Effective & Efficient - Why both terms "effective" and "efficient" used together?
Bilijaf
Why both terms "effective" and "efficient" are most of the time jointly used? Can't we have one word which can replace both?:tg:
Ajit Basrur
Re: Effective & Efficient
Good question :agree1:
Both terms are related to each other -
Efficiency will refer to output versus input; higher ratio contributes to higher efficiency while lower ratio refers to lower efficiency. Thus the higher ratio process will be called "efficient"
Effectiveness is more towards meeting the goals.
Therefore, in a working environment, the manager should be efficient and effective. I come from ESL (English as Second Language) thus shall wait for covers whose English is more better than mine :)
Kevin Mader
One of THE Original Covers!
Ajit's english is fine. Doing a browse here using the search tool will likely land you dozens of hits. Give it a try.
Your question is quite common and the one word term I've often seen used is - performance. As Ajit points out, efficiency is a ratiometric measure in where you are trying to optimize resources for a gain. What's not clear is what gain is being obtained. For instance, you could be very efficient at making scrap. Obviously scrap is not the goal, so it could be said that you are being very efficient at being ineffective. You have to make adjustments, sometimes at the expense of some of your efficiency to meet the target (become effective). Overall, doing the most with the least amount of resources while achieving your goal amounts to good performance. Just ask your boss!!:lol:
I'm sure others have words they prefer - perhaps they'll share here.
Regards,
Kevin
Manix
Get Involved!!!
Just replying really to support what has already been said. They are certainly not mutually exclusive hence why they are used in conjunction with one another.
Perhaps you should think in terms of being "efficiently effective"!!! :notme:
Jen Kirley
Quality and Auditing Expert
Nice to see you again Kevin - my recruiter. :bigwave:
I think the term effective is about as loosely applied and interpreted as the term Quality. And it's fair to point out that effective is one of the synonyms listed for efficient in my Webster's Thesaurus, and vice versa. After all, they both describe outcomes compared against expectations.
And so it seems fair to ask the organization to understand the conceptual difference between the two terms if it cares to, to define substitutions if a distinction is desired, and at the very least demonstrate they pursue their goals without compromising other goals.
In other words, if time to complete an audit is a key metric of efficiency, I can do my job more efficiently by cutting out some of the tasks, but the end result may not be effective if it impacted my overall results unexpectedly, or an internal customer's results, or an external customer's product or service. It is important for an organization to grasp this concept if it wants to avoid errors or other undesired consequences.
:2cents:
SteelMaiden
My son cleans the kitchen on Saturday. His work method is effective. It takes him 5 hours to get done. His work is not effecient.
I clean the kitchen on Friday. My work method is effective. It takes me 20 minutes. My work is effecient.
There is a difference, sometimes it is a subtle difference, but you can be effective without being effecient.
Ajit Basrur
In Pharmaceuticals, we have different levels of cleaning viz. between different batches of the same product and between different products. Definitely the earlier is much quicker while the latter is a detailed cleaning requiring clenaing of equipment, wall surfaces, floor etc.
Probably, yours is that quicker one while your son does a thorough cleaning ;)
SteelMaiden
Yeah, that must be it!:lmao::lmao:
A word used in pharmaceuticals captures both concepts nicely: efficacy. Something that's efficacious performs as intended, which should mean that it's both effective and efficient.
