EASA Part 145 / FAA Bilateral Agreement vs. Manufacturing under EASA Part 21
X
XL189
I have found the Maintenance Annex Guidance (MAG) which appears to apply to EASA Part 145 for the EASA/FAA bilateral agreement, is there a similar document that applies to manufacturing under EASA Part 21 subpart G?
AEOS_QA
I am not sure if there is such an agreement for design and manufacturing as new Parts designed and manufacturerd by some EASA and FAA are usually universally accepted.
Maintenance approvals are not automatically and universally accepted and the MAG which forms part of some bilateral agreements cover all the conditions applicable to the acceptance of approvals and dual certification of repaired items between different regulators.
If you can indicate what type of parts you manufacture and what certifications you require there might be other members of the forum that can help with specific advice.
Some links that may help. note that there seem to be a number of changes between the EASA/FAA agreements in the last two of month.
http://www.faa.gov/aircraft/draft_docs/media/airAC21XX.pdf
http://www.faa.gov/aircraft/air_cert/international/easa/media/EASA_FAQ.pdf
http://www.faa-aircraft-certification.com/support-files/ac_21_23.pdf
S C of C release with accompanying EASA Form 1 for EASA Part 145 EASA and JAA Aviation Standards and Requirements 0
S EASA Part 145 - The difference between non-certifying staff and Certifying staff Federal Aviation Administration (FAA) Standards and Requirements 2
J MAG 6 and EASA Part-145 Issue 005. EASA and JAA Aviation Standards and Requirements 0
M Transport Canada - EASA Part 145 (Bilateral) EASA and JAA Aviation Standards and Requirements 0
S Calibration and Verification requirement for foreign EASA Part 145 EASA and JAA Aviation Standards and Requirements 7
M Can an organisation hold an EASA Part 145 approval WITHOUT a QMS EASA and JAA Aviation Standards and Requirements 1
J Maintenance Man Hour Plan which satisfies EASA Part 145.A.30 (example needed) EASA and JAA Aviation Standards and Requirements 4
A EASA Certification Acceptance - The Russian equivalent of EASA Part 145 (Maintenance) EASA and JAA Aviation Standards and Requirements 2
C EASA Part 145 Audit Programme example wanted EASA and JAA Aviation Standards and Requirements 6
P Cleaning of Seat Covers under EASA Part 145 EASA and JAA Aviation Standards and Requirements 3
A FAR Part 21/145 vs. EASA Part 21/145 EASA and JAA Aviation Standards and Requirements 5
A EASA Part 21G approval for manufacturing of seat covers, carpets, curtains & others EASA and JAA Aviation Standards and Requirements 1
S EASA Part M Internal Audit Check List Internal Auditing 2
L Do I need to use an EASA Part 21 approval, to upload software on a Transport Category EASA and JAA Aviation Standards and Requirements 2
D Part 21-J & G or ETSO or ESTC (jungle of EASA rules) EASA and JAA Aviation Standards and Requirements 3
L Getting the EASA Part 21 J - DOA Certification EASA and JAA Aviation Standards and Requirements 5
E EASA Part 21 Internal Audit Checklist EASA and JAA Aviation Standards and Requirements 1
S EASA - ETSO authorisation (Subpart O of EASA Part 21) for a particular configuration EASA and JAA Aviation Standards and Requirements 9
C What is EASA (European Aviation Safety Agency) Part 21 G EASA and JAA Aviation Standards and Requirements 2
A EASA Part M - Continuing Airworthiness Management Organisation EASA and JAA Aviation Standards and Requirements 40
F EASA Part 21 Subpart J - Understanding the DOA (Design Organization Approval) EASA and JAA Aviation Standards and Requirements 23
M EASA (European Aviation Safety Agency) Part 21 Subpart G EASA and JAA Aviation Standards and Requirements 5
R EASA Form1 - Block 10 EASA and JAA Aviation Standards and Requirements 0
A Domain of the component (EASA CM No.: CM-SWCEH-001 Issue 01 Revision 02) Point 9.3.3 (Usage domain aspects) EASA and JAA Aviation Standards and Requirements 0
L What is the very first step to prepare for applying EASA POA? EASA and JAA Aviation Standards and Requirements 1
S Adding Value prior to signing EASA Form 1 EASA and JAA Aviation Standards and Requirements 5
A EASA Easy Access Rules for Continuing Airworthiness - June 2017 EASA and JAA Aviation Standards and Requirements 0
T Block 11 of the EASA FORM 1 EASA and JAA Aviation Standards and Requirements 2
T EASA P 145: What mandatory information should on the purchase order of the customer ? EASA and JAA Aviation Standards and Requirements 2
A Microcontroller: Discussion about EASA CM - SWCEH - 001 EASA and JAA Aviation Standards and Requirements 1
P Is it possible to receive EASA STC within 48 hours after modification? EASA and JAA Aviation Standards and Requirements 1
P EASA STC (Supplemental Type Certificate) on a Pre-mod FAA STC Configuration EASA and JAA Aviation Standards and Requirements 1
T EASA TAG Block 11 Status/Work issue Quality Manager and Management Related Issues 1
D How to receive EASA approval for removing of engine QEC Kit EASA and JAA Aviation Standards and Requirements 1
G BCARs/EASA to ISO9001/AS9100 cross reference matrix/table wanted EASA and JAA Aviation Standards and Requirements 1
H POA procedure and EASA Form 1 Release EASA and JAA Aviation Standards and Requirements 2
M A Question on EASA's "Release and Acceptance of Components" EASA and JAA Aviation Standards and Requirements 2
I Meeting AS9100, FAA, Transport Canada, EASA Training Requirements - Vent/Rant Coffee Break and Water Cooler Discussions 2
C Example of Man Hours Plan required by EASA EASA and JAA Aviation Standards and Requirements 2
J EASA DOA Certification/Design Activities in India EASA and JAA Aviation Standards and Requirements 2
D EASA Form 1 Requirements for Serviceable Parts from Unserviceable Engine EASA and JAA Aviation Standards and Requirements 2
I Advice Needed For EASA Approved Aircraft Mod EASA and JAA Aviation Standards and Requirements 1
P The use of multiple EASA FORM 1 for Multiple Assemblies EASA and JAA Aviation Standards and Requirements 2
W How to write an EASA 145 Quality Manual EASA and JAA Aviation Standards and Requirements 3
JoCam EASA Regulatory Requirements for Electronics Contract Manufacturer AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
P Non EASA Aircraft - What is meant by Non EASA Aircraft? EASA and JAA Aviation Standards and Requirements 4
C What are these EASA Acronyms? EASA and JAA Aviation Standards and Requirements 9
B Military / Police / EASA Regulations and Requirements EASA and JAA Aviation Standards and Requirements 4
P EASA 145 (145.A.30) Man Hour Plan for Quality Monitoring EASA and JAA Aviation Standards and Requirements 2
