Electronic signature - name.lastname or equal to handwritten
micheliAL
It´s ok to have only the name and the last name of the signer (and of course other information needed like hour, date...) or it needs to be equivalent handwritten signature...
What im trying to understand is... If i have some document only with my name Micheli Lermen printed... it will be enough? or do you recommend a data base of handwritten signatures, so when I electronic sign a document, this handwritten model will be printed with another relevant information...
I really think it´s a dumb question but is something that I´m trying to understand ...this FDA requirement:
Signed electronic records shall contain information associated with the signing that clearly indicates all of the
following:
• Printed name of signer
• Date and time of signature
• Meaning of signature (e.g., content is accurate, format is correct, data calculations were verified)
So...even with all of this bullets, i´ll still need something else... ?
Thank you in advance....
John Predmore
The FDA requirement for electronic signatures
CFR - Code of Federal Regulations Title 21
is more than what lettering appears on the document. Section 11.50(b) states “The items identified [above] shall be subject to the same controls as for electronic records. “ Subpart B covers controls of electronic records and subpart C covers more details for electronic signatures.
That means controls over who in the organization is authorized to create, affix, or alter an electronic signature on documented information. There may need to be robust electronic means for security and traceability, robust against phishing and hacking, to verify the source, time/date, intent, and integrity of the electronic signature. A database of signature facsimiles alone is probably not enough control.
micheliAL
Ok with this John...
My only point is...
it´s ok to electronic sign a document with the signature printed as MICHELI LERMEN
or there are a requirement established that says that we need the "handwritten signature as this attached...
Im saying this because we have a system that has stored all handwritten signatures, and when you print some document...the signature appears as this picture attached.... so .... instead of store the handwritten signature, it´s ok to use only the name of the approval like...JOHN DOE (not the signature)...in this case... ?
I didn´t find any restriction about this..
v9991
My only point is...
image of handwritten signature is not required and relevant; however it is not objectionable;
PART 11ELECTRONIC RECORDS; ELECTRONIC SIGNATURES
7) Electronic signature means a computer data compilation of any symbol or series of symbols executed, adopted, or authorized by an individual to be the legally binding equivalent of the individual's handwritten signature.
(1) Employ at least two distinct identification components such as an identification code and password.
(i) When an individual executes a series of signings during a single, continuous period of controlled system access, the first signing shall be executed using all electronic signature components; subsequent signings shall be executed using at least one electronic signature component that is only executable by, and designed to be used only by, the individual.
(ii) When an individual executes one or more signings not performed during a single, continuous period of controlled system access, each signing shall be executed using all of the electronic signature components.
Persons who use electronic signatures based upon use of identification codes in combination with passwords shall employ controls to ensure their security and integrity. Such controls shall include:
T "Typing name on MS.Word directly" can be "Electronic Approval Signature" Document Control Systems, Procedures, Forms and Templates 3
K ISO 13485 and compliance of electronic signature ISO 13485:2016 - Medical Device Quality Management Systems 5
A 21 CFR part 11 - section 11.100 - Electronic Signature Certification Other US Medical Device Regulations 6
M Electronic Signature - Certificate Qualification and Validation (including 21 CFR Part 11) 8
M Suggestions for Electronic Signature Software (FDA 21 CFR Part 11 Compliant) Qualification and Validation (including 21 CFR Part 11) 12
D 21 CFR Part 11 - Electronic Signature Management SOP Other US Medical Device Regulations 0
G Auto electronic signature on Calibration Form ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
C 21 CFR Part 11 - Electronic Signature Certification Other US Medical Device Regulations 13
S 21 CFR Part 820.198 - Complaint Files & Electronic Signature 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
