ECO (Engineering Change Order) Control for Unreleased Products
JJStone
I'm in the process of defining an ECO process and I'm slightly unsure about how to control changes to a product prior to the product being released.
I'm clear about ECO and revision control for changes to released products (ECR raised, approved leading to ECO being created, changes implemented and ECO approved with ECN to notify on release) - but I need to define a good document for R&D to follow for changes being implemented to unreleased products.
Is an ECO required for all changes to a product before release to manufacturing?
JJ
somashekar
Re: ECO Control for Unreleased Products
JJ
Hi JJStone...
Like all other functions the D&D is also a system oriented process. So changes made in the evolving of the design is the development part, that is to lead you to the released product. A good system will captures the details of changes made at every planned design development review stage.
All our design and development outputs are stamped / watermarked across the document as "DRAFT" and the revision control on then is D1, D2, D3, .. Dx. This is based on the various stages through which the design gets developed and matures to a release level for production use.
Once released, the document will no longer have the "DRAFT" marked on it, and this further goes through formal ECO as you have mentioned with revision control 1,2,3,..x as the case may be. The comment for the revision 1 is always "Released for production".
JJStone
Thanks for your reply Somashekar.
I would also appreciate someone's view on another query.
Do engineering drawings need to be released with an ECO or can drawings be managed via the documentation system (similar to procedures, etc)?
Also do drawings need to be structured into the BOM?
somashekar
Engineering drawings are design and development outputs, and forms a part of the change logic. With the approval and release of an ECO, one or several engineering drawings can undergo changes and be part of the release, that is put to use.
Bill of materials (BOM) again a design and development output refers to parts, components, assemblies, where several of them denoted by their identification (Number / description) directly refer to an engineering drawing. Hence they are structured into the BOM.
Note: A sketch / line diagram or any other visual aid made within a procedure for better understanding and use of the procedure are not engineering drawings. However, one of the use of an engineering drawing can be that of a work instruction or a reference from a work instruction.
D ECO (Engineering Change Order) process questions ISO 13485:2016 - Medical Device Quality Management Systems 7
D Engineering Change Order (ECO) metrics to track ISO 13485:2016 - Medical Device Quality Management Systems 6
M ECO (Engineering Change Order) Record Filing Question Records and Data - Quality, Legal and Other Evidence 1
T Need help developing an ECO (Engineering Change order) procedure Document Control Systems, Procedures, Forms and Templates 3
C Documents not controlled by the ECO (Engineering Change Order) process ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
D How to process Customer ECO's (Engineering Change Orders) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
Q How to close the circle QMS and ECO (Engineering Change Order)? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
Q Document Control ECO (Engineering Change Order) or QMS? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
D ECO (Engineering Change Order) Risk Management Criteria and QA Document Control Systems, Procedures, Forms and Templates 19
M ECO (Engineering Change Order) Tracking and Status Report Document Control Systems, Procedures, Forms and Templates 1
T ECO (Engineering Change Order) Implementation checklist/work instruction Document Control Systems, Procedures, Forms and Templates 6
V How to measure ECO (Engineering Change Order) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
M Engineering Change Request/Order (ECR/ECO) or Document Change Request/Order (DCR/DCO) Document Control Systems, Procedures, Forms and Templates 30
R ECO (Engineering Change Order) presentation Document Control Systems, Procedures, Forms and Templates 2
R ECO (Engineering Change Order) Question for all experts (fill the blanks) Document Control Systems, Procedures, Forms and Templates 4
K ECO (Engineering Change Order) Revision - Letter change or part number change? Manufacturing and Related Processes 13
Raffy ECN (Engineering Change Notice) / ECO (Engineering Change Order) System Document Control Systems, Procedures, Forms and Templates 1
N Engineering Changes (ECR, ECO, ECN) and how they should be Structured Document Control Systems, Procedures, Forms and Templates 6
Q Filtering ECR/ECO by quality management? Managing Engineering Changes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
D Question regarding ECO process, specifically for Life Science products and defining form fit and function ISO 13485:2016 - Medical Device Quality Management Systems 1
P ECO Disposition - Deviation Needed for Use As Is? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
T Electronic ECO/ECR Process - Software recommendations Document Control Systems, Procedures, Forms and Templates 3
R Parts included/not included in ECO/ECN Document Control Systems, Procedures, Forms and Templates 1
H Drowning in ECR/ECO/ECN Document Changes Document Control Systems, Procedures, Forms and Templates 7
J ECR to ECO to ECN Procedure and numbering system Document Control Systems, Procedures, Forms and Templates 4
J Introducing a new Product Variant - ECO Process? Document Control Systems, Procedures, Forms and Templates 3
Q Are ECO's closed after they are shown to be Effective? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
Q How raise en ECO starting from a NC - ECO after NCR? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
L Developing an Access ECO Tracking Database - Need help Document Control Systems, Procedures, Forms and Templates 8
D Official Clarification of ECO, PDR, PCR Acronym Definitions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
M How NCR CAR and ECO Interact - Customer Rejection Document Control Systems, Procedures, Forms and Templates 5
M CAR vs ECO/ECN - How do I merge CAR with ECO or ECR/ECN procedure seemlessly Document Control Systems, Procedures, Forms and Templates 5
M Differences between ISO 14001 and EU Eco-Management and Audit Scheme (EMAS) ISO 14001:2015 Specific Discussions 2
M Looking for an ECO/ECN logging software Document Control Systems, Procedures, Forms and Templates 3
M Documentation for Health & Safety (OSHA) require ECO's? ISO 13485:2016 - Medical Device Quality Management Systems 11
J Drawing Revision History Question... Signature on EO or ECO Document Control Systems, Procedures, Forms and Templates 18
N Corrective Actions and ECOs - If an ECO addresses the issue, why do we do CARs ? Nonconformance and Corrective Action 16
Marc Engineering Technician - X-ray Imaging - Suspense 30 Nov 2020 Job Openings, Consulting and Employment Opportunities 0
Revision36 Engineering Change Order Industry Standards Other Medical Device and Orthopedic Related Topics 4
A Quality engineering positions in US - question Job Openings, Consulting and Employment Opportunities 1
J UCLA extension Medical Device Engineering Program Training - Internal, External, Online and Distance Learning 0
G Engineering retest in line - Machine stability issues IATF 16949 - Automotive Quality Systems Standard 8
A FDA and NB audit of Engineering Drawings in DHF and DMR. Medical Device and FDA Regulations and Standards News 1
I Good resources for learning statistics (quality engineering related) Statistical Analysis Tools, Techniques and SPC 10
B Lessons Learned Implementing ISO 50001 (Chemical Engineering Progress) Other ISO and International Standards and European Regulations 0
G Engineering Specifications - APQP APQP and PPAP 5
O Vendor vs Engineering Document Control ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
C E signatures on Engineering Change Notes AS9100 / AS9116 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
Icy Mountain Engineering Change Order...Modification Order Document Control Systems, Procedures, Forms and Templates 18
