Early Research & Development - ISO 13485:2003 requirements Clarification
  • Thread starter TempusVernumProcella
  • Start date
This may appear idiotic to anyone else, and mayhaps it's because I'm thinking about it too hard. Regardless, I'm going to ask...
To set the stage- We are an ISO 13485:2003-compliant in-vitro medical device manufacturer; I am currently conducting an internal (first-person) audit of our Research & Design/Development Department. Our R&D department isn't exactly on top of filling/filing the appropriate transitional process of our QMS R&D bureaucracy.
My question is:IF R&D has projects that only exist on "scratch paper" (so to speak) that the status is investigatory and zero physical experimentation/prototypes have occurred, is it a CAR or PAR if their QMS-controlled documents are not filled out?:confused:
Welcome to suggestions!
Thank you:bonk:
Reg Morrison
Re: R&D 13485:2003 Clarification...
ISO 13485:2003 has ZERO requirements associated with the product research process, which is different and distinct from product design and development.
So, if you are conducting an internal audit which objective is to ascertain the level of compliance of the QMS against ISO 13485, if you are bugging the people performing pure research, you are auditing out of the scope of the standard.
Thank you. Sometimes it helps just bouncing ideas/thoughts around.
John Broomfield
Tempus,
A nonconformity is a failure to meet requirements. You've not provided any evidence of a failure to meet a requirement.
Once you have a nonconformity it is too late for a PAR.
Once you have a nonconformity it may not be worthy of a CAR to remove its root causes. It may simply need correction.
Lastly, when auditing try asking the person monitoring conformity of the process (per 8.2.3) what they plan to do to correct a nonconforming process instead of assuming the role of supervisor.
That way you can keep your independence while reinforcing the process monitoring which should happen long before your audit.
John
Tempus,
We do have QMS-controlled documents/guides for the R&D team that oft are undone or not completed. They track accurate notes and retain appropriate information on their own but are, simply, not filling out the necessary documentation as it applies to our QMS process. They have received a 'ding' on this account before, last year in fact. The CA then was to retrain R&D team and implement the necessary QMS documents upon the next official R&D review meeting per that project... Only, an official review of the project in conversation has not since been conducted.
So, knowing this, it seems a PAR may be the best option here.
Marcelo
ISO 13485 does not have "explicit" requirements for R&D, but that does not mean that the organization can?t include their own set of requirements and thus this would be part of the ISO 13485 QMS anyway.
L
Laura Halper
Tempus,
As has been mentioned, from what your describe, these R&D activities fall into the "pure research" area and are not covered by ISO 13485. You said that the researchers track accurate notes and retain appropriate information. This tells me that they have their own system (outside of the QMS documentation) that works well for them.
My suggestion is to enlist their help to simply describe their current system in the QMS. That way they don't have to do anything differently and you will have captured their process on paper. They probably feel (and maybe rightly so) that filling out the QMS documentation is not adding value to their research activities. Since ISO 13485 doesn't require them to, and since their system apparently works for them, why try to force them to change?
Maybe this perspective will help.
somashekar
:applause: ... :applause:
Any QMS including the ISO 13485 does not curb or restrict the scientific and research process. This will rather channelize the hard work put into the research when it gets into design and development phase for trials and manufacturing. As an output from the research one certainly can have all design inputs and design outputs which then feeds the verification / validation activities. It can at best make the D&D process as smooth as possible.
Systematic approach must not be confused with restriction of innovative approach.
Tempus, you have asked a fantastic question, that many here will benefit from.
Leave them alone. Do not audit them. Let them know how their brainy work can give great leads to D&D process. :bigwave:
John Broomfield
Tempus,
I've highlighted your words that indicate to me that you are trying to impose your will on your R&D team instead of listening to them.
I agree with Laura's advice on this in #7 and Somashekar's in #8.
To whom does the QMS belong? How is the QMS fulfilling the needs of the R&D team. To paraphrase Edision, many R&D failures may be necessary for their eventual success.
They may already realize the importance recording what does not work but see the recording methods mandated by your QMS as unhelpful.
Lastly, periodic multidisciplinary design reviews for resulting in effective design output may not be appropriate to the sand-box or skunk works activities at the front-end of truly innovative R&D.
John
Thank you, Somashekar! By no means does our QMS aim to enclose or bind the productivity of R&D and their incredibly hard work. We simply have it in our group of company processes to be audited annually and within those processes are QMS-regulated documents that ought be filled out by the R&D... but aren't. So, to remedy this, I will coordinate with them further on restructuring the process to better-suit their needs. :read::cfingers:
:thanks: EVERYONE, for your inputs!
