ECR (Engineering Change Request) Flowchart - Is this a work instruction
sardonyx
Does ECR flowchart considered a work instruction?
Can I submit an ECR flowchart by itself? or should I put this as attachment of a procedure? I'm thinking of submitting an ECR flowchart to use it as a visual aid for engineers just in case they forget the process. Is this possible?
Please help.:confused:
Marc
What information is on the flow chart? If enough information is present, a flow chart can be sufficient.
Q
qualitygoddess - 2010
I think as many procedures and instructions as possible should be in the form of a flowchart. Easy to read, easy to post, easy to follow! All good things.
--QG
sardonyx
Sorry I forgot to put, it's an ECR Process Flowchart, from create/update, submit, review, approve document to its release. I put the title as ECR process flowchart, does it have to go under quality process? This is a supporting document of a control of document procedure. Or maybe change the title?
Howard Atkins
Forum Administrator
In my mind the form is a work instruction in itself and does not need any additional documentation. Build the form so it drives the people to do all the actions in the correct sequence. Why do you need more?
mikoyan
When I create procedures, I try to use flow charts as much as possible. In the little boxes and what not, I try to put as much information as possible to show what needs to get done. Something visual like a flow chart is alot easier to follow than a bunch of words.
To answer you question, it can be whatever you want to call it.
sardonyx
Thanks for all your responses. :thanx: I was just confused if what level is a flowchart in a QMS pyramid like Quality policy is the top one, followed by procedures, and then work instruction as the 3rd level (correctly me if 'm wrong) and so forth. Is flowchart the same level as work instruction? or can be the same level as procedures? :bonk:
Pure wisdom! Thanks Howard!
If the form is designed correctly then it becomes the instruction itself. A bit like the IRS tax forms - designed for 'most' folks to be able to follow, so your ECR should be good for a smaller population....
Andy
sardonyx
We already have an ECR form, I'm trying to create a flowchart to show the procedure from creating a new document/updating existing document to approving the document. I'm sorry for the confusion but I guess my flowchart is not about an ECR process it's more on how to get a document approve before submitting it for an ECR. We have a little bit of confusion here when submitting documents and I'm trying to simplify the flowchart so that non-technical requestor can easily understand the procedure through a flowchart. And my question is, "does the flowchart fall under the work instruction? or does flowchart is another type of document (same level of work instruction)? Can I just include this flowchart under Doc. Control Procedure? Or can I submit this as by flowchart by itself? Thanks for any help.
Howard Atkins
Forum Administrator
Call it what you like
As document control is a Shall for procedures then the flowchart should be part of the procedure or all of the procedure.
See this thread Formats: Text Procedures vs. Flow Charts and search for other similar threads.
You seem to be getting hung up on the name, this is not important apart from the mandatory procedures. As long as it works call it what you like, for example Controlled Document is a neutral term that explains exactly what it is.:agree1:
J Class 1 Medical Device ECR (Engineering Change Request) Changes 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
Q ECR (Engineering Change Request) or NCR (Nonconformance Report) in Fabrication? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
M Formula for Prioritizing Engineering Change Requests (ECR)? Document Control Systems, Procedures, Forms and Templates 1
Q ECR?s (Engineering Change Requests) in Engineering? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
T From ECR (Engineering Change Request) to ECN (Engineering Change Note) - double work! Document Control Systems, Procedures, Forms and Templates 2
9 ECR (Engineering Change Request) process - Please critique / review Document Control Systems, Procedures, Forms and Templates 10
M Engineering Change Request/Order (ECR/ECO) or Document Change Request/Order (DCR/DCO) Document Control Systems, Procedures, Forms and Templates 30
W Engineering ECR (Engineering Change Request) and ECN (Eng Change Notice) Procedures Document Control Systems, Procedures, Forms and Templates 3
K When to use an Engineering Change Request (ECR) Document Control Systems, Procedures, Forms and Templates 8
