Drug Device Submission: Is a Technical File required
H
Hrobot
I have moved on from a medical device environment to a autoinjector drug device environment which relates to drug submission rather than 510(k). This device falls under the medicinal drug directive.
My question is regarding
-if hazard analysis (identify hazard, clasification, risk control measures) is required at all,
- declaration of conformity is needed for EU,
- a separate technical file is needed for EU. (Conformance to Essential requriements is needed but does this have to sit in a technical file or can it sit in the submission document.
Thanks in advance for your input.
hrobot
bio_subbu
Hi Hrobot
I request you to verify your product Autoinjector is defined as a Medical Device if it complies with the definition of a Medical Device under the Medical Devices Directive (MDD) 93/42/EEC Article 1 Clause 2a.
“Medical Device: any instrument, apparatus, implement, machine, appliance, implant, in vitro reagent or calibrator, software, material, or other similar or related article, intended by the manufacturer to be used, alone or in combination, for human beings for one or more of the specific purpose(s) of
— diagnosis, prevention, monitoring, treatment, or alleviation of disease,
— diagnosis, monitoring, treatment, alleviation of, or compensation for an injury,
— investigation, replacement, modification, or support of the anatomy or of a physiological process,
— supporting or sustaining life,
— control of conception,
— disinfection of medical devices,
— providing information for medical purposes by means of in vitro examination of specimens derived from the human body, and which does not achieve its primary intended action in or on the human body by pharmacological, immunological, or metabolic means, but which may be assisted in its function by such means”
Therefore in order to be classified a medical device, a product must be intended to provide or assist with the diagnosis, monitoring, prevention or treatment of a medical condition. My guess is, your product Auto-injector /pen injector is a medical device. You need to have CE technical file and should have hazard analysis details, classification route, declaration of conformity and other information with respect to your product. You may want to submit the technical file to your notified body as a submission document.
For classification details, I would suggest you to refer MEDDEV 2.4/1 Rev 09- Classification of medical devices.
Regards
S. Subramaniam
H
Hrobot
In this case the device is a drug delivery device which is single use where the device part is the ancillary function. Therefore the applicable directive is the medicinal product directive. However the manufacturer still needs to prove that the device is designed based on the essential requirements of the MDD. The question is if this can be a standalone document or this needs to sit under a Technical File as it is for a medical device.
Thanks in advanced for the opinion.
depa1978
Hi everyone,
I re-open this discussion as it seems exactly the correct topic for my question:my client means to introduce on the European Market a drug and a device encapsulated together in a single product for single administration.
There isn't any interactions between them, and they are both registered as for what concern respective regulations. The device is going to monitor compliance and other physiological parameters of the patient.
The only thing is that now they are going to be administered together.
I am going mad trying to understand the correct regulatory strategy :bonk:
Anyone who already had similar experiences?
Thanks!!
Giovanni
chris1price
Hi
The first decision is whether the "device" falls under the MDD or not. If when sold the drug is combined with the device (eg prefilled syringe or inhaler), the whole product is classed as a drug and falls under the drug regulations. If the device is separate and can be reused (eg an empty syringe) then that part is a device and falls under the MDD. Take a look at Article 1, Para 3 of the MDD, there are also several EU and MHRA guidance documents that give more examples.
If the whole product falls under the drug regulations, then I believe you need the CTD files under ICH Quality Module 3. However that is now a whole different area.
Note, the requirements of Article 117 of the new MDR may make the process very different in future. I would start talking to a Notified Body now.
Chris
depa1978
Hi Chris, thanks.
In this case, the device is already registered as IIa device, and used (through ingestion) for monitoring of patient parameters.The drug has been registered many years ago.
Together in the same capsule there isn't any interaction (already tested) but the company would like to create this "kit" (maybe we couldn't define it a combination product) also to monitor the compliance related to the drug.
I know the new MDR will change the process, but I am a bit confused regarding the correct route as per the current MDD. Maybe anything to do?
chris1price
Hi, without knowing more detail, it is difficult to answer. My suggestion would be to contact your Notified Body for assistance.