J EDMS for Very Early Drug Development (Research/Drug Discovery) Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 4
P IEC 62304:2006 A1:2015 - Software from the early 1990s IEC 62304 - Medical Device Software Life Cycle Processes 4
M Informational FDA Panel: Too early to pull textured breast implants over cancer risk, need more data Medical Device and FDA Regulations and Standards News 0
Sidney Vianna Interesting Discussion World wide energy demand will peak in the early 2030's Sustainability, Green Initiatives and Ecology 0
Q Is EN 55011:2009+A1:2010 is expiring in early 2019? Other ISO and International Standards and European Regulations 1
Marc Air Pollution in the Early 21st Century Coffee Break and Water Cooler Discussions 5
S Final FDA Guidance on IDEs for Early Feasibility Clinical Studies - 2013 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
B Best Attribute Data Sampling Plan - Early Production Containment Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
K Tips 'n Tricks for getting a Job in the early 21st Century Career and Occupation Discussions 1
Q Reduced Device License Fee was rejected for being sent in too early Canada Medical Device Regulations 2
G ISO/DIS 14045 - Anyone have an early draft copy? Miscellaneous Environmental Standards and EMS Related Discussions 2
V Evidence for Preventive Action & Early Warning Vigilance procedure Preventive Action and Continuous Improvement 4
J Today it's 'Leave The Office Early' Day Career and Occupation Discussions 2
P Early versus Late delivery from suppliers - what's the acceptable ratio? Quality Tools, Improvement and Analysis 6
Stijloor ASQ Membership Renewal Request Comes Early - Will you renew?? ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 35
M Risk Management - AS9100 revision C - Early advice please! AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
A Juran is dead - Why the thread is closed so early? Philosophy, Gurus, Innovation and Evolution 2
Jim Wynne Never believe early news reports Coffee Break and Water Cooler Discussions 7
Marc When Flying, How early do you get to the airport? Travel - Hotels, Motels, Planes and Trains 25
Q Early Spring Cleaning - Finding Old Documents and Specifications ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
B Retiring Early or Never? Coffee Break and Water Cooler Discussions 65
T "Creative" ways to handle Early Production Containment Misc. Quality Assurance and Business Systems Related Topics 9
Marc GM in early talks to buy Chrysler World News 6
C Graph Choice For Monitoring DOA's (Dead On Arrival) and ELF's (Early Life Failures) Statistical Analysis Tools, Techniques and SPC 5
T AS9003 becoming obsolete as early as 2008??? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
D An Early Brush with Design of Experiments Design and Development of Products and Processes 7
M Aspect Indentification? Early stages of ISO 14001 implementation ISO 14001:2015 Specific Discussions 4
C Reasons for early termination of an audit? General Auditing Discussions 23
J GM's GP-12 Early Production Containment applicable to Tier 2 Suppliers? Customer and Company Specific Requirements 14
Marc BP Meets ISO 14001 Targets 8 Years Early Miscellaneous Environmental Standards and EMS Related Discussions 5
Marc Containment FMEA and GP-12 (GM procedure for early production containment) FMEA and Control Plans 9
Marc The Future of Quality - An Early Discussion Philosophy, Gurus, Innovation and Evolution 11
D Question on equipment - when to use reference only or research only stickers ISO 13485:2016 - Medical Device Quality Management Systems 5
L Clinical research - Request from ANVISA ISO 14971 - Medical Device Risk Management 1
Watchcat Authoritative References about the Research Question? Quality Tools, Improvement and Analysis 0
A VDmax25 and cGMP requirements for "research use only" products Other Medical Device Related Standards 1
M Risk Classification For Supplier - Clinical Research Organisation (CRO) Supply Chain Security Management Systems 3
M Exemption Clauses for Research, Demonstration, etc. Other Medical Device Regulations World-Wide 2
N Time source for paper-based documentation (research nurses) US Food and Drug Administration (FDA) 1
M Medical Device News CDRH Research Programs – VICTRE: Virtual Imaging Clinical Trials for Regulatory Evaluation Medical Device and FDA Regulations and Standards News 0
S Medical Device Research Use Only (RUO) label Other Medical Device Regulations World-Wide 4
M Acceptance of remote auditing techniques - Can you help me with my research? General Auditing Discussions 0
N Dataset for Academic Research - Infusion pump flow IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
T Research Medical Device EU - Requirements and Regulations EU Medical Device Regulations 13
Y Change Management in a very complex Research Organization Misc. Quality Assurance and Business Systems Related Topics 3
L EU MDR CRO (Contract Research Organization) requirements for Clinical Investigations EU Medical Device Regulations 1
T Control of R&D (Research and Development) Parts and Equipment ISO 13485:2016 - Medical Device Quality Management Systems 3
I AS9100D - Interview Request - I'm doing research Misc. Quality Assurance and Business Systems Related Topics 1
I Design & Development, Research and Innovation in the Medical Device framework ISO 13485:2016 - Medical Device Quality Management Systems 3
R University Research Project - Management Review Management Review Meetings and related Processes 17
