ECR?s (Engineering Change Requests) in Engineering?
Q
QAMTY
ECR´s (Engineering Change Requests) in Engineering?
Hi all
I´m going to share a doubt, regarding the ECR´s - Awaiting to hear your valuable opinion.
I´m clear about how to raise an ECR, but dont´know how to apply this in an Engineering process. In the development of the Engineering, are produced a lot of drawings ,spec, Data sheets, isometrics, etc. And normally before a drawing is released for construction,passed for several revisions, verification, crosss-checking process, etc.
The Engineering department has several departments like:
Electrical, Civil, mechanic,etc.
the question is:
If in the process of revision or after a drawing is released suppose Electrical needs a change in a drawing belonging to Mech, area, well normally this is required by mean of commented hardcopy in a cross.checking sessionand asking this by email, a design review session ,but never is raised an ECR. Dont´want to imagine raising a lot of ECR´s for all changes from all the departments.
How to manage, this? in Engineering, when exactly is needed to do it.
And, is it a normal and useful practice in Eng. because the high volumes in changes?
for my QMS I have the DCR process.
somashekar
Re: ECR´s in Engineering?
ECR is the baby of the design and development change process.
So when your mechanical, electrical, structural, plumbing, etc design and drawings have not been reviewed well, and verified by many simulation tools that are available, you will come across more babies ... I mean ECR's.
If this is in a pre design release, it needs to happen as many times as clarifications arise, then why are talking about ECR ??
Q
QAMTY
Thanks Somashekar
You mean the normal practice to ask a change to other department
is by mean of an ECR and filling out the form?
Is it the same process as to markup a drawing asking a change of a drawing no filling out forms?
could it be in both ways?
Thanks for your clarification.
somashekar
I take it that the design is released for construction.
Yes, the form (if designed with thought) helps to capture all the other associated changes that are felt needed with the approval of this change.
It is not the same. Here you are not creating the required interaction with all concerned activities about how this change will effect them. In this approach, you may go about facing a lot of DO and UNDO situations depending upon the complexity of the change, losing on time, money and work quality. Most undesirable and just not what the QMS intends.
Q
QAMTY
Thansk again somashekar
OK, so would be advisable to raise ECR´s ony after the Construction release
more stable document? less likely to changes, thus less paperwork?
not in the preliminary stages?
The markup method, not good, very useful info would be lost
Regards
J Class 1 Medical Device ECR (Engineering Change Request) Changes 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
Q ECR (Engineering Change Request) or NCR (Nonconformance Report) in Fabrication? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
M Formula for Prioritizing Engineering Change Requests (ECR)? Document Control Systems, Procedures, Forms and Templates 1
T From ECR (Engineering Change Request) to ECN (Engineering Change Note) - double work! Document Control Systems, Procedures, Forms and Templates 2
9 ECR (Engineering Change Request) process - Please critique / review Document Control Systems, Procedures, Forms and Templates 10
M Engineering Change Request/Order (ECR/ECO) or Document Change Request/Order (DCR/DCO) Document Control Systems, Procedures, Forms and Templates 30
W Engineering ECR (Engineering Change Request) and ECN (Eng Change Notice) Procedures Document Control Systems, Procedures, Forms and Templates 3
K When to use an Engineering Change Request (ECR) Document Control Systems, Procedures, Forms and Templates 8
O ECN (Engineering Change Notice) to ECR (Change Request) Database with Email Report Document Control Systems, Procedures, Forms and Templates 8
U Advice on Engineering Change Request (ECR) software Software Quality Assurance 4
sardonyx ECR (Engineering Change Request) Flowchart - Is this a work instruction Document Control Systems, Procedures, Forms and Templates 9
G Engineering Change Request (ECR) / Notice (ECN) - Seeking Example Forms Document Control Systems, Procedures, Forms and Templates 21
N Engineering Changes (ECR, ECO, ECN) and how they should be Structured Document Control Systems, Procedures, Forms and Templates 6
Q Filtering ECR/ECO by quality management? Managing Engineering Changes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
T Electronic ECO/ECR Process - Software recommendations Document Control Systems, Procedures, Forms and Templates 3
H Drowning in ECR/ECO/ECN Document Changes Document Control Systems, Procedures, Forms and Templates 7
J ECR to ECO to ECN Procedure and numbering system Document Control Systems, Procedures, Forms and Templates 4
S ECR - meaning of "Control Item Affected: Yes or no" IATF 16949 - Automotive Quality Systems Standard 1
L How to control some Documents and Records (ECN's and ECR's) Document Control Systems, Procedures, Forms and Templates 1
E Help with ECR/DCR Document Change Control Software Validation Qualification and Validation (including 21 CFR Part 11) 6
A ECR & ECN - Looking for advice and Spreadsheet Example Document Control Systems, Procedures, Forms and Templates 1
V ECR/DCR Process Flow - What changes require an ECR vs. a DCR Document Control Systems, Procedures, Forms and Templates 2
M CAR vs ECO/ECN - How do I merge CAR with ECO or ECR/ECN procedure seemlessly Document Control Systems, Procedures, Forms and Templates 5
C Acronym ECR - Acronym Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 6
Marc Engineering Technician - X-ray Imaging - Suspense 30 Nov 2020 Job Openings, Consulting and Employment Opportunities 0
Revision36 Engineering Change Order Industry Standards Other Medical Device and Orthopedic Related Topics 4
D ECO (Engineering Change Order) process questions ISO 13485:2016 - Medical Device Quality Management Systems 7
A Quality engineering positions in US - question Job Openings, Consulting and Employment Opportunities 1
D Engineering Change Order (ECO) metrics to track ISO 13485:2016 - Medical Device Quality Management Systems 6
J UCLA extension Medical Device Engineering Program Training - Internal, External, Online and Distance Learning 0
G Engineering retest in line - Machine stability issues IATF 16949 - Automotive Quality Systems Standard 8
A FDA and NB audit of Engineering Drawings in DHF and DMR. Medical Device and FDA Regulations and Standards News 1
I Good resources for learning statistics (quality engineering related) Statistical Analysis Tools, Techniques and SPC 10
B Lessons Learned Implementing ISO 50001 (Chemical Engineering Progress) Other ISO and International Standards and European Regulations 0
G Engineering Specifications - APQP APQP and PPAP 5
O Vendor vs Engineering Document Control ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
C E signatures on Engineering Change Notes AS9100 / AS9116 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
Icy Mountain Engineering Change Order...Modification Order Document Control Systems, Procedures, Forms and Templates 18
jjmusicjr Implementing Machine Replacement Part Reverse engineering technology Manufacturing and Related Processes 3
T Why do most companies have Quality reporting to Engineering or Operations and not to CEO? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 45
I Document templates required for ISO ISO 45001 - Engineering Construction company Occupational Health & Safety Management Standards 5
R The alignments and contradiction in Quality Engineering and management between the Automotive and Aerospace industry AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
D Engineering Drawing Review and Approval Requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
V Thinning percentage in sheet metal forming per SES (Suzuki Engineering Standard) Manufacturing and Related Processes 1
P Usability/human factors engineering requirement (standard) for IVD medical device Other Medical Device Related Standards 2
R Creating WIs for a Heavy Civil Engineering Services company Document Control Systems, Procedures, Forms and Templates 19
S Ballooned Drawings and Engineering Changes Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
P Tactics to work with Design Engineering on CAR Nonconformance and Corrective Action 3
D Are detailed engineering requirements Design Inputs or Design Outputs 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 14
