Electronics Die Component - Military Standard 883 vs. MIL STD 750 TM2010 B.
Britman - 2012
Help required please.
Could any explain the term "die components" used in electronics.
We have a stated requirement in a contract for MIL STAN 883B standards, however a supplied C of C states visually & inspected to MIL STAN 750 TM2010 B.
Is this the same/replacement or two different standards?
Thanks for your help
You can go here for a copy of MIL-STD-883 and here for MIL-STD-750. You can download them and compare them for yourself. At a glance they look very similar. Note that the latest revisions for those standards are G and E, respectively, and you're apparently specifying the "B" revision of 883.
Regardless of the comparative applicability of the two documents, the supplier should be following your requirements. You'd think that if they saw a requirement for use of a long-superseded MIL standard, they would have asked for direction.
Al Rosen
The die in an Integrated Circuit is what the circuit components are etched or built into.
W
w_grunfeld
I am not sure what is the product you purchase , dies or a finished IC. A die is the piece of silicon or "chip" that is the "heart" of an IC.
MIL-STD-883 is a compendium of all inspections and tests required of an IC to be compiant to MIL-STD-883 (there aree several quality levels or classes)
One of the inspections required is visual inspection, some of it are according to mil-std-883 and some reference test methods from MIL-STD-750. The COC you refer to seems to be mixed up, as test method 2010 is part of MIL-STD-883, NOT 750. Here is the relevant section of MIL-STD-883:
"3.1 Examination. Internal visual examination as required in 3.1.1 through 3.1.9 shall be conducted on each SAW, hybrid/multichip microcircuit, or microwave hybrid microcircuit. The magnifications required for each inspection shall be those identified in the particular test method used (i.e., 2010, 2017, or 2032 of MIL-STD-883 and 2072, 2073 of MIL-STD-750).
3.1.1 Active and passive elements. All integrated circuit elements shall be examined in accordance with MIL-STD-883,method 2010.
Class H Class K
(Class level B Monolithic) (Class level S Monolithic)
Method 2010; Para. 3.1.1: Metallization defects.
Method 2010; Para. 3.1.2: Diffusion and passivation layer(s) faults.
Method 2010; Para. 3.1.3: Scribing and die defects.
Method 2010; Para. 3.2.5: Foreign material.
Method 2010; Para. 3.1.4: Glassivation defects.
Method 2010; Para 3.1.6: Film resistors defects.
Method 2010; Para. 3.1.7: Laser trimmed film resistor defects.
Transistor and semiconductor diode elements shall be examined in accordance with MIL-STD-883, method 2010 (paragraphs referenced above) or the identified paragraphs of MIL-STD-750, methods 2072 and 2073 as indicated below.
Passive elements (including substrates) shall be examined in accordance with MIL-STD-883, method 2032.Visual MIL-STD-750 MIL-STD-883
Inspection Method 2072 Method 2073 Method 2010...."
