Effect of Fixtures on Test Method Validation
deepuasok
Hi all :),
Our company is currently validating the test methods for a particular medical product. We have mostly tension/compression tests measuring the attachment/removal forces between the various mated components of the medical devices. But we found many test methods which could be leveraged for this validations study from other product families which were pretty much the same methods,range,crosshead speed etc. except for the test fixtures. Would this be a significant factor. As the test fixture serves the purpose of holding the component,without actually being a part of the measurement system, should'nt we be able to leverage those methods even though the fixtures are different. Basically the method of attaching/removing the cap,adaptor etc are the same,but the fixture used to hold them are different.What is your opinion on this?
-Deepu :bigwave:
no opinion, just experience. in my experience the fixture can have a substantial effect on the measuements, they actually are considered to be part of the measuring system.
I once went through 3 different fixtures before I found one that would be (mostly) neutral in a measurement of hte pull force required to separate two mating parts. If you draw the free body force diagrams you can see how any holding fixture can change the forces that are applied to the object vs those that are wasted in the system. (I do work in the medical device industry)
M Office and manufacturing site relocation effect on Device Technical File CE Marking (Conformité Européene) / CB Scheme 2
Q Autoclave and Sample Container - Pressure-steam cooking's effect Reliability Analysis - Predictions, Testing and Standards 1
J EU ISO 13485:2016 Recertification Audit - Effect of 10 Minor Nonconformances EU Medical Device Regulations 2
C Design for Assembly in DFMEA - Failure Effect of Sub-System(s) FMEA and Control Plans 5
supadrai Effect of a Merger on Acquired Company's Medical Device Licenses Other Medical Device Regulations World-Wide 2
H New FAQ & SI -IATF 16949 - Effect in april and june 2018 IATF 16949 - Automotive Quality Systems Standard 0
G Effect of ISO9001 2015 transition on ISO IEC 80079-34 Other ISO and International Standards and European Regulations 3
N PFMEA no effect ratings FMEA and Control Plans 15
Ron Rompen The Effect of Heat on Production and Quality Human Factors and Ergonomics in Engineering 14
Q Risk Tools in ISO 31010 - Root Cause Analysis vs. Cause-and-effect Analysis ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
K Determining Effect of Failure without a DFMEA (Design FMEA) FMEA and Control Plans 1
D Is it okay to CE mark the product until the RoHS2 directive goes into effect? CE Marking (Conformité Européene) / CB Scheme 7
N Reason for determining no adverse effect on reworked product ISO 13485:2016 - Medical Device Quality Management Systems 8
S Seeking Feedback on ASQ Guide to Failure Mode and Effect Analysis FMEA and Control Plans 2
P Cyclic Effect Factoring in DOE (Design of Experiments) Quality Tools, Improvement and Analysis 1
C CFDA MD regulation_20140331 - Comes into effect June 01, 2014 China Medical Device Regulations 33
M Effect of Boil Test on Passivated SS Medical Instruments Manufacturing and Related Processes 11
F Power supply certification and its effect on testing IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
R Does the SIC have an effect on the ISO scope on your certificate? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
C Severity of Effect on Process (Manufacturing/Assembly Effect) Scrap or Reworking FMEA and Control Plans 3
M BS EN ISO 15223-1:2012 replaces EN 980 - What is the effect of the change? Quality Manager and Management Related Issues 44
C Cause and Effect Matrix Template Document Control Systems, Procedures, Forms and Templates 0
B Changes that could effect the Quality Management System - Management Review ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
R Length Out of Specification - How do I perform Cause and Effect Diagram? Nonconformance and Corrective Action 6
A Comparing Effect of Process Parameters on Equipment Performance during Start Ups Statistical Analysis Tools, Techniques and SPC 3
P Control of "manufacturing material" that has adverse effect on the medical device? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
B Effect of Soldering on Tin Plating Manufacturing and Related Processes 5
D Effect of Puncture Orientation on Force Value Other Medical Device Related Standards 1
P Process FMEA with the effect "brakes are broken" - Is it nonconformity? IATF 16949 - Automotive Quality Systems Standard 7
S Root Cause Analysis & Cause and Effect Diagram Customer Complaints 5
M Effect of double ETO (Ethylene Oxide) Sterilization ISO 13485:2016 - Medical Device Quality Management Systems 13
V What effect has Supply Voltage on product performance? IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
A Main Effect - Interaction Plots - 2 Level Factorial DOE with 18 Runs Using Minitab Software 8
V Effect of sample size on Cpk results? Using Minitab Software 2
Chennaiite FMEA Severity Rating for Potential Manufacturing Effect mentioned in the FMEA manual FMEA and Control Plans 9
A Cause and Effect Analysis - Hardness of Rubber (i.e., durometer) Quality Tools, Improvement and Analysis 11
Ajit Basrur Pre Filled Syringes (PFS) - Effect of Containers on the Contents 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
R EMP (Evaluating the Measurement Process) Studies for Bias Effect Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
I Quantifying the Effect of Excessive Within-Part Variation Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
B Sampling Plan - AQL effect on Sample Size AQL - Acceptable Quality Level 9
S The Effect of implementation of an Integrated Management System & EFQM ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
Q Cause and Effect Worksheet Quality Tools, Improvement and Analysis 2
M Effect of your Quality Role on your life Coffee Break and Water Cooler Discussions 31
N Uncertainty for Humidity Probes - Temperature Effect from 0.5?C dew point = 1.3%rh Measurement Uncertainty (MU) 2
A Effect of %GRR (% Gage R&R) on Cpk Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 13
C Evaluation of Bearing (Effect) of a Deviation on Quality Nonconformance and Corrective Action 10
M Pygmalion Effect - Communication The Reading Room 11
M Recommendations for detecting "Triangle Effect" Inspection, Prints (Drawings), Testing, Sampling and Related Topics 11
ScottK Telecommuting may have the opposite effect on workers in the office. Career and Occupation Discussions 0
B Effect of Inept Leadership and Mismanagement on an Organization Coffee Break and Water Cooler Discussions 13