O ECN (Engineering Change Notice) to ECR (Change Request) Database with Email Report Document Control Systems, Procedures, Forms and Templates 8
U Advice on Engineering Change Request (ECR) software Software Quality Assurance 4
G Engineering Change Request (ECR) / Notice (ECN) - Seeking Example Forms Document Control Systems, Procedures, Forms and Templates 21
N Engineering Changes (ECR, ECO, ECN) and how they should be Structured Document Control Systems, Procedures, Forms and Templates 6
Q Filtering ECR/ECO by quality management? Managing Engineering Changes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
T Electronic ECO/ECR Process - Software recommendations Document Control Systems, Procedures, Forms and Templates 3
H Drowning in ECR/ECO/ECN Document Changes Document Control Systems, Procedures, Forms and Templates 7
J ECR to ECO to ECN Procedure and numbering system Document Control Systems, Procedures, Forms and Templates 4
S ECR - meaning of "Control Item Affected: Yes or no" IATF 16949 - Automotive Quality Systems Standard 1
L How to control some Documents and Records (ECN's and ECR's) Document Control Systems, Procedures, Forms and Templates 1
E Help with ECR/DCR Document Change Control Software Validation Qualification and Validation (including 21 CFR Part 11) 6
A ECR & ECN - Looking for advice and Spreadsheet Example Document Control Systems, Procedures, Forms and Templates 1
V ECR/DCR Process Flow - What changes require an ECR vs. a DCR Document Control Systems, Procedures, Forms and Templates 2
M CAR vs ECO/ECN - How do I merge CAR with ECO or ECR/ECN procedure seemlessly Document Control Systems, Procedures, Forms and Templates 5
C Acronym ECR - Acronym Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 6
Marc Engineering Technician - Suspense 5 April 2021 Job Openings, Consulting and Employment Opportunities 0
Marc Engineering Technician - Suspense 11 February 2021 Job Openings, Consulting and Employment Opportunities 0
Bev D Essential References for Practical Quality Engineering Misc. Quality Assurance and Business Systems Related Topics 0
Revision36 Engineering Change Order Industry Standards Other Medical Device and Orthopedic Related Topics 4
D ECO (Engineering Change Order) process questions ISO 13485:2016 - Medical Device Quality Management Systems 7
D Engineering Change Order (ECO) metrics to track ISO 13485:2016 - Medical Device Quality Management Systems 6
J UCLA extension Medical Device Engineering Program Training - Internal, External, Online and Distance Learning 0
G Engineering retest in line - Machine stability issues IATF 16949 - Automotive Quality Systems Standard 8
A FDA and NB audit of Engineering Drawings in DHF and DMR. Medical Device and FDA Regulations and Standards News 1
I Good resources for learning statistics (quality engineering related) Statistical Analysis Tools, Techniques and SPC 10
B Lessons Learned Implementing ISO 50001 (Chemical Engineering Progress) Other ISO and International Standards and European Regulations 0
G Engineering Specifications - APQP APQP and PPAP 5
O Vendor vs Engineering Document Control ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
C E signatures on Engineering Change Notes AS9100 / AS9116 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
Icy Mountain Engineering Change Order...Modification Order Document Control Systems, Procedures, Forms and Templates 18
J Implementing Machine Replacement Part Reverse engineering technology Manufacturing and Related Processes 3
T Why do most companies have Quality reporting to Engineering or Operations and not to CEO? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 45
I Document templates required for ISO ISO 45001 - Engineering Construction company Occupational Health & Safety Management Standards 5
R The alignments and contradiction in Quality Engineering and management between the Automotive and Aerospace industry AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
D Engineering Drawing Review and Approval Requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
V Thinning percentage in sheet metal forming per SES (Suzuki Engineering Standard) Manufacturing and Related Processes 1
P Usability/human factors engineering requirement (standard) for IVD medical device Other Medical Device Related Standards 2
R Creating WIs for a Heavy Civil Engineering Services company Document Control Systems, Procedures, Forms and Templates 19
S Ballooned Drawings and Engineering Changes Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
P Tactics to work with Design Engineering on CAR Nonconformance and Corrective Action 3
