WEAVER
We have a new Electronic Weighing Scale used for counting good products in order to check if there was no mixed defective as per machine count. My question would be how to provide calibration test points and tolerances (or should it be calibrated at all?) I have no process tolerance, only that the minimum weight of the product we count is about 7~8 mg., the resolution of the counter is 2 mg and the max is 150g. Minimum countable weight : 0.25 mg The users manual of the scale has a test weight calibration procedure where the weighing scale would have error alarm if the error reaches 1 percent at span calibration. Can I use 1 percent tolerance for the entire operating range and what would be my lowest test point? The exact model of the scale is VIBRA CUX150 .
I tried to read NIST handbook 44 but i can't understand it much, sorry
Thank you in advance, I don't know where else to ask