T How you ensure that QMS is effective and efficient? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
W Safe and Sound Software: Creating an Efficient and Effective Quality System for Softw Book, Video, Blog and Web Site Reviews and Recommendations 1
S How to calculate Effective Number of People for ISO 13485 Certification? General Auditing Discussions 2
A PRRC effective role and activities EU Medical Device Regulations 1
S Effective nonconforming process for AS9100 8.7 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
M Informational TGA presentation: How to submit an effective good manufacturing practice clearance application Medical Device and FDA Regulations and Standards News 0
N Validation procedure, Major NC CAP - Equipment Validation process is not effective ISO 13485:2016 - Medical Device Quality Management Systems 5
A Cost effective thread gaging with ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
S Root cause analysis - The system of developing a work instruction is not effective Problem Solving, Root Cause Fault and Failure Analysis 1
T Effective Date on Documents 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 12
qualprod Effective Auditing advice needed ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
Q Simple and effective way to maintain Training Matrix ISO 13485:2016 - Medical Device Quality Management Systems 16
J If Corrective and Preventive Action were truly Effective IATF 16949 - Automotive Quality Systems Standard 3
qualprod Risk closeout , mitigation was not effective, next? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
J Specific Actions where Timely and/or Effective Actions are not Achieved Nonconformance and Corrective Action 6
Q Predating Document Effective Date Other Medical Device and Orthopedic Related Topics 18
P Thai FDA postpone AMDD to be effective in 2020 Other Medical Device Regulations World-Wide 1
S Sell a Non-RoHS device, manufactured before RoHs regulations became effective? EU Medical Device Regulations 2
J What does "effective implementation of quality management system" mean? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
N What does an effective design process look like? (shoots flare in the air) Design and Development of Products and Processes 2
M Corrective Action - For a corrective action to be effective, a change is required? Nonconformance and Corrective Action 5
R 5.4.1 Quality Objectives - Nonconformity: The process was not fully effective ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 36
R Training to Effective Documents - Transitioning to Agile Document Control Systems, Procedures, Forms and Templates 5
R Good Supply Practices that will be effective on March 1 2015 in China China Medical Device Regulations 2
K IATF has posted new GM Customer Specifics, effective January 2015 Customer and Company Specific Requirements 5
B Medical Device Labeling - Order No. 6 Effective Oct 01, 2014 China Medical Device Regulations 7
R CFDA updated five regulations to be effective from October 1, 2014 China Medical Device Regulations 16
T Qualification System of Internal Auditors is not Effective General Auditing Discussions 5
A A Guide to Effective Internal Management System Audits Book, Video, Blog and Web Site Reviews and Recommendations 2
D Effective Date of updated SOP Document Control Systems, Procedures, Forms and Templates 3
A Effective Date (of Documents) issue outlined in 21 CFR Part 820.4 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 11
P Effective way for DC/DC conversion for 2 MOPP @ 250VAC IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
J Want best and effective solution for mouth infection Coffee Break and Water Cooler Discussions 11
S New FAA Form 8130-3 Effective 2/1/14 - Unlocked version attached Federal Aviation Administration (FAA) Standards and Requirements 3
P Effective Road Usage Coffee Break and Water Cooler Discussions 9
H How to make the Design Review Process Effective Design and Development of Products and Processes 1
Q Effective 1st Piece Inspection Sign Off Procedure Quality Manager and Management Related Issues 8
QMMike What is the most cost effective SPC software Statistical Analysis Tools, Techniques and SPC 5
Y Delivering an effective and all inclusive EHS program in a Food company Food Safety - ISO 22000, HACCP (21 CFR 120) 2
F Suggestions for quick & effective solution for Continuous Improvement Requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
T Very effective movie about clean-up - Tool for 5S Training Lean in Manufacturing and Service Industries 4
M AS 9100 4.2.4 Process for making changes to records is not fully effective Quality Manager and Management Related Issues 4
Q Process Approach & Continual Improvement Clauses and Evidence of its Effective Use ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
M 8.2.2 Internal Audit - Determination of Effective Implementation IATF 16949 - Automotive Quality Systems Standard 4
L Audit NC - Lack of Effective Corrective Action Process ISO 13485:2016 - Medical Device Quality Management Systems 4
P Which Root Cause Analysis Method is the most Effective? Quality Tools, Improvement and Analysis 16
J Cost Effective Solution for Isolating USB 5V 500mA Power IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
Q Are ECO's closed after they are shown to be Effective? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
V What are the Steps in Ensuring a Definition/Implementation of an Effective Procedure Document Control Systems, Procedures, Forms and Templates 3
P What is Effective Maintenance? Auditing a Maintenance Department Manufacturing and Related Processes 5
