Electrical Metrology (Source/Generation and Measurement)
fahimk
Hello
I am a beginner Metrologist. Can anybody help me understand difference between the Source/Generation and Measurement when it comes to stating the scope of electrical/frequency measurement in ranges etc?
Thanks.
dwperron
Hello
Thanks.
This has been a point of confusion for a long time. The folks at A2LA have a guidance document (G118) that you can download at their web site that helps explain scopes of accreditation. Here is what they say about Source vs. Measure in a scope of accreditation:
Use of the word “generate”, “measuring equipment” and “measure” on scopes of accreditation.
Scopes of accreditation, particularly in the electrical field, currently use the word “generate” to describe a laboratory’s ability to generate a quantity with a certain level of uncertainty. For example, “DC Volts – Generate” has been taken to mean that a laboratory can generate one or several multiples and/or submultiples of a volt and that its representation of this quantity is accurate to within the claimed level of uncertainty. Thus, laboratories with this capability can calibrate devices used to measure DC Volts.
Although this usage is most prevalent in electrical scopes of accreditation, the same idea is not extended to other disciplines where the inadequacy of this concept for describing a laboratory’s calibration capabilities would not be clear. As such, the use of the “generate” term is only currently used for the electrical and microwave/RF disciplines in scopes of accreditation. Other considerations will be made on a case-by case basis upon written request from the laboratory.
For areas other than the electrical field, the phrase “measuring equipment” is used to describe the laboratory’s ability to generate a quantity with a certain level of uncertainty. In all fields, the use of the word “measure” is used to describe the laboratory’s ability to measure a quantity with a certain level of uncertainty. The three terms “generate”, “measuring equipment” and “measure” are used to define the capability of the laboratory for a measurement parameter and thus clarify what types of instruments they can calibrate
B IVDR Electrical safety standard EU Medical Device Regulations 0
K Ground Bond Test for Class I Medical Electrical Equipment - calibration problems IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
F Recording Electrical Measurements ISO 17025 related Discussions 2
A Canadian Safety Labels for medical electrical equipment Canada Medical Device Regulations 2
D Electrical Medical Devices class I EU Medical Device Regulations 0
M NFPA 70 electrical harness questions Various Other Specifications, Standards, and related Requirements 2
V Laser Welding Process - Impact on Electrical Properties Reliability Analysis - Predictions, Testing and Standards 4
M ECG lead leakage currents - How to specify ECG leads during electrical safety testing IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
I When is necessary to have RoHS declaration on non-electrical parts? REACH and RoHS Conversations 1
S Battery powered device - electrical protection requirement IEC 60601 - Medical Electrical Equipment Safety Standards Series 18
JoCam Electrical Testing for Japan, PSE or CB Scheme Other Medical Device Regulations World-Wide 0
R Electrical contractor Project Quality Management Plan Quality Manager and Management Related Issues 1
A Regulatory requirements for electrical cosmetic appliances US Food and Drug Administration (FDA) 5
JoCam Mobile Patient Hoists and Electrical Testing Other Medical Device Related Standards 0
JoCam MDL in Canada without Canadian Electrical Testing Canada Medical Device Regulations 0
M Are Electrical Laparoscopic Surgical Devices ME equipment? IEC 60601 - Medical Electrical Equipment Safety Standards Series 8
J FDA wants electrical safety testing on battery powered medical device US Food and Drug Administration (FDA) 11
J EN61010 Electrical Withstand Test IEC 62304 - Medical Device Software Life Cycle Processes 0
L IEC 62368-1 / Electrical Energy Source vs. Power Source? CE Marking (Conformité Européene) / CB Scheme 2
P Scope of application for IEC 60601-1-11 Medical electrical equipment — Part 1-11 IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
B Marking of Medical Electrical equipment and accessories - Cl. 7.2.2 "Identification" and Cl. 7.2.4 "Accessories" IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
rezayatmand IEC 60601-2-18 Medical electrical equipment - Part 2-18: Particular requirements for the basic safety and essential performance of endoscopic equipmen IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
D Electrical Safety During Medical Device Development IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
M Routine testing of medical electrical systems - What specific electrical safety tests should be performed? IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
D CB Certificate - Distributor for a product with electrical components CE Marking (Conformité Européene) / CB Scheme 4
P Electrical Wiring Colours in Electrical Panel (Possibly EN 60446). Other ISO and International Standards and European Regulations 0
M Interesting Discussion Curious old drawings about electrical shock and safety IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
P CE Marking EN ISO 13849-1: Electrical Panel behind interlocked doors CE Marking (Conformité Européene) / CB Scheme 9
M Informational USFDA – Medical Devices; Anesthesiology Devices; Classification of the Ventilatory Electrical Impedance Tomograph Medical Device and FDA Regulations and Standards News 0
A True purpose of doing EST (Electrical Safety Test) on medical device Other Medical Device Related Standards 3
S IEC 60601-1 Electrical safety testing - Dielectric Strength Test - 8.8.3 IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
J IEC 60601-1 Electrical Safety testing - Class 1 ME externally powered - Earth resistance testing IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
E Multiple socket-outlets - Medical Device Electrical Equipment IEC 60601 - Medical Electrical Equipment Safety Standards Series 12
G Electrical Safety standard for medical device not covered by IEC 60601 IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
O EMC - EFT (Electrical Fast Transients) on SIP couples erroneously with other cable CE Marking (Conformité Européene) / CB Scheme 1
K Is a 3V torch classified as medical electrical equipment needing EMI/EMC testing? IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
R Room requirements for electrical tests in devices ISO 13485:2016 - Medical Device Quality Management Systems 2
R Electrical contact resistance testing in MIL-DTL-5541 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
C Electrical Power Plant Supply failure in PFMEAs FMEA and Control Plans 10
E Electrical safety (battery-powered medical device) EU Medical Device Regulations 1
JoCam Medical Device that is class II electrical and IEC 60601-1-11 EU Medical Device Regulations 5
T Requirements and standards for medical custom Electrical Connectors EU Medical Device Regulations 2
K Difference between Medical Electrical Equipment and Medical Equipment System IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
J CE Marking Requirements and IEC 60617 - Electrical Schematics Symbols CE Marking (Conformité Européene) / CB Scheme 1
L Medical Device Electrical Safety Standards - Gap Analysis of Latest Revisions Other ISO and International Standards and European Regulations 2
L Canada Electrical Equipment Marking Language Requirements IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
F Power Cord Length Issue - Medical Device Electrical Safety IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
J Pneumatic & Electrical Torque Tool - Calibration/Verification of 'Power Tools' General Measurement Device and Calibration Topics 2
M Electrical and Electromechanical Product CE Compliance with various Directives CE Marking (Conformité Européene) / CB Scheme 22
