Electrical Power Plant Supply failure in PFMEAs
Cephissus
Hello all,
Say we have a plant in Mexico, and once in a while there is power outage.
Must that be taken into consideration in PFMEAs? Or is it enough to cover it in contingency plans?
Thanks a lot!
Manuel
Hello all,
Thanks a lot!
Manuel
In general, the PFMEA should address potential failures that are intrinsic to the process in question. If we include things like power failures that affect the entire facility, we might as well include asteroid strikes. The contingency plan, if properly executed, should address what must happen in production in the event of whatever extrinsic phenomena might occur. It should be assumed that if power outages are recurring phenomena there are plans in place to deal with the potential results.
I have a slightly different take on this.
If the process is dependent on electrical power for important process functions, then power plant failures enter the FMEA as a cause of the process failure.
we have several critical processes where a power disruption (from whatever source) has catastrophic results on the product. we therefore put mitigations in place to reduce the occurrence of disruptions, robust against them, etc.
I don't think there's anything to be gained by including in the PFMEA potential causes that we have absolutely no control over. There are not very many manufacturing processes that don't depend on a consistent supply of electricity. That's why things like power outages and acts of nature that have a global effect are best dealt with in contingency plans. That's what contingency plans are for.
Jim - of course you can do and advise whatever you want, but my experience is quite different. I don't think about what I have direct control over but what can I mitigate or robust against or plan for. That mind set shift has resulted in substantial improvements in quality problems and other waste.
These actions never supplant "business contingency plans" but for some processes a power disruption - regardless of the source - is catastrophic.
Part of our product portfolio involves the manufacture of large batches of material that must maintain temperature and vacuum for extended periods of time and a disruption results in huge scrap costs, schedule effects and backorder. It can also cause stability concerns with our end product that can't be caught by release QC testing.
Some products must be kept at cold temperature during the manufacturing process as well as shipping and any disruption to that also causes scrap, stability concerns and potential notification to governing bodies. So instead of relying on the whims of mother nature and the god of electricity we take measures to maintain temperature in the face of an outage through other means than externally sourced electrical powered refrigeration. if we didn't we wouldn't survive as a business.
Golfman25
I think the difference is what the effect of power issues is on the product. For us, if the power goes out (used to happen quite often) everything stops. We clean up or get to all those things that have been "sitting there." When the power comes back up, we start up again. There is no affect on the parts we make. No different than stopping for lunch break or the night. Other processes may be more power affected.
I agree with Bev on this. The way it was posed by the OP was that this was a common event, not a rare event. Having worked at several companies that have facilities in Mexico, this is a familiar event to me also.
An analogous utility situation for me was air powered torque drivers. Periodically the plant air pressure would drop, which would cause the applied torque to drop also. While not proactively done, we added pressure regulators set below the level of the pressure drop, reset the torque drivers to work properly and added the issue and actions to our PFMEA for the future.
My current company makes a product line that protects against voltage sags, which account for about 70% of power disruptions. The point is that there are often ways to mitigate, if not eliminate, the risks.
outdoorsNW
How often is one and a while? If it is once a week, I think it should be included. Once a month, probably.
I think severity matters too. If a power failure (regardless of how often one occurs) may cause an event that would cause injury or worse, (severity of 9 or 10 in the AIAG scale), I think it needs to be included in the PFMEA.
Cephissus
Thank you everybody for your contribution and comments
If the frequency of the event can help determine inclusion or not, and settle the discussion between Jim and Bev, I might add that it happens normally only twice a year for only a couple of hours.
When asked, both the plant and the HQ Process Engineers are against including in the PFMEA. Our HQ Quality Assurance Supervisor is in favor of. I was looking for some FMEA guideline-inspired rule of thumb to help decide...
So far it seems it's still up for user's interpretation?
Cephissus
Also to take into account outdoorsNW comment: our product is not critical at all and as such no Severity exceeds 6 or 7 so far...
