During Gage R&R, is calculation of ndc value required?
K
Kim Yong Kil
Hello Cuve..
I have a question for Gage R&R...
In ISO/TS Audit, During the Gage R&R, If NDC(Number distinct categories) is not calculated and analysed for gage. Is it nonconformity?
I need your helps.....
Thanks..
Yong Kil said:
Hello Cuve..
Thanks..
Calculation of NDC isn't required by the standard, so the only way it could be an issue is if you have a customer requirement or an internal requirement for it.
Agreed. ndc is one metric of many to assess the suitability of the measurement system. As long as you are using the metric(s) appropriate to the decision that you make, you should be fine.
For example, you could legitimately get into trouble if you were using P/T ratio to make a decision on whether the gage was acceptable for use in process control (i.e., SPC) because P/T ratio is used to assess suitability for product acceptance (inspection) purposes.
Caster
An Early Cover
Look up, look wa-a-ay up
Yong Kil said:
Hello Cuve..
I need your helps.....Thanks..
Kim
Nonconformity - no? Needing more investigation, maybe.
Do people understand ndc? What are the results if they calculate it? How do they know this if they haven't calculated it?
Have they stopped looking if the GR&R is 20 to 30%, or did they do MSA. Bias Linearity, Stabillty.
The quote "Look up, look wa-a-ay up" comes from a childrens TV program in Canada from the 60s and 70s.
Don't let people lose sight of why they do things. Try to get them to "look up" from R&R requirements to really understand their measurement system.
http://archives.cbc.ca/days_to_remember/classic_7361_en.asp?prov=1-111-1288
K
Kim Yong Kil
This finding was issued NCR by our CB auditor..
Thank you for your useful comments..
But,, I confuse this situation...
During the surveillance audit, a CB auditor issued NCR for this matter..
The CB Auditor said " Regard to MSA 3rd edition, NDC values not calcualted and analysed for vernier calipers... You must be considered NDC of gage..."
What can i do for this matter???
The AIAG MSA manual is intended for reference; the customer and "the organization" set the actual requirements. The manual (page 77) gives "...a general rule of thumb..." in saying "...the number of distinct categories (ndc) the processs can be divided into...ought to be greater than or equal to 5."
A "general rule of thumb" is not a requirement, and "ought to be" is not the equivalent of "shall be." Unless there's a customer requirement for inclusion of NDC calculation, your auditor is out of bounds.
I agree. ndc is a supplemental metric intended to clarify or provide additional insight into the %GRR. It is not mandatory unless you have a documented customer requirement for it.
K
Kim Yong Kil
Thanks a lot...
I decided to change our CB....
Let me know recommended TS CB...
antoine.dias
ndc too low
When your ndc results are too low this can mean the following (amongst others) :
The samples you have taken do not represent the usual spread in your process. (It very often occurs people are taking 10 consecutive parts from the machine - which is very wrong for the study)
The second may be that your choice on measuring equipment was wrong. (It cannot recognise enough classes in the measuring results)
There may be several more reasons, but IMHO those are the most frequent.
In the direction of the " requirement " for ndc calculation :
In item 7.6.1 of ISO TS 16949 the following can be found:
The analytical methods and acceptance criteria used shall conform to those in customer reference manuals on measurement systems analysis.
Other analytical methods and acceptance criteria may be used if approved by the customer.
Unquote
If the MSA manual 3rd edition is the reference manual for a customer of subject company, IMO the auditor has the right to write a non conformity.
Best regards,
Antoine
Antoine,
There is no requirement for calculation of ndc in the MSA manual, as I pointed out earlier. There is a "general rule of thumb."
