Electronic Document Control in a Company - Organization of Files
CottonS
What would you recommend or is there recommendation when it comes to ISO and AS? The manufacturing manager wants to place all forms (no matter what department) in on place, all work instructions/ procedures in one folder(no matter what department). I would not have such a problem if I can make a folder in that location for paint, one for production. Everything is hyper-linked on the master list, but I still need simplicity for floor team members if they are required to get to that place.
What are your preferences.
SteelMaiden
Folders are great things for organizing files, but, the more folders you have the harder it is to find and hyperlink documents, and the greater chance you have of missing links if documents get moved from one folder to another. In our last update of our document control system, a person managed to convince the majority of the team to put a very complicated folder system in place. Now they wish they had not done so. You can do a lot of your sorting with your naming conventions if you plan carefully.
Bogie
I prefer a folder for each general area (Sales, QA, Production etc). In one place I worked at, there were so many Production forms and procedures that we also had several area folders within the Production folder (a function of working in a job shop that made about a billion different parts using a gajillion different machines - hopefully this isn't a problem that you have).
I prefer not to have them all mishmashed into just one folder, but that is mostly because the part numbering and naming conventions in most places are so bad, that finding anything is a huge chore othewise. Also, if a person doesn't know the exact name of the procedure, but does know what area it concerns, they have a better chance of finding it and aren't calling me everytime they need to look at a procedure.
If you go with just one folder, I would suggest you take great care with your naming convention (and part numbering convention - if applicable) as that will help keep like items grouped together.
Bill Mitchell
The biggest complaint I hear is that most programs are overwhelming and not compatible with their current system.
A very simple system I have had customers rave about is EZQMS. I believe you can find this via the web.
And no I do not have any affiliation with this company. Just an honest recommendation per feedback.
E
esalsan
What about an internal wiki page? It works fine for us, and you can organize your links as you wish. Each interested department could even have their own space...
In our case, the hyperlinks in the wiki are always pointed to the latest published version in a software and web-based Document Management System so that you don't need to update wiki links when something changes. But I supose you could have all your controled documents in that one folder and point to them.
There are plenty of discussions about wikis, if you are interested, just make a search. Wiki
6thsense
Well I for one have had it with the Paper-full System in Place and I am planning to go electronic. If my salary improves that is notme:
I have tested KnowledgeTree (the free edition) and it works like a charm. You dont need much IT expertise to even get it up and running. It is available here http://www.knowledgetree.org
Instead of the ordinary folder list. You set access levels and has a decent login page, coupled to a revision history for the documents.
I suggest you try it.
Bill Mitchell
I will have to check this out. Am always looking for a simple system for clients.
hogheavenfarm
I too have reorganized our files which were all paper to electronic format for availability throughout the organization. I used three folders, all write protected, called "Controlled Forms", "Controlled Procedures", and "Controlled records". Someday I hope to implement a wiki style conversion from this, but it was a start for a dept. with no budget.
Within the folders, there are folders grouped by process, instead of departments, since I found to much overlap between various departments, and I didn't want to duplicate information. For instance, we have a "preproduction planning process", which covers all forms and procedures throughout from quoting to contract review to MRP. This way, all my processes closely conform to the ISO procedures, and all documentation is related and available in one place.
Helmut Jilling
Auditor / Consultant
Unless you are a very large company with hundreds of forms and docuemnts, the one folder approach for forms, and one for instructional documents, might make it easier for people to find what they are looking for. Finding electronic documents is the one hurdle, it has to be easy.
For records, and other docuemnts related to each process, I recommend one folder for each process you define in your QMS. That is the catch all for each department or process. But, I recommend forms all be in one, and many of my clients find that very clean and intuitive for people to use.
