DPPM (Defective Parts Per Million) Reporting - Large Quantity Approach
L
Lpitt56
We are looking at changing our DPPM metric and want to see how other companies are calculating this metric. Currently if a supplier provides a direct deliverable part we count that as one part (even if that part is made up of 40detail parts). We also count kits received as one part received. Then calculate DPPM based on parts rejected vs parts received.
However, we have many suppliers who provide us with a direct deliverable as mentioned above (one part made up of 40 or more detailed assemblies) and he still only gets credit for shipping one piece. We are looking at changing our method of to give credit to the supplier for all components parts shipped (i.e. credit the supplier with shipping 40 pieces when we recieve the one direct deliverable).
We feel this will be a more acurate and fair method, but we want to know what others are doing who might have the same situation.
Marc
Can anyone here help with this one? My Thanks in advance!
tomvehoski
Unless you are buying millions of these things, scrap the focus on number of parts/assemblies and focus on dollars. PPM is only useful if you are comparing the exact same (or very similar) items.
Vendor A:
Complex assembly. $10,000 each. 10 per year. One unit was rejected at receivieng, so their PPM is 100,000. Say they fix it the next day for free. You lose about $100 in time with the paperwork, CAR, phone calls, etc.
Vendor B:
Small components. $1 each. 100,000 per year. They run about 1% defective, which causes your assembly line to incur $10 of cost for rework for each instance. Their PPM is 100.
According to PPM, Vendor B is better - but they wasted 10 times more of your money and time.
L
Lpitt56
Thanks for the reply and yes I agree that dollars would be a better indicator. However, I am locked into a supplier rating software package that is mandated by our corporate office and my only option is possibly giving credit for more parts shipped. A good example of the situation I see is with kits received. We purchase a kit under one part number. The kit may contain as many as 40 parts but we receive it under one part number in the system. I do have the ability to credit the supplier with the total number of parts in a kit without messing up the receipts. We have the same situation with direct deliverables where a part is received that is made up of maybe 60 or more subassemblies. Currently the supplier get credit for shipping one part. The reason for my concern is that we have some very good suppliers that are showing a high DPPM when they are actually just not getting credit for all the good parts they ship. Before I make this change I want to see what other are doing that might be experiencing the same situation.
In either case can you use the one part number' (Kit or top level assembly) if one or more sub parts are bad? if no then stick with your current system.
This is about the suppliers effect on your business, not about being kind to them. I'm sure you pay more for the part number with multiple sub-assemblies and for kits than you do for single parts. The supplier knows what his responisbility when he signs the contract.
DPMO is only really useful (fair doesn't come into the question) when comparing relative final quality and improvement progress between disaprate products, lines or facilities and then ti really only serves to stave off the 'it's not fair whining' and focus the groups on the real goal which 'zero defects' or some other high quality level...
tomvehoski
If corporate only gave you a hammer, would you use it to torque a bolt to 30 lb-ft? Bad metrics (or tools) can be more dangerous than no metrics. I do sympathize with upper level mandates to fit a process to the wrong tool. I've been arguing with customers and our registrar as to why I won't put any effort into PPM since it does not work well in our batch manufacturing.
You could still code dollars as PPM. If a unit is $2 and you buy 100,000 - that is 200,000 opportunities. If issues cost you $500, your PPM = $500/$2K X 1M, or 2500 PPM.
L
Lpitt56
Thanks for the reply and input! I probably used the wrong terminolgy when I said "fair to the supplier". In actuality I want to make sure my attention is on the real problem suppliers. For example our system has some auto triggers that require I visit a supplier or in some cases de-source a supplier that can't get to a gold level we have set, when in reality they are not my problem supplier. In a perfect world I would fly to corporate and tell them to change metric to something more appropriate to my needs but I could also come back unemployeed. Our target is always zero defects and we communicate that relentlessly to our supplier base, but right now I am looking for a real-world workable solution.