L IEC 62368-1 / Electrical Energy Source vs. Power Source? CE Marking (Conformité Européene) / CB Scheme 2
F Power Cord Length Issue - Medical Device Electrical Safety IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
J Pneumatic & Electrical Torque Tool - Calibration/Verification of 'Power Tools' General Measurement Device and Calibration Topics 3
A Inmetro Mark required on Electrical Power Cords? Other Medical Device Regulations World-Wide 1
J Define Energy Used/Delivered - Applicable to Electrical or Mechanical Power or both? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
M Electrical Power Quality Assurance Field - Any other folks here? Career and Occupation Discussions 4
Franky Zhang123 The Electrical Standards GB9706.1:2020 (same as IEC 60601-1:2012) etc. will be implemented on May 1st, 2023 in China. China Medical Device Regulations 0
K Electrical Safety Tester ISO 13485:2016 - Medical Device Quality Management Systems 7
pziemlewicz Electrical Engineer - Madison, Wisconsin Job Openings, Consulting and Employment Opportunities 0
K Brazil (INMETRO) for Medical Electrical and IVD Equipment? Other Medical Device Regulations World-Wide 4
F Quality Control in Electrical Calibration ISO 17025 related Discussions 0
Ed Panek Very Long Lead Times for Components (Electrical) Manufacturing and Related Processes 8
B IVDR Electrical safety standard EU Medical Device Regulations 0
K Ground Bond Test for Class I Medical Electrical Equipment - calibration problems IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
F Recording Electrical Measurements ISO 17025 related Discussions 2
A Canadian Safety Labels for medical electrical equipment Canada Medical Device Regulations 3
drwallice Electrical Medical Devices class I EU Medical Device Regulations 0
M NFPA 70 electrical harness questions Various Other Specifications, Standards, and related Requirements 2
V Laser Welding Process - Impact on Electrical Properties Reliability Analysis - Predictions, Testing and Standards 4
M ECG lead leakage currents - How to specify ECG leads during electrical safety testing IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
I When is necessary to have RoHS declaration on non-electrical parts? REACH and RoHS Conversations 1
S Battery powered device - electrical protection requirement IEC 60601 - Medical Electrical Equipment Safety Standards Series 18
JoCam Electrical Testing for Japan, PSE or CB Scheme Other Medical Device Regulations World-Wide 2
R Electrical contractor Project Quality Management Plan Quality Manager and Management Related Issues 1
A Regulatory requirements for electrical cosmetic appliances US Food and Drug Administration (FDA) 5
JoCam Mobile Patient Hoists and Electrical Testing Other Medical Device Related Standards 0
JoCam MDL in Canada without Canadian Electrical Testing Canada Medical Device Regulations 0
M Are Electrical Laparoscopic Surgical Devices ME equipment? IEC 60601 - Medical Electrical Equipment Safety Standards Series 8
J FDA wants electrical safety testing on battery powered medical device US Food and Drug Administration (FDA) 11
J EN61010 Electrical Withstand Test IEC 62304 - Medical Device Software Life Cycle Processes 0
P Scope of application for IEC 60601-1-11 Medical electrical equipment — Part 1-11 IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
F Electrical Metrology (Source/Generation and Measurement) General Measurement Device and Calibration Topics 1
B Marking of Medical Electrical equipment and accessories - Cl. 7.2.2 "Identification" and Cl. 7.2.4 "Accessories" IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
rezayatmand IEC 60601-2-18 Medical electrical equipment - Part 2-18: Particular requirements for the basic safety and essential performance of endoscopic equipmen IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
D Electrical Safety During Medical Device Development IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
M Routine testing of medical electrical systems - What specific electrical safety tests should be performed? IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
D CB Certificate - Distributor for a product with electrical components CE Marking (Conformité Européene) / CB Scheme 4
P Electrical Wiring Colours in Electrical Panel (Possibly EN 60446). Other ISO and International Standards and European Regulations 0
M Interesting Discussion Curious old drawings about electrical shock and safety IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
P CE Marking EN ISO 13849-1: Electrical Panel behind interlocked doors CE Marking (Conformité Européene) / CB Scheme 9
M Informational USFDA – Medical Devices; Anesthesiology Devices; Classification of the Ventilatory Electrical Impedance Tomograph Medical Device and FDA Regulations and Standards News 0
A True purpose of doing EST (Electrical Safety Test) on medical device Other Medical Device Related Standards 3
S IEC 60601-1 Electrical safety testing - Dielectric Strength Test - 8.8.3 IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
J IEC 60601-1 Electrical Safety testing - Class 1 ME externally powered - Earth resistance testing IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
E Multiple socket-outlets - Medical Device Electrical Equipment IEC 60601 - Medical Electrical Equipment Safety Standards Series 12
G Electrical Safety standard for medical device not covered by IEC 60601 IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
O EMC - EFT (Electrical Fast Transients) on SIP couples erroneously with other cable CE Marking (Conformité Européene) / CB Scheme 1
K Is a 3V torch classified as medical electrical equipment needing EMI/EMC testing? IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
R Room requirements for electrical tests in devices ISO 13485:2016 - Medical Device Quality Management Systems 2
