Effects of Irradiation Sterilization on Medical Electronics - Li Coin Cell Batteries
sudeepd
Hello all-
We are currently designing a simple LED light system into our disposable medical device. It consists of two 3V Li coin cell batteries, a switch and a high brightness white LED. We have two questions that we'd like to put up for discussion.
1. Short of doing a full performance test on samples and spending a lot of money on figuring out the effects, we were wondering if anyone has any experience packaging similar coin cell batteries and used radiation (Gamma and/or E-Beam) to sterilize the product, and what can be expected.
2. Also, does E-beam radiation affect low powered magnets? We have a small magnet reed switch in the design and would like to know if there is any effect on the magnet/magnetized metal from E-beam radiation.
Your suggestions and guidance are most appreciated.
Thank you.
SD
MIREGMGR
Re: Effects of Irradiation Sterilization on Medical Electronics - Li Coin Cell Batter
A caveat to this response: I don't regularly use or design for either E-beam or gamma sterilization.
I'm under the impression that E-beam may set up prodigious voltages in conductors, so that completion of a conductive path via either leakage current or arcing standoff distance becomes an issue. E-beam also is notorious for causing disintegration of some high-resistivity polymers; a lithium cell that had PTFE insulation exposed at its can surface, for instance, could have that PTFE rapidly destroyed.
I believe I've read in application notes in the past that in at least one instance, a lithium cell maker instructed that their products were not to be gamma sterilized because of radiation effects on chemistry and physics of insulative components.
G
greensal
Hi all,
I am having a similar challenge to that of sudeepd.
We are currently designing a disposable medical device which contains a two 3V Li coin cell batteries, a switch and a high brightness white LED.
The challenge we are facing is in sterilizing the product. We are considering either Gamma or E-Beam. Based on preliminary research, Li coin batteries do not like high temperatures. We know we can sterilize using EtO method, yet the turn around time is not feasible.
Your suggestions and guidance on this topic is highly appreciated.
Thank you,
GS
MIREGMGR
In addition to the prior adverse mechanisms...in E-beam, charge/voltage buildup resulting in circuit failure, and in both means, damage to polymers...gamma tends to directly destroy semiconductor junctions at the nuclear level.
G
greensal
Thank you MIREGMGR for your input
Would a shield around the battery make any difference either during E-Beam or Gamma?
Also are there any Collateral standards (60601-1-X) that define the requirements for certain aspects of safety and performance for battery powered medical device?
Regards,
GS
MIREGMGR
Shielding for gamma would have to be lead, and quite thick. The LED, being a semiconductor, would have to be shielded. Not very practical if you want your device to be portable and emit light.
E-beam shielding with a Faraday cage is possible, but that'll prevent sterilization of the enclosed elements and again would interfere with light emission and switch operation. Very generally speaking, any opening in a Faraday cage larger in its largest dimension than a half wavelength of the applied RF field, defeats the shielding.
My guess is that you aren't going to end up using E-beam or gamma.