N Is this a single integral drug device combination product EU MDR CE Marking (Conformité Européene) / CB Scheme 1
T Clinical trial - Medical device product not cleared (without FDA approval) in a drug trial Other US Medical Device Regulations 9
V Informational EMA - Quality requirements for drug-device combinations EU Medical Device Regulations 0
M Informational Health Canada – Drug and medical device highlights 2018: Helping you maintain and improve your health Medical Device and FDA Regulations and Standards News 1
K Release testing for Combination Drug-Medical Device Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 0
M FDA News USFDA Final Rule – Medical Device Classification Procedures: Incorporating Food and Drug Administration Safety and Innovation Act Procedures Medical Device and FDA Regulations and Standards News 0
V For a Drug-Device Combination Product, 'Design Control' Process is triggered at? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
A Russia- Medical device with drug registration Other Medical Device Regulations World-Wide 0
V Upgrading Systems from CFR 211 to CFR 820 (drug+device combination) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 7
D Risk Management for Drug-Device Combinations ISO 14971 - Medical Device Risk Management 1
E Operational Qualification of a Drug Box Coding Device in Production Other Medical Device and Orthopedic Related Topics 1
A Comparing US/FDA Drug Regulations against US/FDA Device Regulations US Food and Drug Administration (FDA) 3
S ANOVA and Test Method Validation for a Drug Delivery Device Statistical Analysis Tools, Techniques and SPC 4
S US FDA (Food and Drug Administration) Medical Device User Fees for 2013 Other US Medical Device Regulations 4
somashekar Fake Drug Identifier - Would this device be termed a Medical Device? Medical Information Technology, Medical Software and Health Informatics 5
Ajit Basrur FDA Guidance - Heparin for Drug and Medical Device Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 1
E Classification (Medical Device or Drug) of Blood Bag in Japan Japan Medical Device Regulations 6
bio_subbu European Medicines Agency Seeks Comments on Drug/device Consultation Process EU Medical Device Regulations 0
M Medical Device Makers - Louisiana Wholesale Drug Distribution Rules Various Other Specifications, Standards, and related Requirements 1
Y Draft FDA Guidance on "Presenting Risk Information in Prescription Drug and Device" US Food and Drug Administration (FDA) 1
B Drug Device combinations - Drug degradation and impurities Other Medical Device and Orthopedic Related Topics 2
O Experience with IMB as Competent Authority of Drug Device Combination Products? EU Medical Device Regulations 5
D CFR Title 14: Aeronautics and Space PART 120—DRUG AND ALCOHOL TESTING PROGRAM Federal Aviation Administration (FAA) Standards and Requirements 3
Q Legal Manufacturer OTC Drug Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 0
D CE Marked product considered a Drug in India Other Medical Device Regulations World-Wide 0
M Workplace Drug Testing in 2020 Misc. Quality Assurance and Business Systems Related Topics 9
D Requirement of Pharmacovigilance (Drug Safety) Risk Based Strategic and Tactical Audit Plan General Auditing Discussions 0
K Comparator drug with Japanese label use in Clinical trials? US Food and Drug Administration (FDA) 0
S Do we need to validate Software used in Drug discovery and development process? Qualification and Validation (including 21 CFR Part 11) 2
O Validation approach for a Photostability Chamber (used for fluid therapy and injectable drug products) Qualification and Validation (including 21 CFR Part 11) 1
M Informational MHRA Guidance – Recommendations from the independent Expert Advisory Group on the use of Paclitaxel Drug-Coated Balloons (DCBs) and Drug-Eluting Stent Medical Device and FDA Regulations and Standards News 0
D FDA filing guidance to add sterilization step for approved drug Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 8
S Should the primary drug containers be molded in ISO Class 7 clean room? Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 6
P Drug packaging / filling operations Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 8
P China drug packaging DMF China Medical Device Regulations 0
H Korea DMF (Drug Master File) Fees Various Other Specifications, Standards, and related Requirements 5
Y What Clinical Data is required for Drug Delivery System EU Medical Device Regulations 1
P DMF (Drug Master File) type V for Sterilization Processes for USFDA Submission Other US Medical Device Regulations 3
Y Shelf Life of Non-Sterile Disposable Drug Inhaler 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
V Design Controls for Combination Drug Product Manufacturer (ANDA) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
L Registration of an Imported Medical Drug in Turkey Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 1
R Holding time stability study of intermediates of drug substances US Food and Drug Administration (FDA) 2
S Korea - MFDS (South Korea Ministry of Food and Drug Safety) Contact? Other Medical Device Regulations World-Wide 4
J CFDA issues Guiding Opinions on Enhancing the Construction of Food and Drug Inspectio China Medical Device Regulations 1
S Can I view listed drug products on FDA website similar to listed medical devices? Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 4
B Environmental Monitoring for Biopharmaceutical Manufacturing of Bulk Drug Substances Other ISO and International Standards and European Regulations 1
R Drug Stability Data at the time of Filing US Food and Drug Administration (FDA) 3
Ajit Basrur FDA - Guidance for Industry - Generic Drug User Fee Amendments of 2012 - Q & A US Food and Drug Administration (FDA) 0
V Variations - Changes to Approved Dossiers - Drug Product US Food and Drug Administration (FDA) 0
Ajit Basrur Cancer drug prices may fall by up to 80% in India! Coffee Break and Water Cooler Discussions 1
