Electronic Signatures (21CFR Part 11) - Must They Appear on Printed Documents
fcowdery
We have just implemented a new tool (Oracle Agile) which allows for electronic signature sign off of documents within the application workflow.
However when we print the documents, the signature does not appear on the document.
Instead we are considering putting the following generic statement on each document:
[FONT=&quot]All approvals are maintained in the Document Control System. Refer to the Document Control System for the current controlled revision and approval records. Draft, archived, and obsolete revisions are not to be used. Access the Document Control system to verify revision.[/FONT]
Question: Must a replica of the electronic signature appear on the document itself once printed for use at point of use or does this statement satisfactorily replace the physical electronic signature and keep us in compliance with Annex 11 and 21CFR11.
Jen Kirley
Quality and Auditing Expert
Re: Electronic Signatures - Must They Appear on Printed Documents
Good day fcowdery,
The short answer is NO.
You don't state what standard you are referring to, but I can offer that none of the standards I work to require approval evidence on controlled documents as you've described. When I review approval of controlled documents I am happy to consider a range of options. Some clients keep a signed hard copy on file. Some use 2010 Microsoft Outlook's vote feature to record approvals, and leave no evidence of that approval on the document whatsoever; others use a proprietary software application to do the same thing.
In short, I am looking for approvals but they do not need to show up on the documents themselves.
I hope this helps!
W
WoodDuck
Hello flowery,
The name of the approved would need to be displayed on displayed and printed copies.
See paragraphs (a)(1) and (b) from 21 CFR 11 below.
Sec. 11.50 Signature manifestations.
(a) Signed electronic records shall contain information associated with the signing that clearly indicates all of the following:
(1) The printed name of the signer;
(2) The date and time when the signature was executed; and
(3) The meaning (such as review, approval, responsibility, or authorship) associated with the signature.
(b) The items identified in paragraphs (a)(1), (a)(2), and (a)(3) of this section shall be subject to the same controls as for electronic records and shall be included as part of any human readable form of the electronic record (such as electronic display or printout).
I've been told a system user name is acceptable in place of a persons legal name if there is a list on file which identifies the person's user name.
Regards,
Jim
fcowdery
Thank you Jennifer and WoodDuck for your responses.
Jennifer-
We are medical device manufacturer. We need to comply with ISO13485 and EU GMP Annex 11. Additionally, we need to comply with 21CFR820.40 and 21CFR11.
v9991
:applause:
in short, Yes you need to outline the above details of Electronic Signature in the approved document. Further more, pl. evaluate the approach to meet the requirements of 11.50(b) above.
btw,have you checked the options available(offered) by the software vendor?(Oracle Agile!)
whichever approach you take, it need to be supported through policy-verification-system-maintenance processes.
fcowdery
Thank you everyone for your responses.
V9991-
We have discuissed this issue with Agile integrator and were told for a 4-5 figure fee they would be able to customize (write a groovy script) our Agile Software. Being a small start up company, this is a big number for us to afford at moment.
Anyhow, than you all for the sound guidance.
MIREGMGR
I'm not directly familiar with Oracle Agile's implementation, but I'm very surprised that it might be thought to not be compliant with all of the major document and record control requirements. Have you asked your Oracle Agile representative--not the integrator, who has a financial motivation to decide that the system needs customization--to provide you with the regulatory validation documentation for the rules to which you are subject?
For ISO 13485 compliance, I want use a document change order process that lists all revised documents and relevant signatures. The change order cover sheet will be signed and the document revisions will be tied to the change order number.
Do printed documents need signatures in that case?
v9991
In short, Yes, Here's the reason.
and as per the 21 CFR part 11, any document/activity managed in electronic form to comply with predicate rule, shall comply with e-sign/e-record requirements.
in fact, all the changes pertaining to part 820 requirements you want to handle using the software.
http://www.accessdata.fda.gov/scripts/cdrh/cfdocs/cfcfr/CFRSearch.cfm?CFRPart=820&showFR=1
for eg., the above activity/document is relevant to following rule...
Subpart D--Document Controls
Sec. 820.40 Document controls.
(b)Document changes. Changes to documents shall be reviewed and approved by an individual(s) in the same function or organization that performed the original review and approval, unless specifically designated otherwise. Approved changes shall be communicated to the appropriate personnel in a timely manner. Each manufacturer shall maintain records of changes to documents. Change records shall include a description of the change, identification of the affected documents, the signature of the approving individual(s), the approval date, and when the change becomes effective.
hope this helps.
