Electronic Approval Demonstration - Use of the voting option in Outlook
H
Howard Lee
At my local ASQ chapter I had asked about methods to do electronic approvals on documents and I have also seen some threads about electronic approvals here on the cove. Both places suggested the use of the voting option in Outlook to collect electronic approvals on documents.
I created a PowerPoint show to demonstrate an example of how I see Outlook being used to collect electronic approvals on documents. I would like to share it with the Cove and get opinions. What do you think of the attached presentation?
Craig H.
Re: Electronic Approval Demonstration
Howard, I have never even seen such a system (we use a canned solution) but I think I would have absolutely no problem using the new process, now that you have explained it. Good job!
N
noboxwine
Value-Added and Cost Effective ! How many of us have bought stand-alone software to manage this, when it was right in front of us the whole time !
Well Done :agree1:
H
Howard Lee
Well Done :agree1:
Thank you. I couldn't buy anything new and my goal was to create something workable with what we already owned. I have taken our entire QMS and saved all of the Word files as HTML files and indexed them so that they are all available on our internal Intranet and readable in Internet Explorer. It's workable but I hate that it is not automatic.
jradford
What version of outlook are you running? Does everyone need to be running the same version for the voting option to work? I am running Outlook 2000 and I don't see an option to add voting.
MIREGMGR
I assume you're running Exchange Server? If not, how are you handling backup of what would amount to a distributed system?
I've been told that Outlook implementations cannot be made revision-secure, i.e. documents can be changed by sufficiently knowledgable persons without any systemic record that the change has occurred. What are the community's thoughts regarding such a system for ISO 13485, in a context where FDA compliance isn't also needed?
H
Howard Lee
The approved documents are saved in a file accessable to the document manager and one or two other people and the revision level is stated in the subject line of the approval email as a matter of record.
Yes, I know it is cumbersome and there are massive holes in the execution, but it works on our simple level and it is cheap and paid for.
I would never try to suggest such a thing on a system concerning medical devices.
MeatDog
For several years now routing documents for approval has always been a thorn in my side & now, thanks to you I can route those same documents electronically to everyone who needs to see them & get their approval. And best of all I didn't have to purchase anything. Thank you again.
JaneB
It's a good way of doing it Howard - streamlines the process and makes it more likely you'll get responses, usually (though I urge the use of a 'respond by' date). I've used this kind of method in a few different systems.
I've also used the 'no response = approval" method (either in combination with the above, or alone): set a date deadline for responses, and state in the email 'if you do not respond by the due date, your silence will be taken as no objection & thus approval'. You need to put on the 'tracking option' (so you have a record that they did get the email, & keep those), but this has also worked quite well. Setting up an automatic rules filter in Outlook to filter & store the replies for you helps manage the process.
MeatDog
Something else that may be helpful. First I created a file named "Documents" in outlook, then I created a template in outlook & I put "Document for Approval:" in the subject line. Next I turned on the voting option & I had this e mail sent to my Documents file. And finally, just as JaneB stated I created a filter so that all replies with Document or Approval in the subject were sent to my Documents file. I am very early in my implementation of this but so far so good. Thanks again for everyone's input.