D Reducing Within Part Variation during a Gage R&R Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 26
G Attribute Gage R&R - Number of Samples - OFI during our TS-16949 surveillance audit Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 14
K Silver Plating corroding possible during SMT Manufacturing and Related Processes 10
B How many nonconformances have you received on average during IATF audits? General Auditing Discussions 24
Q Summative Usability Evaluation Testing: prior or during Clinical Investigation? Human Factors and Ergonomics in Engineering 6
M ECG lead leakage currents - How to specify ECG leads during electrical safety testing IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
M Disabling measurement data during fault conditions IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
B Oracle Cloud ERP Validation during Quarterly Patch ISO 13485:2016 - Medical Device Quality Management Systems 1
H Obligations as a contract manufacturer during an MDSAP audit ISO 13485:2016 - Medical Device Quality Management Systems 5
A OEM On-Site Calibration issues during Covid19 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
silentmonkey How to decide what characteristics need to be verified during incoming inspection? ISO 13485:2016 - Medical Device Quality Management Systems 5
C Documentation hold during submissions? ISO 13485:2016 - Medical Device Quality Management Systems 0
C 21 CFR 803 malfunction detected during packaging - report? Other US Medical Device Regulations 1
L Open Positions During AS9100 Audit AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
L Internal audit during COVID-19 restrictions ISO 13485:2016 - Medical Device Quality Management Systems 5
S Heat Sealers Upper and lower limit setting during OQ for Heat Sealer Qualification and Validation (including 21 CFR Part 11) 0
John Broomfield Guidance on Safe Working During Covid-19 Pandemic Misc. Quality Assurance and Business Systems Related Topics 5
Stefan Mundt AS9100D Major nonconformity due to recurrence of a NC during a subsequent CB audit. AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
K Things to learn during lockdown.... Safety-related books/articles/threads Book, Video, Blog and Web Site Reviews and Recommendations 2
S Is there a standard for sample size during R&D phase Other ISO and International Standards and European Regulations 18
Randy Remote auditing (for disaster, disease, disturbance etc...) during the Neo Coronavirus Pandemic and Social Distancing Registrars and Notified Bodies 7
K Analysis variation among the lots during cpk calculation. Design and Development of Products and Processes 1
G Question about Non-conformances during New Product Introduction Nonconformance and Corrective Action 14
G Is it common to do a repeatability check during calibration of an instrument? General Measurement Device and Calibration Topics 5
E Received a Major finding during IATF Surveillance audit for loss of BIQS Level 3 (more than 6 SPPS in 6 months)...how should we address SYSTEMIC CA? IATF 16949 - Automotive Quality Systems Standard 11
F Bayes Success run Theorem for sample size during OQ&PQ Qualification and Validation (including 21 CFR Part 11) 4
R What happens during a Stage 1 MDSAP audit? ISO 13485:2016 - Medical Device Quality Management Systems 4
M Informational US FDA – URGENT/11 Cybersecurity Vulnerabilities in a Widely-Used Third-Party Software Component May Introduce Risks During Use of Certain Medical Dev Medical Device and FDA Regulations and Standards News 0
A Microbial exposure during use - Requirement 11.1(c) EU Medical Device Regulations 1
GreatNate What to expect during an ISO 9001 audit Manufacturing and Related Processes 42
B Evaluation of Basic Safety during EMC Immunity or Climate Testing IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
G Non Conformance During ISO 9001 Audit - Not All Internal Audits Completed General Auditing Discussions 19
S Change value of target during a batch Capability, Accuracy and Stability - Processes, Machines, etc. 0
D Electrical Safety During Medical Device Development IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
S How to consider the relevant standards during development of ISO13482:2016 for IVD manufacturing Blood grouping Other Medical Device Related Standards 6
M Informational Draft ANSM’S GUIDELINE Cybersecurity of medical devices integrating software during their life cycle Medical Device and FDA Regulations and Standards News 0
A How to manage the QMS system and SOP during the transition from MDD to MDR EU Medical Device Regulations 4
M MDR Annex IX Chapter I, 2.2 (c) - Device identification procedures during manufacture. EU Medical Device Regulations 1
B How to reply NCR on ineffectiveness of corrective action during IATF external audit? This is repeated issue whereby some mistake was done. IATF 16949 - Automotive Quality Systems Standard 7
R Major nonformance finding was given during a closing meeting of a ISO9001 certification audit General Auditing Discussions 76
P NCMRs on in-proccess rejections - Products that fail during assembly ISO 13485:2016 - Medical Device Quality Management Systems 2
A Doubt on multiple inspection carrying out for same balloon number during Stage Inspection and Final Inspection? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
V System suitability or stability during continuous usage Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
A Determining the Scope of the QMS during Stage 1? Registrars and Notified Bodies 11
G How many samples you require to test during PQ for validation of a equipment? ISO 13485:2016 - Medical Device Quality Management Systems 1
I Quality of Potable Water Testing Parameters during Purified Water Validation Qualification and Validation (including 21 CFR Part 11) 1
S Document Handling during an Audit General Auditing Discussions 6
T Is 510k Anesthesia group particularly picky/difficult to work with during 510k? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
A Scheduled during our company's inventory activity - ISO 9001 audit question ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
A ISO/IEC 27001 - Issue during implementation of system IEC 27001 - Information Security Management Systems (ISMS) 3
