Electrosurgical Testing - Is there a specific standard for Electrosurgical Testing?
N
nikolaos
Hello All,
I plan to test a medical autotransfusion medical device for immunity against electrosurgical. Is there a specific standard for this? Can someone advice me how to perform this test?
Thank you
SteveK
Re: Electrosurgical testing - Is there a specific standard for this?
There are an awful lot of standards based around EN (or IEC) 60601. Maybe EN 60601-2-24 "Medical electrical equipment - Part 2-24: Particular requirements for the safety of infusion pumps and contollers" might meet your requirements. Not read it, got the list of Harmonized Standards from: http://ec.europa.en/enterprise/newapproach/standardization/harmstds/reflist/meddevic.html.
There is the overall standard EN 60601-1 "Medical electrical equipment; Part 1: General requirements for basic safety and essential performance".:2cents:
N
nikolaos
Thank you, I haven't find any specific standard till now. Immunity tests according the EMC standard 60601-1-2 are simulated in the EMC Labs to rappresent the real world. What I am searching for is how to do the immunity test with an electrosurgical device a verify the immunity of the medical device. To my knowledge there ie no test the simulate the radiated electrosurgical emissions, so a real electrosurgical device must be used.
Marcelo
There´s no standard for this.
Anyway, you´re right in using a real electrosurgical device. Some standards in the IEC 60601-1 even requires this, that is, that you use a real electrosurgical unit (i just cannot remember exactly which ones right now).
AAMI has a document, "Guidance on electromagnetic compatibility (EMC) of medical devices to assist clinical engineers and other biomedical personnel in evaluation of the radiated frequency (RF) electromagnetic environment in health care facilities", which might have some info, but i´ve never seen it, so i´m not sure it can help.
N
nikolaos
Re: Electrosurgical Testing - Is there a specific standard for Electrosurgical Testin
Thank you for the link. I found a preview copy of the AAMI TIR18:1997 but ther is no mention to an electrosurgical generator in the index. Anyway I performed the test and the result was positive, no interference. I used a 400W generator with a frequncy of 475Khz with an electrosurgical analyzer where I connected the electrodes to simulate the patient. I tested 5 times with 30sec of duration and checked for the essential performance of the medical device that was functioning in normal operation. The mediacal device was about 30cm from the electrosurgical electrodes. What do you think? Can this test be realistic?
Peter Selvey
There are some of particular standards that specify testing for immunity against electrosurgical units (ESUs).
An example is IEC 60601-2-27:2005 (ECG, monitoring), Clause 36.202.101. That standard specifies a 300W cut and 100W coag mode (both with 400kHz +/- 10% fundamentals).
A critical point is that they specify that an arc is drawn between the active electrode and a metal block which simulates real world (ESU are typically used in this way, with an arc).
It is the high frequency content of the arc (well above 400kHz) that is likely to cause the most disturbance. It is a bit unpredictable, which is why the standard requires to repeat the test 5 times cut mode + 5 times in the coag mode.
The ESU should be tested with a special high power non-inductive test load (e.g. 200-500 ohms, 300W thick film resistors), since just shorting the electrodes will probably trigger the ESUs short circuit protection so that nothing is coming out.
And finally you need to simulate electrical connection between the ESU and your infusion device (assuming we are talking here about ESU operation on the same patient that is being infused), and the return path. Note that this is not expected to be a radiated issue, but rather conducted problem through the fluid circuit. IEC 60601-2-27 includes a circuit for this appropriate for ECGs, and this could be adapted for an infusion circuit. I would go for saline fluid with the minimum length of tubing, with the patient simulated by an electrode in the fluid at the end of the tubing. This electrode would connect to one pole of the ESU test load. IEC 60601-2-27 then specifies a 47nF capacitor (should be a HV type) which should also connected between the other pole and earth. I cannot see any reason why you would not use the same value.
Having written all the above, it also seems clear that this might be difficult to set up without some hands on experience with ESUs. On the other hand, better to do it properly, especially if you are going to claim ESU immunity as part of your intended purpose or advertising material.
