Double Sampling Plan Explanation for *
ThaRide
We have a product line with a lot size of 500. The inspection calls out for Level S-3, AQL=1.5% (Letter D). For a single sampling plan, that is 8 samples. Accept on 0 rejects, Reject on 1. I understand that much.
When a failure occurs, it has been suggested to then use a double sampling plan to further sample the lot to determine if it can be released. When I look on the other side of the AQL Inspectors rule, for 1.5% (Letter D), an asterisk is there and the notes suggests to use the single sampling plan on the other side. Since we already inspected 8 samples and had 1 reject, do we just pull another 8 samples (doubling the initial sample size) and release the lot if there are no more rejects?
The Double sample plans seem easy if you have a letter where the Acc-Rej is already defined 0-2, 0-3, but there doesnt seem to be a very good explanation when the * is identified.
Any help woudl be appreciated.
ThaRide
Thanks. It says for Double Sampling to use 20 samples. Which means that I ignore the reference to the asterisk. What is the purpose then of the asterisk? If I am using the Double Sampling plan, why does it even bother referring me to the Single Sampling plan?
So, lets say I did initially use a Single Sampling plan (8 samples, Acc-0, Rej-1) and had 1 failure. We decide to re-evaluate the lot using the Double Sampling Plan. I should then pull another 12 samples to make sure there is not another reject and then pull an additional 20 to complete the Double Sampling? Is that correct?
arios
If a double sampling plan is being used which initially asks you to sample 8, Acc-0, Rej-1 and you find one defect then you reject the batch, and there is no need to keep sampling. A disposition will then need to be made with the lot that was rejected: scrap, rework, sort, etc.
On the other hand if a double sampling plan provides you for example with a criteria like: Acc-0, Rej-2 and you find 1 defect on the initial sample you can't yet make a decision over the batch since it is between the Acc-Rej criteria, and that is when you use the second sampling. On the second sampling you will count the accumulated defects detected from the first and the second sample and compare the result vs. the Acc-Rej criteria for the second sampling, and that is when you make a decision. If no more defects are found you can accept the batch and take out the one piece defective
When you use a double sampling plan and you are required to examine 8 units on the 1st sampling, and 20 on the 2nd sampling, then you sample 8 and then 20, not 12. Sample size is not cummulative, but defects are.
ThaRide
Thanks for all of your help, it is greatly appreciated. So, for a lot size of 500, we would need to have selected Level I, Level II or Level III to have a chance at accepting the lot because all three of those Inspection levels would have pointed me to 20 samples Acc-0, Rej-2. If we use Level S-1, S-2, S-3 or S-4 that points us to the asterisk, which in turn points us to the Normal Sample Size of 8 samples Acc-1, Rej-0.
Since there is a chance of failure, what we would like to do is to be able to react when we do get a failure from Acc-0, Rej-1 and still state our confidence in the lot. If I am looking at AQL 1.5%, will I have the same confidence in the quality of the lot if I pull 8 samples (Acc-0, Rej-1) or if I pull 32 samples (Acc-1, Rej-2)?
arios
Here is my "5 cents":
Dr. Kaoru Ishikawa on his book titled "Guide to Quality Control" (Chapter 12) provides guidance on the selection of the inspection levels.
I will here quote him:
"Inspection level I: when the inspection cost is comparatively high
Inspection level II: ordinary cases
Inspection level III: when inspection costs are low
Inspection level S-1 to S-4: when the cost of destructive testing is high"
I know that there are folks in Elsmar with very good background in statistics and sampling techniques who can provide us with further guidance but at least I recommend the use of bibliographic support to define or select the inspection levels and justify the use of one or another approach.