G Definition DPPM - Defective Parts Per Million Calculation Formula Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 5
P How to measure DPPM in Chemical batch manufacturing Quality Tools, Improvement and Analysis 1
M Metric/Way to show how Internal DPPM and External DPPM relate to each other Nonconformance and Corrective Action 1
R DPPM? Scrap? Both? How to report Returns Misc. Quality Assurance and Business Systems Related Topics 6
J How to measure process quality? Is DPPM the correct metric? Capability, Accuracy and Stability - Processes, Machines, etc. 5
D DPPM - Calculating the Defect Rate of a Software Test Statistical Analysis Tools, Techniques and SPC 9
C What is the appropriate DPPM for to be used In-Process Inspection Other Medical Device Related Standards 2
Ajit Basrur Dashboard Software for representing Quality Metrics like DPPM, On Time Delivery, etc. Quality Tools, Improvement and Analysis 4
V Calculation of Cable Assembly DPPM Customer Complaints 6
C Calculate DPPM/PPM for second yield rework Quality Tools, Improvement and Analysis 1
L Is there any place for sampling plan if customer requirement is 20 DPPM Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
J Failures-in-time (FITs), DPPM and Probability Calculation Questions Reliability Analysis - Predictions, Testing and Standards 9
B DPPM - 'Standard' minimum quantity to measure DPPM? Statistical Analysis Tools, Techniques and SPC 21
A DPPM vs. PPM - What is its purpose and use? Quality Tools, Improvement and Analysis 1
Ajit Basrur Trending segregated for cosmetic and functional dppm? Automotive requirements Misc. Quality Assurance and Business Systems Related Topics 5
S Packaging Specification template and Reasonable dppm target for printed material? Document Control Systems, Procedures, Forms and Templates 1
Y Definition DPPM - Quality Indicator? Using DPPM instead of DPMO as our OQA quality indicator Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 4
K DPPM vs. AQL - What is the difference between DPPM and AQL? AQL - Acceptable Quality Level 17
R MTBF to DPPM Calculation Based on the Unit's Typical Working Hours Reliability Analysis - Predictions, Testing and Standards 9
G DPPM Industry Standard - Metal fabrication (Job shop) Misc. Quality Assurance and Business Systems Related Topics 3
M Minitab assistant: 1-Sample % Defective Test Using Minitab Software 1
L PPM - wrong parts or defective parts? IATF 16949 - Automotive Quality Systems Standard 18
R Question on determining defective units - I am not recording fixture to part rejected Statistical Analysis Tools, Techniques and SPC 5
C Serialised Defective Part Replacement EU Medical Device Regulations 4
M Level 3 PPAP submission of intentional defective parts APQP and PPAP 4
S Falsified documentation and defective product - Management gone mad Internal Auditing 37
Stijloor Inmate-Produced Combat Helmets Found Defective Supplier Quality Assurance and other Supplier Issues 4
G Calculating the Fraction Defective Confidence Interval for a Lot Statistical Analysis Tools, Techniques and SPC 2
M Sampling Level for Defective Units with a confidence level of ~95% Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
A Upper Confidence Level (3 sigma) for Proportion Defective Statistical Analysis Tools, Techniques and SPC 1
M Procedure for Handling Customer Return Part (Defective Part Return) IATF 16949 - Automotive Quality Systems Standard 1
M At what point should defective product be rejected? Manufacturing and Related Processes 11
M Supplier Defective Product Return and Corrective Actions. AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
R How to determine LTPD (lot tolerance percent defective) or RQL Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
R LTPD (Lot Tolerance Percent Defective) Sampling Plan with %Defect Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
S International Returns for Defective Materials Supplier Quality Assurance and other Supplier Issues 2
K Engineering Disposition on Defective Work Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
B Probability of finding a Defective Part - Probability question Statistical Analysis Tools, Techniques and SPC 8
S What is the proper flow to feedback the defective found during QA sampling check? Quality Tools, Improvement and Analysis 8
O LTPD (Lot Tolerance Percent Defective) Formula for Calculator Inspection, Prints (Drawings), Testing, Sampling and Related Topics 18
V AQL and small % defective AQL - Acceptable Quality Level 7
B Defective Product Cost - True Cost of Customer Rejects Misc. Quality Assurance and Business Systems Related Topics 2
0 Which sampling plan to use if 0.5% defective is known Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
P ImR and P chart comparison on % defective data Statistical Analysis Tools, Techniques and SPC 13
R Percent defective in Attribute GR&R (Gage R&R) General Measurement Device and Calibration Topics 3
C DPM (Defective per million) calculation Six Sigma 8
C Best Way to Measure Defective Area General Measurement Device and Calibration Topics 1
H Cost of Poor Quality (COPQ) - All returned/defective parts (plastic) are recycled Training - Internal, External, Online and Distance Learning 7
Q Is DPM defective parts per million a form of Attribute Data Sampling? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
Q Supplier Excuse: Sending Defective Unit to Catch Up Shipping Schedule Supplier Quality Assurance and other Supplier Issues 11
