EASA Easy Access Rules for Continuing Airworthiness - June 2017
AEOS_QA
EASA has jut released a set of consolidated regulations that might be helpful to visitors.
It is a handy online resource that shows the current amended rules, and for each 145 regulation the Acceptable Methods of Compliance and Guidance material.
There is also a good set of guidance material on their page for Foreign Part 145 organisation
R UK Compliance monitoring (Auditing) of EASA/CAA Regulations 1321/2014 & 748/2012 EASA and JAA Aviation Standards and Requirements 0
W Difference between Appliances and Parts according EASA EASA and JAA Aviation Standards and Requirements 0
F EASA - POA & Part21G EASA and JAA Aviation Standards and Requirements 0
B Managed Certification Projects FAA vs EASA EASA and JAA Aviation Standards and Requirements 0
R EASA Form1 - Block 10 EASA and JAA Aviation Standards and Requirements 1
A Domain of the component (EASA CM No.: CM-SWCEH-001 Issue 01 Revision 02) Point 9.3.3 (Usage domain aspects) EASA and JAA Aviation Standards and Requirements 0
L What is the very first step to prepare for applying EASA POA? EASA and JAA Aviation Standards and Requirements 1
S C of C release with accompanying EASA Form 1 for EASA Part 145 EASA and JAA Aviation Standards and Requirements 0
S Adding Value prior to signing EASA Form 1 EASA and JAA Aviation Standards and Requirements 5
S EASA Part 145 - The difference between non-certifying staff and Certifying staff Federal Aviation Administration (FAA) Standards and Requirements 2
J MAG 6 and EASA Part-145 Issue 005. EASA and JAA Aviation Standards and Requirements 0
M Transport Canada - EASA Part 145 (Bilateral) EASA and JAA Aviation Standards and Requirements 0
S Calibration and Verification requirement for foreign EASA Part 145 EASA and JAA Aviation Standards and Requirements 7
T Block 11 of the EASA FORM 1 EASA and JAA Aviation Standards and Requirements 2
T EASA P 145: What mandatory information should on the purchase order of the customer ? EASA and JAA Aviation Standards and Requirements 2
M Can an organisation hold an EASA Part 145 approval WITHOUT a QMS EASA and JAA Aviation Standards and Requirements 1
A Microcontroller: Discussion about EASA CM - SWCEH - 001 EASA and JAA Aviation Standards and Requirements 1
P Is it possible to receive EASA STC within 48 hours after modification? EASA and JAA Aviation Standards and Requirements 1
P EASA STC (Supplemental Type Certificate) on a Pre-mod FAA STC Configuration EASA and JAA Aviation Standards and Requirements 1
T EASA TAG Block 11 Status/Work issue Quality Manager and Management Related Issues 1
D How to receive EASA approval for removing of engine QEC Kit EASA and JAA Aviation Standards and Requirements 1
G BCARs/EASA to ISO9001/AS9100 cross reference matrix/table wanted EASA and JAA Aviation Standards and Requirements 1
H POA procedure and EASA Form 1 Release EASA and JAA Aviation Standards and Requirements 2
M A Question on EASA's "Release and Acceptance of Components" EASA and JAA Aviation Standards and Requirements 2
I Meeting AS9100, FAA, Transport Canada, EASA Training Requirements - Vent/Rant Coffee Break and Water Cooler Discussions 2
A EASA Part 21G approval for manufacturing of seat covers, carpets, curtains & others EASA and JAA Aviation Standards and Requirements 1
C Example of Man Hours Plan required by EASA EASA and JAA Aviation Standards and Requirements 2
J EASA DOA Certification/Design Activities in India EASA and JAA Aviation Standards and Requirements 2
D EASA Form 1 Requirements for Serviceable Parts from Unserviceable Engine EASA and JAA Aviation Standards and Requirements 2
J Maintenance Man Hour Plan which satisfies EASA Part 145.A.30 (example needed) EASA and JAA Aviation Standards and Requirements 4
S EASA Part M Internal Audit Check List Internal Auditing 2
I Advice Needed For EASA Approved Aircraft Mod EASA and JAA Aviation Standards and Requirements 1
X EASA Part 145 / FAA Bilateral Agreement vs. Manufacturing under EASA Part 21 EASA and JAA Aviation Standards and Requirements 2
P The use of multiple EASA FORM 1 for Multiple Assemblies EASA and JAA Aviation Standards and Requirements 2
A EASA Certification Acceptance - The Russian equivalent of EASA Part 145 (Maintenance) EASA and JAA Aviation Standards and Requirements 2
W How to write an EASA 145 Quality Manual EASA and JAA Aviation Standards and Requirements 3
JoCam EASA Regulatory Requirements for Electronics Contract Manufacturer AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
P Non EASA Aircraft - What is meant by Non EASA Aircraft? EASA and JAA Aviation Standards and Requirements 4
C What are these EASA Acronyms? EASA and JAA Aviation Standards and Requirements 9
C EASA Part 145 Audit Programme example wanted EASA and JAA Aviation Standards and Requirements 6
B Military / Police / EASA Regulations and Requirements EASA and JAA Aviation Standards and Requirements 4
P EASA 145 (145.A.30) Man Hour Plan for Quality Monitoring EASA and JAA Aviation Standards and Requirements 2
K Guidance on Preparation for EASA Certification wanted EASA and JAA Aviation Standards and Requirements 4
H Maintenance Activities in an EASA 145 Facility EASA and JAA Aviation Standards and Requirements 2
P EASA DOA and ETSO (European Technical Standard Order) EASA and JAA Aviation Standards and Requirements 4
A What is "EASA" and "Competent Authority"? EASA and JAA Aviation Standards and Requirements 5
A FAA 8130-3 Approval acceptance by EASA DOA EASA and JAA Aviation Standards and Requirements 4
A Can an EASA approved MRO release (EASA release) a non EASA registered Aircraft? EASA and JAA Aviation Standards and Requirements 2
C New Guidance for FAA 145's with EASA Authority Federal Aviation Administration (FAA) Standards and Requirements 4
