Effectiveness of Training... micro or macro?
Randy
#21
:topic:Can't get the FOD program across?
Put 'em in an airplane, strap em down so they can't leave, toss some nuts, bolts and safety wire down the intake and then ask 'em how safe they feel about taking off and flying around a bit. I'm not being ugly or talking BS here, I'm a survivor of the effects of a FOD'd aircraft because of poor practices. You wanna get the message across? Put photo's of downed aircraft and deceased people around the facility and in the break room especially that are the results of FOD......drive it home! Been there, done that.
You have gotten some pretty good answers here about effectiveness of training, but your problem isn't training effectiveness as indicated, it's attitude, core values, and lack of give-a-s*** if if folks don't take FOD seriously, so additional training, survey's and tests may not be the solution.
This subject is too serious to take lightly:mad:
G
ggdjr
#22
as a former f-16 avionics technician in the USAF i can tell you FOD can have serious consequences
FOD walks twice daily at a minimum
Randy
#23
You don't have to tell me. I pranged into the Mojave Desert and took a Martin-Baker seat ride because of a FOD'd engine about 20 years ago.
V
vanputten
#24
"...how would you show evidence of it having taken place (and the results of it) if not in documentary form?"
Interview people. Corroborating responses from multiple people. Competency of the person being asked about the evaluation of the effectiveness of training, meaning the interviewee could competently describe the evaluation and the results.
All of the above could be evidence that the evaluation happened and what the resut was.
P
Pistonbroke
#25
The "questionnaire" answer put earlier was slapped down a little rapidly imo
Althought the anonymous "how do you think you did?" approach is for my taste a little simplistic, there is no reasons why a question sheet cannot be used as a method of determining if the message or activity you are trying to educate is getting into the subjects brain.
In a world where "it's not my fault" seems to be the first line of defence for many, a bit of objective evidence that the person:
a) Attended the training,
b) Was able to identify what was expected of them,
c) Did this to a reasonable level of consistency in relation to the subject matter,
Goes a long way in ensuring that people follow what they have been told.
I have trained many people over the years and I consider that one of the most important aspects, particularly on an "awareness" related subject matter, such as FOD or handling and identifcation of NCM is that there is a mixed attendace, from Management to the Cleaner,
This ensures that everyone knows everyone else is being told the same message, that it's everyones resonsibility, and that everyone knows that you know it too.
I've also found that putting offenders back through training works very well....
It pisses their manager off to have to release them, especially repeatedly
It causes a degree of mockery from their peers if they keep having to get trained for the same thing
It reinforces the message for those whose memory is something like that of a goldfish
Lets face it training can be boring, so it's often easier to improve your working practices than face additional training.
David DeLong
#26
Pistonbroke:
I am the one that posted the anonymous self assessment rating one on a scale of 1 - 10 prior to training and post training.
I do agree with many of the later posts but most were theoretically correct and a much better answer than mine but many were not really applicable in today's lean but fast pace manufacturing. Trying to give each person a written test with a pass fail is time consuming since the same test must be given prior to the training and after the completion of the training.
We all need an effectiveness method that is quick but effective and not too costly.
Sardokar
#27
well personally the way we do it is :
- have a small questionaire about training ( to be filled shortly 24hours after training maximum)
- require a small presentation (15 min or so) on key training featuresto department manager (shortly after training-about 1 week max)
- 3 months after training we ask the employee how much he think this training helped him improve his work
- also 3 months after training we ask the department manager how much he thinks the training the employee got has helped him improve his work
joshua_sx1
#28
…I do agree on David DeLong - that individual assessment is really time consuming and have to be done on strategic ways… that is why, for me, the assessment of the effectiveness of training should start on the training objectives…
you have to have training objectives (this is a must!)… and based on those objectives, you can decide which strategic approach can be used to measure the effectiveness of the training performed… it doesn’t really matter whether your approach is in “micro” or “macro”, as long it will give you measurement to indicate whether you met your objectives or not…
…here is a good example: when giving training for NCR (e.g. how the system works?), your objective might be improvement of NCR implementation… then after conducting training, you have to give enough time, for this NCR to be absorbed by your system, then you can evaluate the effectiveness of the given training… and there are so many ways to evaluate this, one of them is through internal audit… and on this example, you used macro approach…
…now, if you are giving training for an aircraft inspector such as “a walk around inspection”, your objective is probably to make the individual inspector more competent on performing this task… then after a series of trainings, you can evaluate its effectiveness through individual performances (e.g. written or verbal exams, no. of accidents or incidents as resulted from poor walk-around inspection on individual basis, etc)… this is where micro approach would be applicable…
…again, for me, to evaluate the effectiveness of the given training is to measure it against the established training objectives…
:2cents:
Todd H
#29
Table top training can be effective training and always plays a part. Quizzes are effective in testing for comprehension. However procedural or processes have to be demonstrated / observed and then certified.
IE, You can have some one review your Hazcom manual and review the MSDS but only through observation can you verify the employee knows how to handle a hazardous material.
The same logic applies to most any application.
PDCA can be applied to training.
Plan - define training requirements
Do - provide training
Check - verify the effectiveness (quizzes are a tool but observation is required)
Act - refine training or provide refresher training.
V
vanputten
#30
Since ISO 9001 is about processes and systems, and not really individuals, I would take a macro approach towards the effectiveness of the process instead of a micro approach based on individuals.