D How to meet AS9100 Electronic Signature Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
J How to Link Electronic Records (510k Documents) to Handwritten Signature Other Medical Device Regulations World-Wide 16
D Electronic Signature Documents - FDA Requirements for Retention and Hardcopy Records and Data - Quality, Legal and Other Evidence 4
sagai Automated System's Signature on Electronic Record - PART11 Qualification and Validation (including 21 CFR Part 11) 4
J Electronic Signature Validation Protocol example or template Qualification and Validation (including 21 CFR Part 11) 2
K Question about paperless signature - Electronic signatures in outlook emails ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
S Is there an Electronic Signature standard? Various Other Specifications, Standards, and related Requirements 3
A Electronic forms QMS Document Control Systems, Procedures, Forms and Templates 7
S Reporting REACH - Electronic components distributor REACH and RoHS Conversations 5
M MDR - eIFU - When you can supply an electronic IFU instead of a paper IFU EU Medical Device Regulations 5
D Advice on capturing electronic signatures ISO 13485:2016 - Medical Device Quality Management Systems 8
C Shelf life electronic components 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
C Cleaning of electronic transmitter Other Medical Device Related Standards 2
D Preservation of Electronic Data / Information Technology ISO 13485:2016 - Medical Device Quality Management Systems 5
Anonymous16-2 21 CFR Part 11 - Steps to take if we want to validate an electronic system Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 2
R Electronic and hand-written footnotes for GDP Document Control Systems, Procedures, Forms and Templates 1
qualprod From paper to Electronic (records) in the QMS ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
S FDA's E submitter - For clinical electronic thermometer Medical Device and FDA Regulations and Standards News 6
J Integrity of electronic digital records - Medical Devices ISO 13485:2016 - Medical Device Quality Management Systems 4
T Electronic ECO/ECR Process - Software recommendations Document Control Systems, Procedures, Forms and Templates 3
M Informational EU – DSVG 03 – Cardiac Implantable Electronic Devices (CIED) – Guidance on the vigilance system for CE-marked medical devices Medical Device and FDA Regulations and Standards News 0
D Benefits of electronic QMS software Software Quality Assurance 5
M Informational US FDA Draft Guidance – Providing Regulatory Submissions for Medical Devices in Electronic Format – Submissions Under Section 745A(b) of the Federal F Medical Device and FDA Regulations and Standards News 0
R Electronic handwritten signatures for approvals - Signed with a Stylus or a Finger Document Control Systems, Procedures, Forms and Templates 2
WEAVER Electronic Weighing Scale Calibration Tolerance Manufacturing and Related Processes 1
S ISO 10993 Biocompatibility Evaluation - Electronic thermometer Other Medical Device Related Standards 3
P FDA inspections and electronic signatures Other US Medical Device Regulations 2
S Need Assistance in Visual Inspection - Tiny electronic components AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
G Looking to move to an electronic QMS software Software Quality Assurance 11
QIE Electronic IFU - new project, need input Other Medical Device and Orthopedic Related Topics 0
U Electronic templates for making paper control charts Reliability Analysis - Predictions, Testing and Standards 2
M Informational USFDA – Radiological Health Regulations; Amendments to Records and Reports for Radiation Emitting Electronic Products; Amendments to Performance Stand Medical Device and FDA Regulations and Standards News 0
P Electronic component failure analysis turnaround time Reliability Analysis - Predictions, Testing and Standards 0
W Part Change Request - Standard (OTS) electronic parts (resistors, capacitors etc.) IATF 16949 - Automotive Quality Systems Standard 3
C In cases where users of an electronic system change their names Qualification and Validation (including 21 CFR Part 11) 6
A How a test flow can be build for a car electronic sunroof control Reliability Analysis - Predictions, Testing and Standards 6
N Electronic Instructions for use (eIFU) EU Medical Device Regulations 2
I GMP 21 CFR Part 11 Electronic Records Compliance Project Help Qualification and Validation (including 21 CFR Part 11) 9
M Medical Device News FDA News - 12-09-18 - MD Submissions to Electronic Format to Improve Efficiency Other US Medical Device Regulations 0
Q Real Time Electronic SPC/Control Charting Statistical Analysis Tools, Techniques and SPC 4
