EASA Form 1 Requirements for Serviceable Parts from Unserviceable Engine
davor_k
I would like to ask what are the conditions of issue EASA Form 1 for parts removed as serviceable from unserviceable engine which is off wing? Of course the removed parts weren't the root cause of engine failure. What details should be known and what tests/ inspections need to be done to treat the parts as serviceable?
I would like to add that my company don't have C category approval for CMM tests for parts to be removed from engine.
Thank you for help in advance.
AEOS_QA
Hi Davor
Typically a EASA Form 1 can only be issued by appropriately rated organisation for components that have been removed from a EASA member state registered aircraft.
Check out EASA Part 145 AMC No 2 to 145.A.50(d) Certification of maintenance
especially Point 2.6 Used aircraft components removed from a serviceable aircraft.
Hope that helps
S C of C release with accompanying EASA Form 1 for EASA Part 145 EASA and JAA Aviation Standards and Requirements 0
S Adding Value prior to signing EASA Form 1 EASA and JAA Aviation Standards and Requirements 5
T Block 11 of the EASA FORM 1 EASA and JAA Aviation Standards and Requirements 2
H POA procedure and EASA Form 1 Release EASA and JAA Aviation Standards and Requirements 2
P The use of multiple EASA FORM 1 for Multiple Assemblies EASA and JAA Aviation Standards and Requirements 2
S ETSO, TSO and EASA Form 1 - Do I need the ETSO approval for the installation? EASA and JAA Aviation Standards and Requirements 3
H FAA Operator - Acceptance of EASA Form 1 for Repaired Parts EASA and JAA Aviation Standards and Requirements 5
Q EASA (European Aviation Safety Agency) Form #9 Check List Federal Aviation Administration (FAA) Standards and Requirements 9
C Form 1 EASA / Form 8130-3 tag - light aircraft with registration N EASA and JAA Aviation Standards and Requirements 5
M EASA FORM 1 and 8130-3 - EASA Pt 21 Subpart G POA - FAA EASA and JAA Aviation Standards and Requirements 8
R EASA Form1 - Block 10 EASA and JAA Aviation Standards and Requirements 0
A Domain of the component (EASA CM No.: CM-SWCEH-001 Issue 01 Revision 02) Point 9.3.3 (Usage domain aspects) EASA and JAA Aviation Standards and Requirements 0
L What is the very first step to prepare for applying EASA POA? EASA and JAA Aviation Standards and Requirements 1
S EASA Part 145 - The difference between non-certifying staff and Certifying staff Federal Aviation Administration (FAA) Standards and Requirements 2
J MAG 6 and EASA Part-145 Issue 005. EASA and JAA Aviation Standards and Requirements 0
M Transport Canada - EASA Part 145 (Bilateral) EASA and JAA Aviation Standards and Requirements 0
S Calibration and Verification requirement for foreign EASA Part 145 EASA and JAA Aviation Standards and Requirements 7
A EASA Easy Access Rules for Continuing Airworthiness - June 2017 EASA and JAA Aviation Standards and Requirements 0
T EASA P 145: What mandatory information should on the purchase order of the customer ? EASA and JAA Aviation Standards and Requirements 2
M Can an organisation hold an EASA Part 145 approval WITHOUT a QMS EASA and JAA Aviation Standards and Requirements 1
A Microcontroller: Discussion about EASA CM - SWCEH - 001 EASA and JAA Aviation Standards and Requirements 1
P Is it possible to receive EASA STC within 48 hours after modification? EASA and JAA Aviation Standards and Requirements 1
P EASA STC (Supplemental Type Certificate) on a Pre-mod FAA STC Configuration EASA and JAA Aviation Standards and Requirements 1
T EASA TAG Block 11 Status/Work issue Quality Manager and Management Related Issues 1
D How to receive EASA approval for removing of engine QEC Kit EASA and JAA Aviation Standards and Requirements 1
G BCARs/EASA to ISO9001/AS9100 cross reference matrix/table wanted EASA and JAA Aviation Standards and Requirements 1
M A Question on EASA's "Release and Acceptance of Components" EASA and JAA Aviation Standards and Requirements 2
I Meeting AS9100, FAA, Transport Canada, EASA Training Requirements - Vent/Rant Coffee Break and Water Cooler Discussions 2
A EASA Part 21G approval for manufacturing of seat covers, carpets, curtains & others EASA and JAA Aviation Standards and Requirements 1
C Example of Man Hours Plan required by EASA EASA and JAA Aviation Standards and Requirements 2
J EASA DOA Certification/Design Activities in India EASA and JAA Aviation Standards and Requirements 2
J Maintenance Man Hour Plan which satisfies EASA Part 145.A.30 (example needed) EASA and JAA Aviation Standards and Requirements 4
S EASA Part M Internal Audit Check List Internal Auditing 2
I Advice Needed For EASA Approved Aircraft Mod EASA and JAA Aviation Standards and Requirements 1
X EASA Part 145 / FAA Bilateral Agreement vs. Manufacturing under EASA Part 21 EASA and JAA Aviation Standards and Requirements 2
A EASA Certification Acceptance - The Russian equivalent of EASA Part 145 (Maintenance) EASA and JAA Aviation Standards and Requirements 2
W How to write an EASA 145 Quality Manual EASA and JAA Aviation Standards and Requirements 3
JoCam EASA Regulatory Requirements for Electronics Contract Manufacturer AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
P Non EASA Aircraft - What is meant by Non EASA Aircraft? EASA and JAA Aviation Standards and Requirements 4
C What are these EASA Acronyms? EASA and JAA Aviation Standards and Requirements 9
C EASA Part 145 Audit Programme example wanted EASA and JAA Aviation Standards and Requirements 6
B Military / Police / EASA Regulations and Requirements EASA and JAA Aviation Standards and Requirements 4
P EASA 145 (145.A.30) Man Hour Plan for Quality Monitoring EASA and JAA Aviation Standards and Requirements 2
K Guidance on Preparation for EASA Certification wanted EASA and JAA Aviation Standards and Requirements 4
H Maintenance Activities in an EASA 145 Facility EASA and JAA Aviation Standards and Requirements 2
P EASA DOA and ETSO (European Technical Standard Order) EASA and JAA Aviation Standards and Requirements 4
A What is "EASA" and "Competent Authority"? EASA and JAA Aviation Standards and Requirements 5
A FAA 8130-3 Approval acceptance by EASA DOA EASA and JAA Aviation Standards and Requirements 4
A Can an EASA approved MRO release (EASA release) a non EASA registered Aircraft? EASA and JAA Aviation Standards and Requirements 2
