DPM (Defects per Million) vs. DPMO (Defects per Million Opportunities)
optomist1
A Sea of Statistics
Hi To Everyone,
A generic question for the agile minds of Elsmar.....if you have a part say with 10 or 11 different dimensions/part, and whether one dimension or six dimensions are beyond the specification say +/- 0.01mm, the part is unacceptable.
Would you use DPM or DPMO? Seems like an obvious question yet in my experience; you use DPMO when you have a part or item that has a number of different attributes/part such a nicks, cracks, or surface not parallel etc. Or are different dimensions on the same part treated as different measures?
The DPM vs DPMO selection would certainly make a difference in assessing current performance.
Any insight would be welcome...
Thank You...
Marty
Re: DPM vs DPMO
In *my* opinion, DPM vs DPMO is a false issue that was brought up by the 'silly' part of Six Sigma.
The real question is: are you concerned with defects (Poisson) or defectives (Binomial) and what question are you trying to answer to with the data...
Use of the Poisson for defects obviates the need for accounting for the number of opportunities which is usually a non-value add task.
The critical understanding is that if you have a high enough defect rate, you can improve the defect rate without substantially improving the defective rate. SO, the choice is situational, based on the question and what action you are concerned with.
DISCLAIMER: I don't typically use ppm (or is dpm/dpmo cousins) unless I actually have millions of things AND the defect rate is so low that the number of leading zeros in the proportion is difficult to track. I also eschew percentages...
Re: DPM vs DPMO
I have a client that has one part with 32 different machining operations. So, each part would have 32 opportunities. However, their customer sees it as if one dimension is out of spec, the entire part would be rejected, so they measure as DPM, not DPMO. They don't really care about the opportunities, they care only about the part.
Taking that to an extreme. I have a part with 1 million dimensions. If one is off, and I send the part to the customer, and it gets rejected, they will say I have 1,000,000 DPM (since the only part I sent was defective), yet, my internals would show 1 DPMO. Quite a difference, but the only one that matters is what my customer grades me on.
optomist1
A Sea of Statistics
Re: DPM vs DPMO
Hi Bev,
Poisson or Binomial it depends on the situation....which makes this foundation of analysis question all the more important. Thank you for the insight, as one's choice strongly influences the analysis.
Regards,
Marty
optomist1
A Sea of Statistics
Hi db,
Your insight better states my point or concern; the metric changes depending on your perspective.
With this one crucial selection, you can drastically change the process performance measure. Sometimes it is a question of "how real" you want to be.
Thanks for your input...
Marty
K DPM (Defects Per Million) Opportunites - Help with examples Six Sigma 3
A Cpk Vs DPM (Defects Per Million {aka PPM}) Capability, Accuracy and Stability - Processes, Machines, etc. 3
Z Direct Part Marking (DPM) requirements for Class II Medical Devices Manufacturing and Related Processes 0
C Data Matrix and DPM (direct part marking) UDI Standards - ISO/IEC TR 29158 Other US Medical Device Regulations 2
B Relating DPM, Sigma Quality, and Centering Statistical Analysis Tools, Techniques and SPC 2
O Estimating the dpm and ppm of the process from Cp and Cpk Statistical Analysis Tools, Techniques and SPC 4
S +/-6 sigma (range 12) for 3.4 DPM - Explanation please Six Sigma 4
C What is the best way to do projection - CPM and DPM by end of this year Quality Tools, Improvement and Analysis 2
C DPM (Defective per million) calculation Six Sigma 8
Q Is DPM defective parts per million a form of Attribute Data Sampling? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
M Cp, Cpk, Dpm, or other? Diameter of a Hole - Non-Normal Distribution Capability, Accuracy and Stability - Processes, Machines, etc. 20
G Choosing a Sampling plan for Start Up Fabless IC Company - Guarantee a 200 DPM limit Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
S DPM (Defect parts per million opportunity) vs. PPM Statistical Analysis Tools, Techniques and SPC 3
A AQL - How to count samples with defects for each defect class AQL - Acceptable Quality Level 17
B IATF 16949 Cl. 8.6.6 - Acceptance Criteria - Zero Defects Attribute Data Sampling IATF 16949 - Automotive Quality Systems Standard 2
J Validating a stopped test due to never finding any defects Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
Q PPM - Filtering Defects out of calculation Quality Tools, Improvement and Analysis 5
R Classification of Major & Minor Defects AQL - Acceptable Quality Level 10
S Understanding, Analysis and Monitoring Quality Defects on Composite Components Statistical Analysis Tools, Techniques and SPC 3
K Is there any specific Standard on visual defects for extrusion and machined parts ? Quality Tools, Improvement and Analysis 6
P What are the causes of painting defects? Manufacturing and Related Processes 2
T Repeated Inspection - Probability of Visual Inspection catching Defects Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
T How many complaints, defects and non-conformances are typical? Customer Complaints 5
P Monitoring Production Defects - Three simple questions Six Sigma 3
S Are P-charts for a Particular Defect or can Different Defects be counted in one? Statistical Analysis Tools, Techniques and SPC 2
E Post Machining Casting Defects with MIL-STD-2175 Requirements - Responsibility Manufacturing and Related Processes 9
L What is the Cpk for Zero Defects Six Sigma 4
S Allowed Faults (Defects) on Plastic Parts Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
G Sample Size for 2900 ppm Visual Defects Inspection Requirement Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
T 10 CFR Part 21 - Reporting of Defects and Noncompliance Various Other Specifications, Standards, and related Requirements 6
Crusader "Defects" Visual Aid: To Control or To Not Control? Document Control Systems, Procedures, Forms and Templates 8
I Integrated Management System - Nonconforming Service/Product Defects ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
T Supplier Spray Process Audit - Fish Eye, Spray Dust and Fiber Dust Defects Manufacturing and Related Processes 8
I Cpk < 1.33 - How do I estimate actual defects? Statistical Analysis Tools, Techniques and SPC 7
R Suppliers Defects found during Production Process - Supplier Scorecards Quality Tools, Improvement and Analysis 6
N Causes of Disbond Defects in Composites Manufacturing Process Manufacturing and Related Processes 7
S Aluminum Castings Defects - Welding and what to Mark with Manufacturing and Related Processes 3
T Calculation of Sigma Level of Defects for a Manufacturing Process Statistical Analysis Tools, Techniques and SPC 8
Ron Rompen Looking for counter for my inspector to tally the number of defects discovered Manufacturing and Related Processes 3
B Tracking Defects - Help with Graphing Culprits from CAR's Quality Manager and Management Related Issues 6
B Effectiveness of 200% Visual Inspection to Identify Defects and Defectives Inspection, Prints (Drawings), Testing, Sampling and Related Topics 32
M AQL (Acceptable Quality Level) for Zero Defects AQL - Acceptable Quality Level 13
V Calculating Sigma Quality Level - Defects are more than evaluations Quality Tools, Improvement and Analysis 1
T Measuring Quality Performance of Distributors - Product defects Supplier Quality Assurance and other Supplier Issues 2
Chennaiite High Technology Visual Inspection for Casting and Forging Parts - Zero Defects Inspection, Prints (Drawings), Testing, Sampling and Related Topics 11
A Customer Quality Complaint - Visual Defects from cut-to-length shear Manufacturing and Related Processes 8
L Zoned Defect Chart - 9 zones with 12 possible defects Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
gard2372 Concentration Diagram of Product - Plotted defects over a picture of one of our parts Statistical Analysis Tools, Techniques and SPC 7
B Emirates Slams Airbus on A380 Defects World News 0