MeatDog
B Supplier Approval of electronic document storage service ISO 13485:2016 - Medical Device Quality Management Systems 8
shimonv The importance of NRTL Approval - Electronic Devices IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
I Electronic vs. Paper Copy Document Approval Process Document Control Systems, Procedures, Forms and Templates 9
T "Typing name on MS.Word directly" can be "Electronic Approval Signature" Document Control Systems, Procedures, Forms and Templates 3
Q Evidence of Approval in an Electronic Document Management System ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
K Electronic approval system - Fraudulently made electronic approval found Document Control Systems, Procedures, Forms and Templates 11
Q Should electronic copies of Procedures show the approval signatures? Document Control Systems, Procedures, Forms and Templates 5
T Managing approval of Level II procedures - Moving to Electronic Signatures Document Control Systems, Procedures, Forms and Templates 17
W Approval of Electronic Documents - How do we indicate "document approval"? Document Control Systems, Procedures, Forms and Templates 9
Marc Electronic Documentation Systems - Security, Approval and Editing Document Control Systems, Procedures, Forms and Templates 29
D Approval of a Single Electronic Document for Multiple Locations? Document Control Systems, Procedures, Forms and Templates 6
A Electronic forms QMS Document Control Systems, Procedures, Forms and Templates 7
S Reporting REACH - Electronic components distributor REACH and RoHS Conversations 5
K ISO 13485 and compliance of electronic signature ISO 13485:2016 - Medical Device Quality Management Systems 5
M MDR - eIFU - When you can supply an electronic IFU instead of a paper IFU EU Medical Device Regulations 5
D Advice on capturing electronic signatures ISO 13485:2016 - Medical Device Quality Management Systems 8
C Shelf life electronic components 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
C Cleaning of electronic transmitter Other Medical Device Related Standards 2
D Preservation of Electronic Data / Information Technology ISO 13485:2016 - Medical Device Quality Management Systems 5
Anonymous16-2 21 CFR Part 11 - Steps to take if we want to validate an electronic system Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 2
R Electronic and hand-written footnotes for GDP Document Control Systems, Procedures, Forms and Templates 1
A 21 CFR part 11 - section 11.100 - Electronic Signature Certification Other US Medical Device Regulations 6
qualprod From paper to Electronic (records) in the QMS ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
S FDA's E submitter - For clinical electronic thermometer Medical Device and FDA Regulations and Standards News 6
J Integrity of electronic digital records - Medical Devices ISO 13485:2016 - Medical Device Quality Management Systems 4
T Electronic ECO/ECR Process - Software recommendations Document Control Systems, Procedures, Forms and Templates 3
M Informational EU – DSVG 03 – Cardiac Implantable Electronic Devices (CIED) – Guidance on the vigilance system for CE-marked medical devices Medical Device and FDA Regulations and Standards News 0
D Benefits of electronic QMS software Software Quality Assurance 5
M Informational US FDA Draft Guidance – Providing Regulatory Submissions for Medical Devices in Electronic Format – Submissions Under Section 745A(b) of the Federal F Medical Device and FDA Regulations and Standards News 0
R Electronic handwritten signatures for approvals - Signed with a Stylus or a Finger Document Control Systems, Procedures, Forms and Templates 2
WEAVER Electronic Weighing Scale Calibration Tolerance Manufacturing and Related Processes 1
S ISO 10993 Biocompatibility Evaluation - Electronic thermometer Other Medical Device Related Standards 3
P FDA inspections and electronic signatures Other US Medical Device Regulations 2
S Need Assistance in Visual Inspection - Tiny electronic components AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
G Looking to move to an electronic QMS software Software Quality Assurance 11
QIE Electronic IFU - new project, need input Other Medical Device and Orthopedic Related Topics 0
U Electronic templates for making paper control charts Reliability Analysis - Predictions, Testing and Standards 2
M Informational USFDA – Radiological Health Regulations; Amendments to Records and Reports for Radiation Emitting Electronic Products; Amendments to Performance Stand Medical Device and FDA Regulations and Standards News 0
P Electronic component failure analysis turnaround time Reliability Analysis - Predictions, Testing and Standards 0
W Part Change Request - Standard (OTS) electronic parts (resistors, capacitors etc.) IATF 16949 - Automotive Quality Systems Standard 3
C In cases where users of an electronic system change their names Qualification and Validation (including 21 CFR Part 11) 6
A How a test flow can be build for a car electronic sunroof control Reliability Analysis - Predictions, Testing and Standards 6
M Electronic signature - name.lastname or equal to handwritten Document Control Systems, Procedures, Forms and Templates 3
N Electronic Instructions for use (eIFU) EU Medical Device Regulations 2
M Electronic Signature - Certificate Qualification and Validation (including 21 CFR Part 11) 8
I GMP 21 CFR Part 11 Electronic Records Compliance Project Help Qualification and Validation (including 21 CFR Part 11) 9
M Medical Device News FDA News - 12-09-18 - MD Submissions to Electronic Format to Improve Efficiency Other US Medical Device Regulations 0
Q Real Time Electronic SPC/Control Charting Statistical Analysis Tools, Techniques and SPC 4
M Suggestions for Electronic Signature Software (FDA 21 CFR Part 11 Compliant) Qualification and Validation (including 21 CFR Part 11) 12
