
B Define Fault, Double Fault and Normal Conditions - Preparing a Risk Management File FMEA and Control Plans 1
T Double Sampling Plan Explanation for * Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
T Double-sided (USL, LSL) Variables sampling plan Z1.9 - Use in Excel spreadsheet? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
T From ECR (Engineering Change Request) to ECN (Engineering Change Note) - double work! Document Control Systems, Procedures, Forms and Templates 2
W Advice on the best way to approach a double moving average using Minitab 15 Using Minitab Software 3
V Draw OC curve - Double sampling plan Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
C Company has double identity - How do I state this in our QM (quality manual)? Quality Management System (QMS) Manuals 4
Marc Toyota vehicle recalls double in 2005 World News 1
D Unilateral / Bilateral Tolerances for dimensions with Double Plus or Minus Tolerance Statistical Analysis Tools, Techniques and SPC 12
C Retention of Clinical Trial Data after a Clinical Trial has ended Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 5
Zero_yield Thread Necromancy Coffee Break and Water Cooler Discussions 9
R Calibrating Solid Thread Rings with HILO master General Measurement Device and Calibration Topics 1
B Calibration of Thread Gages with Metric Standards with Conversion to Imperial Units General Measurement Device and Calibration Topics 3
G G11 5/8" Thread Manufacturing and Related Processes 0
Miner Reported content: Post in thread 'Form of real time study for establish shelf time' Document Control Systems, Procedures, Forms and Templates 1
N Validation of special processes - thread closed Oil and Gas Industry Standards and Regulations 3
D Accurately measuring Full Thread Length Inspection, Prints (Drawings), Testing, Sampling and Related Topics 11
DuncanGibbons Additive Manufacturing Processes Thread Manufacturing and Related Processes 6
C Aluminum galling on thread plug gauge Manufacturing and Related Processes 10
ScottK Measuring thread flank angle on a screw Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
G Oversized Threads - What sized stab pin would be best to quickly check for oversized thread holes General Measurement Device and Calibration Topics 5
H Thread Plug Gauge Tolerances General Measurement Device and Calibration Topics 3
A Cost effective thread gaging with ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
APHX02 Thread Roll Process Verification w/in AS9100 (i.e. BSP-F-69/AS8879) Manufacturing and Related Processes 2
C Thread Tolerance - Can I use a 3A Ring on a part that the drawing calls out for a 2A? Manufacturing and Related Processes 5
M Error trying to Start a New Thread Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 2
M NPT thread gauging and the "rapping" process Manufacturing and Related Processes 1
