Drawing tolerance vs. Measurement device
NRitacco
I'm struggling with what I understand to be a measurement standard and what our QC department is saying.
I have a drawing that dimensions a length to ±0.25mm. My question is (again, based on what I think is the correct approach), what instrument I use to measure this length has to be capable / repeatable to 1/10th of the tolerance (10:1 ratio). Is that 10:1 compared with the .25mm or the .01 decimal place?
Any help would be appreciated.
Thank you
The 10:1 "rule" is just a guideline of sorts, and other information is needed in order to determine the device to use. In your case, the tolerance range is 0.50mm (~.020"), so using the 10:1 ratio your gage should resolve to 0.05mm (.002"). Other factors to consider include the risk(s) of error near the tolerance limits, and the thing being measured (is it 20 feet long or 2 inches, e.g.).
NRitacco
Ahh, OK, so it is based on the tolerance range, in this case 0.50mm. OK, I was thinking I needed to account for the hundredth decimal place when considering a measurement device.
That helps. Thank you for the clarification.
Black Ships
As said above, QC is referring to 1/10 of the measurement range. This is a practical rule, born out of a simple intepretation of the calculation of uncertainty of measruement. If there are more variables affecting this uncertainty, a 1/10 precision would assure that the contribution of the instrument appreciation to the total uncertainty is 1% (1/10 squared). As Jim said, 1/4 would contribute 6%. (1/4*1/4). Again, this is a simple explanation of a complex subject!
C Thread Tolerance - Can I use a 3A Ring on a part that the drawing calls out for a 2A? Manufacturing and Related Processes 5
S Surface Profile of a Hole - The meaning of the tolerance in the provided drawing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
J Drawing Callout: "Holes must be in line" No Tolerance specified Inspection, Prints (Drawings), Testing, Sampling and Related Topics 12
G Geometric Tolerance - Swedish Drawing which states that all tolerances are to NS 1430 Manufacturing and Related Processes 2
K Drawing Tolerance What is the difference between ISO 2768-mH and ISO 2768-mK? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
B Tolerance on Thread Angle - Drawing calls for M4 external thread to BS3643 Various Other Specifications, Standards, and related Requirements 6
A Best Way to Tolerance a Cylindrical Section on a Part (Customer's Design and Drawing) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
QMMike Tolerance block on customer drawing - Major interpretation problem with customer Inspection, Prints (Drawings), Testing, Sampling and Related Topics 25
adztesla Medical device Drawing related change justification Other Medical Device Related Standards 0
T Drawing title block - approval history Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
S Defining special characteristics beyond customer drawing FMEA and Control Plans 11
V Would the customer drawing change necessitate re-PPAP of the Product? APQP and PPAP 3
S Drawing Requirements for Catalog Items (Class II Medical Device) US Food and Drug Administration (FDA) 3
M Customer Dimensions on Internal Drawing, all of them? IATF 16949 - Automotive Quality Systems Standard 3
8 Drawing Feature Question Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
H Prodigit DC Electronic Load - Drawing current but showed 0 on the screeen Manufacturing and Related Processes 0
J Drawing Example Request: Inspection Section Plane of Aluminum Casting Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
T CSE 5.01 reference on drawing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
2 GDT of datums - Putting Datum C on a drawing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
D Partial FAI - AS9102 - One single drawing has 10 part numbers AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
A Help with Drawing Review - ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
V Manufacturing without a Formal Drawing ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
V ISO 9001: 2015 Production drawing Control ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
D Engineering Drawing Review and Approval Requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
D GD&T Drawing Question - I have a drawing and it makes no sense to me whatsoever Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
Prashant G AS9100 Requirement - Verification of characteristics results with drawing requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 13
Q How do you interpret this dimension in my drawing Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
D Drawing (print) does not specify restrained or free state Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
A Drawing Issue with Supplier - xb file did not match that of the pdf drawing Nonconformance and Corrective Action 4
M Best Practice for setting tolerances on a Drawing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 14
M PCBA Drawing Best Practices IPC Class 3 ISO 13485:2016 - Medical Device Quality Management Systems 1
G Decimal places on Drawing (Print) Callouts Measurement Uncertainty (MU) 7
M True Position / GD&T - I'm staring at this drawing and I'm lost Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
I Engineering Drawing = Record or Document? Document Control Systems, Procedures, Forms and Templates 8
B Profile of a Surface Callout on this Drawing General Measurement Device and Calibration Topics 4
J Is there a specification that provides directions on Drawing Revision Changes Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
R Location Interpretation on Drawing - Hole to Hole? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
I Delta FAIR due to a Drawing Change AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
J Drawing Callout - Arrow pointing to an inner edge where there is a radius Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
M What is 'Loft' which is used in Boeing company to express 1/1 scale 2D drawing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
V Dimension marked with "frame" on 2D drawing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
A Measurement of a Radius on Drawing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
K Accounting for Drawing Notes in PPAP APQP and PPAP 1
I Drawing standard (VDA) - Drawings in 3 different status VDA Standards - Germany's Automotive Standards 4
T Engineering Drawings - Once a customer has signed off on an engineering drawing ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
C Use of white-out or obliterating a portion of a controlled drawing or document Document Control Systems, Procedures, Forms and Templates 7
L How to document use of wrong engineering drawing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 22
K Tolerances on Drawing Title Block Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
M 4 Datums Referenced in a Print (Drawing) Feature Control Frame Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
J Help with a Metric Drawing Callout Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