D Advice on capturing electronic signatures ISO 13485:2016 - Medical Device Quality Management Systems 8
R Electronic handwritten signatures for approvals - Signed with a Stylus or a Finger Document Control Systems, Procedures, Forms and Templates 2
P FDA inspections and electronic signatures Other US Medical Device Regulations 2
K 21 CFR Part 11 Biometrics for electronic signatures Other US Medical Device Regulations 2
S 21 CFR 11 - Require paper and hand signatures not electronic Other US Medical Device Regulations 2
J Unsigned Certification of Conformance (Electronic Signatures) Records and Data - Quality, Legal and Other Evidence 8
D FDA 21 CFR Part 11 Compliant Digital (electronic) Signatures Document Control Systems, Procedures, Forms and Templates 7
R 21 CFR Part 11: Electronic Signatures Qualification and Validation (including 21 CFR Part 11) 12
Ron Rompen Computerized Electronic Signatures on Inspection Records Records and Data - Quality, Legal and Other Evidence 8
M Original written signatures vs. Copies/scans/faxes/electronic documents US Food and Drug Administration (FDA) 24
I Could We use electronic signatures rather than manual sign offs? ISO 13485:2016 - Medical Device Quality Management Systems 8
K Question about paperless signature - Electronic signatures in outlook emails ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
K Document Approvals and 21 CFR 11 - Electronic signatures and approvals Qualification and Validation (including 21 CFR Part 11) 6
K Application of Electronic Records & Signatures in Calibration Management Software Document Control Systems, Procedures, Forms and Templates 0
M Date Stamping for Electronic signatures Qualification and Validation (including 21 CFR Part 11) 3
G Validation of Electronic Signatures on Multiple Servers Document Control Systems, Procedures, Forms and Templates 13
J 21 CFR Part 11 - Securing Electronic signatures using Adobe Acrobat Qualification and Validation (including 21 CFR Part 11) 1
Q Should electronic copies of Procedures show the approval signatures? Document Control Systems, Procedures, Forms and Templates 5
D Document Control - How can I switch to electronic signatures? Document Control Systems, Procedures, Forms and Templates 12
C Electronic Nonconformance and CAR signatures - Are actual signatures required? Document Control Systems, Procedures, Forms and Templates 2
J Electronic Signatures - We're trying 1" x 5" Digital Sign-on Pads Like UPS's Document Control Systems, Procedures, Forms and Templates 14
T Managing approval of Level II procedures - Moving to Electronic Signatures Document Control Systems, Procedures, Forms and Templates 17
Marc Electronic Records and Signatures - 21 CFR Part 11 Records and Data - Quality, Legal and Other Evidence 3
A Electronic forms QMS Document Control Systems, Procedures, Forms and Templates 7
S Reporting REACH - Electronic components distributor REACH and RoHS Conversations 5
K ISO 13485 and compliance of electronic signature ISO 13485:2016 - Medical Device Quality Management Systems 5
M MDR - eIFU - When you can supply an electronic IFU instead of a paper IFU EU Medical Device Regulations 5
C Shelf life electronic components 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
C Cleaning of electronic transmitter Other Medical Device Related Standards 2
D Preservation of Electronic Data / Information Technology ISO 13485:2016 - Medical Device Quality Management Systems 5
Anonymous16-2 21 CFR Part 11 - Steps to take if we want to validate an electronic system Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 2
R Electronic and hand-written footnotes for GDP Document Control Systems, Procedures, Forms and Templates 1
A 21 CFR part 11 - section 11.100 - Electronic Signature Certification Other US Medical Device Regulations 6
qualprod From paper to Electronic (records) in the QMS ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
S FDA's E submitter - For clinical electronic thermometer Medical Device and FDA Regulations and Standards News 6
J Integrity of electronic digital records - Medical Devices ISO 13485:2016 - Medical Device Quality Management Systems 4
T Electronic ECO/ECR Process - Software recommendations Document Control Systems, Procedures, Forms and Templates 3
M Informational EU – DSVG 03 – Cardiac Implantable Electronic Devices (CIED) – Guidance on the vigilance system for CE-marked medical devices Medical Device and FDA Regulations and Standards News 0
D Benefits of electronic QMS software Software Quality Assurance 5
M Informational US FDA Draft Guidance – Providing Regulatory Submissions for Medical Devices in Electronic Format – Submissions Under Section 745A(b) of the Federal F Medical Device and FDA Regulations and Standards News 0
WEAVER Electronic Weighing Scale Calibration Tolerance Manufacturing and Related Processes 1
S ISO 10993 Biocompatibility Evaluation - Electronic thermometer Other Medical Device Related Standards 3
S Need Assistance in Visual Inspection - Tiny electronic components AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
G Looking to move to an electronic QMS software Software Quality Assurance 11
QIE Electronic IFU - new project, need input Other Medical Device and Orthopedic Related Topics 1
U Electronic templates for making paper control charts Reliability Analysis - Predictions, Testing and Standards 2
M Informational USFDA – Radiological Health Regulations; Amendments to Records and Reports for Radiation Emitting Electronic Products; Amendments to Performance Stand Medical Device and FDA Regulations and Standards News 0
P Electronic component failure analysis turnaround time Reliability Analysis - Predictions, Testing and Standards 0
W Part Change Request - Standard (OTS) electronic parts (resistors, capacitors etc.) IATF 16949 - Automotive Quality Systems Standard 3