T Electronic Document Control - Posting a process at work station ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
D 21 CFR 11 Tools Validation - Electronic Document and Records Control Qualification and Validation (including 21 CFR Part 11) 5
R A simple electronic (software) document control question ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
M Computerised (Electronic) Document Control Insights Customer Complaints 1
C Process Mapping Electronic Document Control Software Recommendations Quality Tools, Improvement and Analysis 5
D Converting to Electronic Document Control - Procedure Content ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 19
D Electronic Document Control System suitable for TS 16949 Requirements Document Control Systems, Procedures, Forms and Templates 2
V Electronic Document Control Software suggestions wanted Document Control Systems, Procedures, Forms and Templates 14
V Electronic Document Control Sharepoint Questions Document Control Systems, Procedures, Forms and Templates 2
A Control of Document - Manual and Electronic Document Control Systems, Procedures, Forms and Templates 5
S Electronic Document Printing Restrictions and Access Control Document Control Systems, Procedures, Forms and Templates 4
F Looking for Electronic Document Control Software Quality Assurance and Compliance Software Tools and Solutions 14
M What is the best Electronic Document Control Management System? Document Control Systems, Procedures, Forms and Templates 46
C Document Control of Electronic Forms Document Control Systems, Procedures, Forms and Templates 6
D Document Control - How can I switch to electronic signatures? Document Control Systems, Procedures, Forms and Templates 12
I Electronic Document Control - How do we handle document signoffs? Document Control Systems, Procedures, Forms and Templates 8
N Anybody with experience with Sharepoint portal for electronic document control? Document Control Systems, Procedures, Forms and Templates 53
A What Electronic Document Control Software are you using? 'Canned' or In-House? Document Control Systems, Procedures, Forms and Templates 10
A The cost of document control - Electronic vs. Paper Document Control Systems, Procedures, Forms and Templates 20
J Electronic Document and Records Control Software Records and Data - Quality, Legal and Other Evidence 28
A Document Control: Controlling Electronic Email (E-mail) Document Control Systems, Procedures, Forms and Templates 7
A Document and Data Control - We are not satisfied with electronic document security Other ISO and International Standards and European Regulations 3
B Supplier Approval of electronic document storage service ISO 13485:2016 - Medical Device Quality Management Systems 8
P Converting DMF III into eCTD (Electronic Common Technical Document) Medical Information Technology, Medical Software and Health Informatics 4
I Electronic vs. Paper Copy Document Approval Process Document Control Systems, Procedures, Forms and Templates 9
Q Evidence of Approval in an Electronic Document Management System ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
R Electronic Document System - Compliance US Food and Drug Administration (FDA) 9
K Master Document List and Unalterable Electronic Forms ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
J Qumas as an EDM (Electronic Document Management System) Quality Manager and Management Related Issues 2
A 21 CFR part 11 compliant Electronic Document Management Systems Document Control Systems, Procedures, Forms and Templates 20
S Customized EDMS (Electronic Document Management System or ADMS) Document Control Systems, Procedures, Forms and Templates 4
K Document Approvals and 21 CFR 11 - Electronic signatures and approvals Qualification and Validation (including 21 CFR Part 11) 6
CalRich How to Document Review of Electronic Documents? Document Control Systems, Procedures, Forms and Templates 2
T Training on SOPs through our Electronic Document Management System ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
W Approval of Electronic Documents - How do we indicate "document approval"? Document Control Systems, Procedures, Forms and Templates 9
D Approval of a Single Electronic Document for Multiple Locations? Document Control Systems, Procedures, Forms and Templates 6
M Paperless Electronic Document and Records Systems Software Records and Data - Quality, Legal and Other Evidence 19
A Electronic forms QMS Document Control Systems, Procedures, Forms and Templates 7
S Reporting REACH - Electronic components distributor REACH and RoHS Conversations 5
K ISO 13485 and compliance of electronic signature ISO 13485:2016 - Medical Device Quality Management Systems 5
M MDR - eIFU - When you can supply an electronic IFU instead of a paper IFU EU Medical Device Regulations 5
D Advice on capturing electronic signatures ISO 13485:2016 - Medical Device Quality Management Systems 8
C Shelf life electronic components 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
C Cleaning of electronic transmitter Other Medical Device Related Standards 2
D Preservation of Electronic Data / Information Technology ISO 13485:2016 - Medical Device Quality Management Systems 5
Anonymous16-2 21 CFR Part 11 - Steps to take if we want to validate an electronic system Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 2
R Electronic and hand-written footnotes for GDP Document Control Systems, Procedures, Forms and Templates 1
A 21 CFR part 11 - section 11.100 - Electronic Signature Certification Other US Medical Device Regulations 6
qualprod From paper to Electronic (records) in the QMS ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