P Lot Acceptance Plan that specifies BS 6001 Double Sampling Plans, general inspection Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
M OC Curves for Double Sampling Plan - How are they Derived? Statistical Analysis Tools, Techniques and SPC 2
T Double-sided (USL, LSL) Variables sampling plan Z1.9 - Use in Excel spreadsheet? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
V Draw OC curve - Double sampling plan Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
Scanton Double Major for the same infraction? IATF 16949 - Automotive Quality Systems Standard 11
U Cpk Calculation - I analyse a double seam cans Manufacturing and Related Processes 15
R IMDS for double sourced component RoHS, REACH, ELV, IMDS and Restricted Substances 3
J Double-Retest of Nonconforming Material to Accept the Material Nonconformance and Corrective Action 5
S Double Thermocouple - Two types, same sheath (AMS2750/Nadcap) Manufacturing and Related Processes 9
S Is double packaging obligatory for surgical single-use scalpels? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
V Difference between a "Double D" slot and a "True Slot" Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
P IEC 60601-1-11 - Conversion to Double Insulation IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
M FDA Submission Printing Format - Is double sided printing allowed? Other US Medical Device Regulations 5
R Double Spec'ing in Control Plans FMEA and Control Plans 11
P Understanding IEC 60601-1:2005, Clause 8.1 b) - Short Circuiting Double Insulation IEC 60601 - Medical Electrical Equipment Safety Standards Series 13
I ERP acronym has double meaning in our company Internal Auditing 6
G Double Blister Pack for an Implantable Device Other ISO and International Standards and European Regulations 1
S Do insulation layers in double insulation have sequence requirement? IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
R Calculation Mean for Control Chart -X Double Bar Statistical Analysis Tools, Techniques and SPC 13
M Effect of double ETO (Ethylene Oxide) Sterilization ISO 13485:2016 - Medical Device Quality Management Systems 13
S Double certification 93/42/EEC and 89/689/EEC for gloves possible? EU Medical Device Regulations 4
kedarg6500 Writing the symbol for R bar bar (double bar) in Excel Excel .xls Spreadsheet Templates and Tools 3
B Define Fault, Double Fault and Normal Conditions - Preparing a Risk Management File FMEA and Control Plans 1
T From ECR (Engineering Change Request) to ECN (Engineering Change Note) - double work! Document Control Systems, Procedures, Forms and Templates 2
W Advice on the best way to approach a double moving average using Minitab 15 Using Minitab Software 3
J Screw Thread Inspection Standards? Double Ended Stud Inspection Criteria Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
C Company has double identity - How do I state this in our QM (quality manual)? Quality Management System (QMS) Manuals 4
Marc Toyota vehicle recalls double in 2005 World News 1
D Unilateral / Bilateral Tolerances for dimensions with Double Plus or Minus Tolerance Statistical Analysis Tools, Techniques and SPC 12
J IVD sampling sizes for buyer Reliability Analysis - Predictions, Testing and Standards 0
C Sampling - ISO 16269-6 vs ISO 2859 Other ISO and International Standards and European Regulations 0
L Sampling Plan Risks AQL - Acceptable Quality Level 6
Q Sampling method for Distributor verification activities EU Medical Device Regulations 1
F Product audit sampling plans IATF 16949 - Automotive Quality Systems Standard 3
R Reduced sampling plan for sterial products APQP and PPAP 0
A ISO 2859-1 - 9.3.3.2 Switching score - Sampling Plans and PPM AQL - Acceptable Quality Level 0
R BS EN 12060:1998 - Zinc and zinc alloys Method of sampling Specifications Manufacturing and Related Processes 4
S High voltage testing - ISO 17025 - 7.2.2 Validation of methods and 7.3 Sampling ISO 17025 related Discussions 3
8 Activity Sampling Exercise Lean in Manufacturing and Service Industries 11
B AS9100D Sampling Plan AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
R Design verification for interim design outputs - sampling rationale ISO 13485:2016 - Medical Device Quality Management Systems 2
Nicole Desouza Sampling plan for a customer who wants AQL 1.0 (per ANSI Z1.4) AQL - Acceptable Quality Level 5