K Monitoring the identified side-effects and contraindications ISO 14971 - Medical Device Risk Management 4
Watchcat Effects of Technology - 2020 Misc. Quality Assurance and Business Systems Related Topics 14
C Failure nets - Same level effects FMEA and Control Plans 0
M Informational US FDA paper – Epidemiological Evidence on the Adverse Health Effects Reports in Relation to Mercury from Dental Amalgam: Systematic Literature Review Medical Device and FDA Regulations and Standards News 0
C Detection Action for Failure Effects - AIAG 4th Edition Layout FMEA and Control Plans 5
J0anne Implantable Devices - The effects of surgical scaffold implanted into the human body Other Medical Device and Orthopedic Related Topics 8
H Addressing of Undesirable side-effects, harms, risks and side-effects in clinical evaluation report (CER) EU Medical Device Regulations 12
B ISO 9001:2015 6.1.1 b - Enhance desirable effects - No opportunities were addressed ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
I DOE: High variance and small effects in Minitab Using Minitab Software 1
T How to Document Risk Effects on Design Change(s) ISO 14971 - Medical Device Risk Management 3
J Medical Device Failure Effects - Where to draw the line? FMEA and Control Plans 8
kedarg6500 Potential Effects of Failure(s) FMEA and Control Plans 23
J0anne Effects of Strengthened Surveillance of Notified Bodies in 2015 EU Medical Device Regulations 1
P UFMEA - Use Failure Mode Effects Analysis FMEA and Control Plans 7
Q Format to Evaluate the Effects of New Processes and Equipment Manufacturing and Related Processes 4
R Effects of Calibration Laboratory Temperature on Uncertainty Measurement Uncertainty (MU) 10
A Effects of categorical variables on single response Using Minitab Software 9
J Quality Management Process Model Possible Interactions and Effects ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
L "Half Normal Plot vs Normal Probability Plot" of Effects Using Minitab Software 1
R Drawing a Normal Plot of the Effects for Multilevel Factorial Design Using Minitab Software 3
E Laser Marking effects on the Fatigue Strength of Alloys CE Marking (Conformité Européene) / CB Scheme 6
A Function for Effects - Beginner in usage of the IQRM FMEA and Control Plans 3
M Corporate Procedures and their effects on Companies they Own Quality Manager and Management Related Issues 6
Q Documenting the Review of Adverse Effects from Rework ISO 13485:2016 - Medical Device Quality Management Systems 4
B Process FMEA (PFMEA) Same Multiple Causes for Different Effects FMEA and Control Plans 6
P Adverse Effects caused by Manufacturing Material of Medical Devices Manufacturing and Related Processes 4
R Are multi-faults needed? Effects of a Short Circuit IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
S Nylon Moisture Content - Transportation and Seasonal Effects Manufacturing and Related Processes 3
AnaMariaVR2 Effects of the Economic Downturn in Quality Systems & Quality in General Career and Occupation Discussions 9
G Effects of CMM Probe Tip Ball Size measuring a Round Part OD - CMM Help Inspection, Prints (Drawings), Testing, Sampling and Related Topics 18
R Effects of Dealing with Out of Tolerance Monitoring Equipment General Measurement Device and Calibration Topics 4
M New Directive MDD 2007/47 - What is the status and effects? EU Medical Device Regulations 7
D ITAR/EAR and effects on commercial Heat Treating AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
H Removing fixed effects (time demeaned variables) in Minitab Using Minitab Software 12
S Process Failure Mode Effects Analysis (PFMEA) Basics FMEA and Control Plans 4
M PAA (Process Assurance Assessment) vs. FMEA (Failure Modes and Effects Analysis) FMEA and Control Plans 3
Raffy Effects or Impact of Changes to ISO 17021 and Revision Status as of 16 NOV 2014 Other ISO and International Standards and European Regulations 25
J Effects of substrate on biological indicator organisms US Food and Drug Administration (FDA) 2
Q FMEA (Failure Modes and Effects Analysis) and Control Plan Process Diagrams FMEA and Control Plans 3
S What is the use of bar code? The Potential Effects of Missing Bar Code Labels FMEA and Control Plans 6
S Basic PFMEA (Process Failure Mode Effects and Analysis) Questions FMEA and Control Plans 22
T Standard for "Simulating Long Term Effects on Materials / Thermal Disinfecion" needed Other ISO and International Standards and European Regulations 3
T The Effects of Anodization on Pressure Impregnated Castings Manufacturing and Related Processes 3
R Should I be notifying the FDA of adverse effects (per 21 CFR 803)? ISO 13485:2016 - Medical Device Quality Management Systems 4
M Difference between potential failure mode and potential effects of failure FMEA and Control Plans 11
D ISO 14971 Risk Analysis - Effects of component failure on the patient ISO 14971 - Medical Device Risk Management 7
B Grain boundary effects in alloy depletion analysis - SAE AS7101 requirement AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
A How to organize DFMEA for Failures that have many Causes and Effects FMEA and Control Plans 2
F Quality Management System vs. Effects of Local Culture on Implementing a QMS Misc. Quality Assurance and Business Systems Related Topics 22
