Electrosurgery Emission Compatibility - Patient monitoring equipment
royal77
We are developing a patient monitoring equipment(ECG, NIBP) which we intend to use along with Electrosurgery equipment. As per 60601-2-27 (ECG) and 60601-2-30 (NIBP) standards, we need to meet a couple of testsfor Electr-surgery compatibility. And we are complying with these tests. These standards also have 60601-2-2 (HF surgical equipment) as normative reference. In 60601-2-2 standard, some tests are given as guidance tests in annexure (Anex-BB) which manufacturer can use to check compatibility with the emissions from Electrosurgical equipments.
I was told that, we have to mandatorily qualify these tests also in order to comply with Electr-surgery compatibility. Can anybody provide information on whether these tests are mandatory or voluntary for complaince.
Marc
Can any medical device folks here help with this one? My Thanks in advance!
Peter Selvey
In modern regulations, there are no mandatory standards, but you would have to justify if you don't comply with a harmonised or recognised standard. This might be tough to do for some subjects.
However, there is some conflicting information in the particulars on this subject that might be sufficient evidence to say that protection is optional (for reference, I have been heavily involved in the assessment of patient monitors for CB scheme, MDD and voluntary test reports, and I am working on equipment for testing against particulars like IEC 60601-2-27, IEC 60601-2-30 etc, if you are interested in information on, for example, pacemaker related tests, let me know via the contact section).
Note that new term for electrosugery is "HF surgical equipment"; all IEC based standards are being updated to use this term, but I will use "ESU".
The summary as I can see is:
IEC 60601-2-27:2005 (ECG) states that you must have protection against ESU noise; normal operation should resume normal operation within 10s. The draft standard (2009) does not change this aspect.
IEC 60601-2-30:1999 (NIBP) says this is optional, if claimed you test, using the same test as in IEC 60601-2-27. This standard has been replaced (IEC 80601-2-30:2009, not yet recognised in regulations), but the new standard is unchanged for this point.
IEC 60601-2-34:2005 (IBP) says again optional; if claimed, test (10s return).
IEC 60601-2-49:2001 (patient monitor) has no requirement. A new draft standard (dated 2009) has again the optional 10s recovery test.
ISO 9919:2005 (SpO2) has no requirement in this regard.
EN 12470-4:2000 (Temp) has no requirement for ESU noise.
So, all the standards apart from IEC 60601-2-27 refer to this as optional, or have no requirement. I do not know why IEC 60601-2-27 is "mandatory" and it makes no sense that one function of a multiparameter monitor must withstand ESU noise, but other functions are optional.
I also know that most patient monitor manufacturers have optional ECG cables (ESU type, non-ESU type), the ESU type having series inductors to limit HF currents (e.g. 400kHz and above). It could be interpreted that the non-ESU types might be illegal in Europe, but as far as I am aware, they are still being sold.
Finally note that ESU noise immunity is only one aspect. Protection against ESU burns is also important. This appears to be optional in all standards (including IEC 60601-2-27); but there is no test for this. If you are interested I can suggest tests based on IEC 60601-2-2 that would show your equipment restricts HF current to below, say 50mA @ 400kHz, which should be more than enough to limit the risk of burns.
Hope this helps - Peter
royal77
Thankyou for your elaborate reply.
Actually, we do have input impedance to restrict from defibrillation and HF surgery currents. I am not sure if we have done some testing regarding that. I request you to please suggest the test from -2-2 to make sure that the protection is sufficient. I understand that this is also a voluntrary test.
Also, can you please clarify that, if we want to claim compatibility with HF surgical equipment and if we want to add this statement as part of the IFU (user manual), then whether we should mandatorily comply with the tests given in Annexure-BB (involving using an actual generator and wrapping the cord of the monopolar hf surgical instrument: 1) around the enclosure of the equipment being tested, 2) around the power cord and 3) around the accessory cables).
Thanks for your time and suggestions.
Peter Selvey
For a test for burns, I would need to prepare some research and diagrams, so out of the scope of this thread - can you contact me directly at "peter.selvey(at)medteq.jp"
The testing specified in Annex BB of IEC 60601-2-2:2006 is informative, so it has no mandatory basis. However, under the MDD (for example), if you claim compatibility with HF surgical equipment, you would still need to have to evidence to back the claim; this would almost certainly involve some kind of verification testing with a real ESU. In the absence of a standard, Annex BB makes sense.