L Verifying training effectiveness for procedure changes ISO 13485:2016 - Medical Device Quality Management Systems 4
S What are some ways to demonstrate Effectiveness of Training? ISO 13485:2016 - Medical Device Quality Management Systems 29
R Documenting Self-Training and Effectiveness - ISO 13485:2016 Training - Internal, External, Online and Distance Learning 4
Colin Effectiveness of IRCA Registered Training ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 4
M Training Effectiveness TS 16949 Clause 6.2.2c Training - Internal, External, Online and Distance Learning 5
S How to Monitor Training Effectiveness Training - Internal, External, Online and Distance Learning 13
Q Third Party Audit Nonconformance for Training effectiveness IATF 16949 - Automotive Quality Systems Standard 20
M Effectiveness of Read-Only Training for Procedures Training - Internal, External, Online and Distance Learning 4
S Training Efficiency Assessment - Evaluate the Effectiveness (Clause 6.2.2 c) Training - Internal, External, Online and Distance Learning 3
M How To Measure Training Effectiveness Quality Tools, Improvement and Analysis 8
D How to Measure QSR Training Effectiveness? Training - Internal, External, Online and Distance Learning 6
somashekar Training Effectiveness across Participants ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
J Effectiveness of training? How to Measure Training Effectiveness Training - Internal, External, Online and Distance Learning 51
S How to show that policies are properly communicated & Training Effectiveness ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
C Education vs. Training - Training effectiveness program ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
J Information regarding Competence and Effectiveness of Training Training - Internal, External, Online and Distance Learning 18
S Evaulation of Operator and Staff Training Effectiveness Training - Internal, External, Online and Distance Learning 10
R Training Competency Verification - NCR related to Training Effectiveness Training - Internal, External, Online and Distance Learning 8
S AS9100 - 6.2.2 - Effectiveness of training? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
S Evidence of Effectiveness of OJT (On the Job Training) - ISO 9001 Clause 6.2.2 Training - Internal, External, Online and Distance Learning 24
R Need some information on Training Effectiveness Assessment Form Document Control Systems, Procedures, Forms and Templates 3
R 13485 6.2.2 c) "evaluate the effectiveness of the actions taken" (training) ISO 13485:2016 - Medical Device Quality Management Systems 4
R APQP and Core Tools Training how to Determine the Effectiveness of Training Training - Internal, External, Online and Distance Learning 10
S How do you evaluate effectiveness of training ISO9001 Section 6.2.2.c? Training - Internal, External, Online and Distance Learning 12
M Training effectiveness measurement - 6.2.2 Competence, awareness and training Training - Internal, External, Online and Distance Learning 9
B Training Effectiveness Evaluation - Different Styles - In-House and External Document Control Systems, Procedures, Forms and Templates 21
Raffy How can I demonstrate evidence and effectiveness of Corrective Action Training Nonconformance and Corrective Action 7
M ISO 9001:2000 - Evaluating Training Effectiveness and Why ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
N Training Competency and Effectiveness Documentation Training - Internal, External, Online and Distance Learning 27
Raffy How do I measure Measuring Training Effectiveness? Performance evaluation? Other ISO and International Standards and European Regulations 26
SteelMaiden Documenting Competency and Effectiveness of Training Document Control Systems, Procedures, Forms and Templates 7
C Training Effectiveness: Simple format for supervisors to track and evaluate training Document Control Systems, Procedures, Forms and Templates 2
G Evaluating Training Effectiveness - 6.2.2 Competence, Awareness and Training ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 55
S Measuring Training Effectiveness - How do you measure Effectiveness? Training - Internal, External, Online and Distance Learning 50
H Effectiveness and efficiency indicators ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
K Visual Inspection Effectiveness Inspection, Prints (Drawings), Testing, Sampling and Related Topics 16
M ISO14971:2019 - Verification of implementation and effectiveness of risk control ISO 14971 - Medical Device Risk Management 3
C Quality, efficiency and effectiveness of daily work routines Misc. Quality Assurance and Business Systems Related Topics 4
V CAPA effectiveness check Nonconformance and Corrective Action 3
N How to monitor the effectiveness of the CAPA system ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
qualprod ISO 9001 5.1.1 - How to measure System effectiveness ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
qualprod Add new action plans in CA, while waiting effectiveness - Same problem reappears ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
qualprod Best criteria to measure Corrective Action effectiveness - Poor Maintenance ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
C CMDR Essential (Safety & Effectiveness) Requirements Checklist? Canada Medical Device Regulations 9
J AQL for Effectiveness Check - What AQL tiers to use on this type of sampling? Nonconformance and Corrective Action 9
M Medical Device News FDA - Transformative new steps to modernize FDA’s 510(k) program to advance the review of the safety and effectiveness of medical devices Other US Medical Device Regulations 0
S Nonconformance to a Note in ISO13485 clause 6.2 Human Resources Effectiveness ISO 13485:2016 - Medical Device Quality Management Systems 13
J Recall Effectiveness - Accessory to Medical Devices shipped through Distributors Customer Complaints 3
qualprod To Evaluate Effectiveness in All Improvements? (ISO 9001:2015) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
M Corrective Action Effectiveness Nonconformance and Corrective Action 5