P Electrosurgical Device User Need: Cord Flexibility -> Requirement Other Medical Device and Orthopedic Related Topics 4
N Electrosurgical generator with switchable sockets - creepage IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
W Electrosurgical devices/surgery IFU contraindications EU Medical Device Regulations 2
M Electrosurgical Electrodes - Stability Test Other Medical Device Related Standards 1
S Defibrillator Requirement for ME Equipment connected to HF Electrosurgical Generator IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
K IEC60601 3rd Edition Insulation Thickness for electrosurgical devices IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
A Accuracy for electrosurgical analyzer General Measurement Device and Calibration Topics 2
H Clinical Evaluation Template for an Electrosurgical Device or Accessory Document Control Systems, Procedures, Forms and Templates 2
W EN 61000-4-4:2004 Compliance - Electrosurgical Unit Transient Voltage Pulse EU Medical Device Regulations 3
M Classification rules for Canada - Electrosurgical and Cryosurgical Equipment ISO 13485:2016 - Medical Device Quality Management Systems 8
E 60601-1 - Tilt testing - Tensile safety factor IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
V Setup for testing against ISO14708 clause 16 (protection of the patient from herms caused by heat) Other Medical Device Related Standards 0
gramps What do you think about automated QA testing For software app industry? Misc. Quality Assurance and Business Systems Related Topics 5
B In house NIOSH pre Testing accepted by NIOSH? US Food and Drug Administration (FDA) 1
M Bacteriostasis/Fungistasis Testing Other Medical Device and Orthopedic Related Topics 6
P Sample Size for Distribution Simulation Testing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 11
N EN 813, EN 12277, EN 1497 - Testing some harness prototypes to an EN standard Various Other Specifications, Standards, and related Requirements 0
D Essential performance and EMC immunity testing IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
J Biocompatbility testing on Class 1 device requirements Other US Medical Device Regulations 12
Q Summative Usability Evaluation Testing: prior or during Clinical Investigation? Human Factors and Ergonomics in Engineering 6
B NIOSH Approval for Surgical N95 Respirators - Required testing US Food and Drug Administration (FDA) 2
M ECG lead leakage currents - How to specify ECG leads during electrical safety testing IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
C Stress / Challenge Conditions for Design Verification Testing to Reduce Sample Size 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 11
D CFR Title 14: Aeronautics and Space PART 120—DRUG AND ALCOHOL TESTING PROGRAM Federal Aviation Administration (FAA) Standards and Requirements 3
lanley liao Purchase Acceptance Criteria - Tensile testing Oil and Gas Industry Standards and Regulations 2
M Device mounted at IV pole - what about mechanical stability testing? IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
A Outsourcing IEC 60601-1 Ed 3.2 Testing IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
J Cochlear Implant Testing 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
A Class I (exempt) testing requirements Other Medical Device Related Standards 0
JoCam Electrical Testing for Japan, PSE or CB Scheme Other Medical Device Regulations World-Wide 0
M Who are the go to companies for non-destructive hardness testing? General Measurement Device and Calibration Topics 3
P Testing cloud-based backups IT (Information Technology) Service Management 7
I IATF Lab Scope Testing Qualification and Competency Documentation IATF 16949 - Automotive Quality Systems Standard 3
N Chemical Testing on Medical Devices - Solutions in a container closure system (bag) EU Medical Device Regulations 1
M Comparing data from destructive testing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
T Flammability testing Reliability Analysis - Predictions, Testing and Standards 0
E Manufacturers should develop a testing device for covid19 Service Industry Specific Topics 0
K When is Bioburden Testing Required? Other Medical Device Related Standards 4
K IEC 62304 - Testing Independance IEC 62304 - Medical Device Software Life Cycle Processes 5
A ANSI/AAMI versions of 60601-1-2 and related testing requirements Other Medical Device Related Standards 3
C Surgical mask stability testing (CE mark) EU Medical Device Regulations 2
Beliz Biocompatibility Testing for Laser Epilation Device EU Medical Device Regulations 2
C One Time Service Supplier - Temperature and Humidity Testing Service ISO 13485:2016 - Medical Device Quality Management Systems 5
D IEC 60601-1 - Service life testing IEC 60601 - Medical Electrical Equipment Safety Standards Series 8
P Flammability Testing of Aircraft Interior Materials Federal Aviation Administration (FAA) Standards and Requirements 0
N Usability testing required for FDA IDE (investigational device exemption)? Human Factors and Ergonomics in Engineering 8
E ASTM F2118 - Fatigue testing of bone cement - Changes between the 2003 and the 2014? Other Medical Device Related Standards 1
K Biocompatibility Testing - Multile products of different sizes and shapes US Food and Drug Administration (FDA) 2