Hope this helps
Willy
R Through-Hole Electronics - Checking Lead Length Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
Q Weigh Scale Electronics - Suggested Storage Humidity and Temperature Manufacturing and Related Processes 7
J Medical Device Electronics - Secondary to output isolation for 1 MOPP IEC 60601 - Medical Electrical Equipment Safety Standards Series 9
J To Calibrate or not to calibrate electronics rack components Manufacturing and Related Processes 5
S Number of MOPP for Type BF Applied Part (Medical Device Electronics) IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
G Looking for a Metrology Course preferably Dimensional and Electronics Training - Internal, External, Online and Distance Learning 5
V New on Electronics Instrumentation - Looking for tutorials Training - Internal, External, Online and Distance Learning 1
S New Electronics Manufacturing Setup - Checklist/Gantt chart Manufacturing and Related Processes 4
E Quality Techucuan (Technician) in Electronics - Defining Postion Requirements Career and Occupation Discussions 4
J Medical Device with Electronics Functions Other Medical Device Related Standards 3
L Customer requies 'Jet Test' on a Car Part (Electronics Connectors) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
B Query on Medical Device Electronics RoHS Certificate Statement RoHS, REACH, ELV, IMDS and Restricted Substances 3
Q Change of fields - Quality Engineering Electronics Vs medical Devices Career and Occupation Discussions 20
Q Conflict Minerals Reporting for Electronics Manufacturing AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
H Marking Compliance for Consumer Electronics Products and Gadgets CE Marking (Conformité Européene) / CB Scheme 2
1 China CM's (Contract Manufacturer) for Electronics Manufacturing and Related Processes 6
S Electronics Manufacturing Industry Standards Manufacturing and Related Processes 5
S Example Business Agreement for Electronics Mfg. Services Provider? Contract Review Process 2
S Root Cause Determination of Epoxy Encapsulated Electronics Modules Nonconformance and Corrective Action 8
J Looking for reference to Electronics Industry's Standard Scrap Rates ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
C Hazards of Old Electronics Quality Manager and Management Related Issues 9
Q Quality System followed/executed in the Consumer Electronics Industry Various Other Specifications, Standards, and related Requirements 3
JoCam EASA Regulatory Requirements for Electronics Contract Manufacturer AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
Hami812 Question on Cycle time for Repair of Electronics Products Lean in Manufacturing and Service Industries 3
A EU vs. Canada Electronics Recycling (WEEE) Plan Canada Medical Device Regulations 2
W Cost of Quality - Electronics Manufacturing The Reading Room 14
S Effects of Irradiation Sterilization on Medical Electronics - Li Coin Cell Batteries IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
Q Process and Part Qualifications - Automotive Industry and Consumer Electronics IATF 16949 - Automotive Quality Systems Standard 12
G Component IMDS for an Electronics Contract Manufacturer RoHS, REACH, ELV, IMDS and Restricted Substances 6
L Approval Process for Approbation of Alternates in the Electronics Industry ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
S Test Philosophy for Electronics Supplier Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
R Silicone in Hand Lotion in Electronics Manufacturing Manufacturing and Related Processes 4
G SCEM (Sub Contract Electronics Manufacturer) Audit ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
R Cost of Quality Benchmarking Information for the Electronics Industry Benchmarking 1
Q Career Switch - Aerospace and Medical Devices to Automotive and Consumer Electronics Career and Occupation Discussions 3
K Use of Vacuum Pens to hold SMT Components in Electronics Industry Manufacturing and Related Processes 3
P PCB (Printed Circuit Board)/Electronics Inspection Training? IPC-A-610? Career and Occupation Discussions 10
Q Using ROHS Components in Military Electronics Products RoHS, REACH, ELV, IMDS and Restricted Substances 6
S Searching for applicable Standards for a Medical Device using electronics, software Other Medical Device Related Standards 11
T Design Plan for use in our Engineering Department - Aviation Electronics Document Control Systems, Procedures, Forms and Templates 2
Icy Mountain Alcohol Based Hand Sanitizers in Electronics Manufacturing Manufacturing and Related Processes 10
E Environmental Screening of PCBAs in High Volume Electronics Contract Manufacturing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
V PPAP for electronics - What do we have to require for PCB compare to mechanical parts APQP and PPAP 4
H Traceability in Electronics Assembly Manufacturing and Related Processes 11
S NPI (New Product Introduction) in Electronics Industries Document Control Systems, Procedures, Forms and Templates 10
A How to Implement PLM on Compliance Management of Electronics Parts RoHS, REACH, ELV, IMDS and Restricted Substances 5
Q FMEA Scaling - Both D and P FMEAs' in Electronics Manufacturing FMEA and Control Plans 2
A Exclusion of Purchasing Process - Consumer Electronics Product Design House Design and Development of Products and Processes 1
M Environmental Impact of Lead in Electronics Production Miscellaneous Environmental Standards and EMS Related Discussions 15
M Looking for Electronics Hands on Training Material - ESD, Comp ID, Soldering, etc Training - Internal, External, Online and Distance Learning 8