Note that test results can be highly dependent on the HF surgical equipment used. Valleylab, for example, produce a high quality stable output with fewer harmonics, whereas lower cost ESU manufacturers outputs are extremely noisy, unstable and unpredictable. I would use Valleylab, on the grounds that there is also an obligation on the ESU side to limit the noise as far as possible.
royal77
Thankyou for your suggestions.
I will suggest my team to verify the tests given in 60601-2-2 and have the record. I will confirm if the tests against burns are already done or not and contact you if required at your email.
K FDA 510k electrosurgery 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
A Electrosurgery interference equipment requirements IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
R Electrosurgery Immunity Testing IEC 60601 - Medical Electrical Equipment Safety Standards Series 8
S IEC 60601-1-2 Radiated E-Field Emission Testing - Diagnostic ECG device IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
A EMC Emission Issues - Communication between PC and Monitor IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
B Mitigation of emission of flames, molten metal, poisonous or ignitable substance IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
C Uncertainty Estimation for Spark Optical Emission Device Measurement Uncertainty (MU) 1
R Optical Emission Spectrometer Calibration General Measurement Device and Calibration Topics 0
R EMS Programme Target is Reduction in CO2 Emission Miscellaneous Environmental Standards and EMS Related Discussions 5
T Optical Emission Spectrometer Calibration to a National or International Standard Various Other Specifications, Standards, and related Requirements 4
W Who can do a noise emission test for us? CE Marking (Conformité Européene) / CB Scheme 3
R Compatibility studies for Combination Products - Europe Medical Device and FDA Regulations and Standards News 2
R Compatibility studies - combination product CE Marking (Conformité Européene) / CB Scheme 4
R Compatibility studies - Medicinal Product and Medical Device Other ISO and International Standards and European Regulations 0
S Medical Device MRI Compatibility EU Medical Device Regulations 3
T Submitting MR Compatibility Data for 510(k) Cleared Device Other Medical Device and Orthopedic Related Topics 2
A Compatibility between MDD and MDR devices EU Medical Device Regulations 7
K Electromagnetic Compatibility Test IEC 60601-1-2: 2014 IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
E IEC 60601-1-2 compliance for accessories - Electromagnetic compatibility of the ME system IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
S Testing an equipment for MRI Compatibility Other US Medical Device Regulations 3
K Class II Medical Device Compatibility Issue - Removal or Market withdrawal? US Food and Drug Administration (FDA) 2
F EMC (Electromagnetic Compatibility) Conformity Charts - IFU Requirements Misc. Quality Assurance and Business Systems Related Topics 3
K Interpretation of IEC 60601-1-2 Electromagnetic Compatibility – Requirements & tests IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
C Compatibility of a Class II exempted accessory with a Class III device US Food and Drug Administration (FDA) 1
J Plastic Compatibility tests with the contact of mucous membranes Other Medical Device Regulations World-Wide 3
B Titanium Implants MR (Magnetic Resonance) Compatibility Labeling US Food and Drug Administration (FDA) 2
R How to deal with the RM requirement of clause 17 Electromagnetic Compatibility? IEC 60601 - Medical Electrical Equipment Safety Standards Series 8
B Should EMC (Electromagnetic Compatibility) Testing be performed In-House CE Marking (Conformité Européene) / CB Scheme 10
J EMC (Electromagnetic Compatibility) Requirements - IEC 60601 3rd edition Clause 17 IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
R Quality Assurance procedures for EMC (Electromagnetic Compatibility) Compliance CE Marking (Conformité Européene) / CB Scheme 4
J ISO 10993 (Biological Compatibility) Approved Materials US Food and Drug Administration (FDA) 23
Y MRI Compatibility - Electrical Device with a Video Display Other Medical Device and Orthopedic Related Topics 1
M Compatibility and Analogues Materials US Food and Drug Administration (FDA) 2
S Materials Compatibility in ISO 8185:2007 - Respiratory Tract Humidifiers IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
somashekar Material Compatibility - PVC (halogenated polymers) and Santoprene (TPE) Manufacturing and Related Processes 4
D Definition What does cultural compatibility mean? Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 9
S Construction Projects - Client & contractor - System compatibility issues Quality Manager and Management Related Issues 4
kedarg6500 "Cultural compatibility" EFQM excellence model Various Other Specifications, Standards, and related Requirements 1
4 Design help needed - Isoflurane compatibility with polymers - Anesthesia gas Design and Development of Products and Processes 6
S ISO14001 and TS16949 "Compatibility" vs. Audit Day Requirements IATF 16949 - Automotive Quality Systems Standard 7
