Duplicated Gauges want to reduce calibration
wayne.wilson7
After our latest Calibration run I have looked at the number of gauges we currently have to look at the cost of calibration, during this exercise I have noticed that we have sometimes 4 of the same size gauge i.e. m4 screw plug gauge.
What I was thinking of doing is actually only calibrating one of these gauges that will be kept for inspection use only and label the rest reference only. As long as the inspection is kept locked and is used for verification of the 1st off and in patrol inspections I believe I can almost cut the cost of calibration by 3/4's
Does anyone else run something similar?
Regards
Wayne
JoshuaFroud
I would be slightly careful with this, look at the cost saving of the calibrations vs the cost of the lost product if one of the reference gauges was to fail. Sometimes the cost of calibration can be a lot smaller than even a single failure.
Also depending on what quality system you run if any (9001 etc.) there may be a requirement for equipment used for product verification to be calibrated.
I personally would be surprised to find a gauge labelled as "reference only" for anything but minor un-recorded in-process checks that are not critical to product fit, form or function.
Another way to approach this would be, do you actually need all four of the gauges or are you over inspecting the material? Is the validation behind the process acceptable to conduct a lower frequency of verification allowing for the reduction in the number of gauges available?
Michael_M
One of the first things I did when I took over calibration was create the following 'rules':
1. Thread gages (ID and OD) remain in wax seal until used. Thread gages are all stored in the quality department and individually checked out to jobs.
2. If after 1 year, the gage is still sealed in wax, I extended the calibration by 1 year (I wrote this into our procedures). Note, if any part of the wax seal is broken/removed for any reason, this requires re-calibration. I also reviewed the usage history.
3. If after the 2nd year, the gage is still sealed in wax, I pull from service and place in Bond. Always maintaining the wax seal for both preventative damage and to indicate the device has not been used. I also reviewed the usage history.
This has worked well and we removed over 1/2 of our gages. This also allows us to use the gage years after being put into bond (yes, using a gage 5 years old was fairly recent) so long as we re-calibrate.
This is an on-going process so if we have gages that were used 5 years ago but are no longer used, we can catch it after a year. Yes, we do have to pay for the last calibration (that puts it in wax) but for AS9100/ISO9001 this is a requirement.
J Using ring gauges General Measurement Device and Calibration Topics 2
D Different limits for new and worn gauges General Measurement Device and Calibration Topics 2
G Calibration of "Master Parts" Used as Gauges Calibration Frequency (Interval) 5
I How many gauges in a Go/No Go Gauge? General Measurement Device and Calibration Topics 7
L Calibration of Plug Gauges - Tolerancing General Measurement Device and Calibration Topics 1
I Can we use pin gauges to measure an accurate Cpk ? Capability, Accuracy and Stability - Processes, Machines, etc. 9
S Acceptance criteria for gauges General Measurement Device and Calibration Topics 8
S ISO 5356-1 - 22 mm ring gauges and test laboratories for an Anesthetic connector Other Medical Device Related Standards 1
K Guard-banding and relaxed acceptance for dimensional gauges General Measurement Device and Calibration Topics 1
S GRR on ID with set of pin gauges Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
J IATF 16949 Cl. 7.1.5.2.1 - Gauges (Measuring Jigs) Calibration/Verification Records IATF 16949 - Automotive Quality Systems Standard 6
L Excel Template for Cgk Study wanted (Capability Gauges Study) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
B Calibration Status of Gauges for Training Only ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
G Sequence and Frequency of Calibration for Thread Gauges General Measurement Device and Calibration Topics 2
V How to Calibrate Ring Force Gauges Service Industry Specific Topics 1
N Calibration Method of Dial Thermometer Gauges General Measurement Device and Calibration Topics 7
E Do you need a Certification to Calibrate Gauges? General Measurement Device and Calibration Topics 2
E MSA of Attribute Gauges Signal Detection Method Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
K New Gauges calibration certificate shows deviations from the measurement uncertainty IATF 16949 - Automotive Quality Systems Standard 5
K Calibration Overdue on Customer-owned Gauges Calibration Frequency (Interval) 5
L TiN Coated Thread Plug Gauges General Measurement Device and Calibration Topics 12
P Is MSA needed once or once a year for Verniers, Micrometers, Gauges, etc? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
P Internal Calibration for Laser Temperature Gauges Manufacturing and Related Processes 3
S Offline Laboratory Scale Gauges for Min Max Diameter of Round Steel Bars General Measurement Device and Calibration Topics 6
N Calibration Certificate Requirements for Pressure Gauges General Measurement Device and Calibration Topics 9
S Colour Codes for Vacuum Gauges on Medical Devices? Other Medical Device and Orthopedic Related Topics 3
J Performing Internal Calibrations - Dial gauges, micrometers, height gauges, calipers General Measurement Device and Calibration Topics 8
D Ring Gauges P.D Formula using "Ball Rounded Teeth" General Measurement Device and Calibration Topics 13
S Calibrating Panel Mounted Pressure Gauges located on Hydraulic Test Stands General Measurement Device and Calibration Topics 3
0 Best way to evaluate the differences between 2 gauges Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
D Acceptance Of Gauges > 10% < 20% Tolerance Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
E Calibration of Calipers, Mics, Height gauges - Recommended Gage Block Types General Measurement Device and Calibration Topics 7
S Go/No-go Length Gauges - Length checking of beam assemblies General Measurement Device and Calibration Topics 2
D Two Gauges (Gages) - Two measurements correlation I do not know how to explain Reliability Analysis - Predictions, Testing and Standards 4
D Comparison of two gauges - Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 23
A Plug Gauge Size shows increase after use? Criteria for acceptance of the gauges? General Measurement Device and Calibration Topics 5
F Conical gauges (ISO 5356) how to use on PVC (soft part) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
B Method for Calibration of Thread Plug Gauges General Measurement Device and Calibration Topics 13
B Drunken Thread Inspection - Gauges for quick check for drunken threads General Measurement Device and Calibration Topics 3
Manix Do Gauges used for Maintenance of the Facilities Require Calibration IATF 16949 - Automotive Quality Systems Standard 5
C Does all gauges mean every gage? Manufacturing Engineering (Paragraph 7.6.2) IATF 16949 - Automotive Quality Systems Standard 10
G Accuracy class for gauges - Class 1,0 gauges - NS-5504 (Norwegian Standard) General Measurement Device and Calibration Topics 2
S New check gauges have strong chemical smell (TCE?) Occupational Health & Safety Management Standards 8
H Calibration of Measuring instrument, MRP gauges in machining General Measurement Device and Calibration Topics 2
V Calibration of Pin Gauges General Measurement Device and Calibration Topics 2
Z How To Calibrate Pressure Gauges On Line? General Measurement Device and Calibration Topics 9
Ron Rompen MSA to perform Linearity and Stability studies on Variable Gauges with Minitab Ver 15 Using Minitab Software 6
A When purchasing gauges does the OEM need to be accredited to 17025? ISO 17025 related Discussions 8
