Emphasizing Severity more than Occurrence and Detection vs. Overall RPN
V
vanputten
Has anyone heard about the auto industry (or specific auto manufacturers) placing emphasis on the Severity score and not the overall Risk Priority Number (severity x occurrence x detection)?
It was suggested to our organization to determine action plans based on severity only and not the overall RPN.
Thank you,
Dirk
errhine
Involved - Posts
Re: Emphasizing Severity more than Occurrence and Detection
Those in the auto industry that I know will only use RPN. Even if you have a severity of 10, if you almost always detect that failure, and it almost never occurs, it would be foolish to spend increasing amounts of money to try to reduce a severity. You would be better off to reduce your occurrences and increase detection of less severe items (given a high RPN). Thats the whole point of the FMEA.
Al Rosen
How can you reduce severity?
Stijloor
Thank you,
Dirk
Hello Dirk,
That's correct. There's too much emphasis on RPN. That can be very misleading. RPN is a simple multiplication of 3 numbers. Each of the numbers (rankings) has a distinct meaning. In terms of prioritizing what actions to take? One OEM (Ford) recommends to go after Severity first. See if a design change can reduce severity. Next, look at Severity x Occurrence. Finally look at remaining RPN's.
Sadly, some automotive suppliers play an RPN numbers game. They develop an FMEA procedure, state that below an RPN of 100, no further action is required. Guess what I see on their FMEA's? Exactly! No RPN above 100.
Upon PPAP submission, often no response from the customer. And so it goes. Another worthless document for a PPAP "package." :mad:
Stijloor.
Stijloor
Hello Al,
Through a design change; although this may not always be feasible. But trying to reduce severity is the first "order of business" when designing a product and/or process.
Stijloor.
Thank you,
Dirk
I have seen one prioritization scheme that had three categories:
  • Priority 1 = Safety (Severity ratings of 9 or 10)
  • Priority 2 = Warranty (Severity rating of 6 - 8 with an Occurrence rating > 5 and a Detection rating > 3)
  • Priority 3 = Top 5 RPNs remaining after Priority 1 and 2 have been addressed
I incorporated it into our FMEA process and liked it. Never had any audit issues regarding it either.
V
vanputten
Thank you everyone. This is great information.
Has anyone performed FMEA's using both the customer and consumer in ranking Severity as suggested by the 4th edition of the PPAP manual?
Thank you,
Dirk
someshvar
Can anyone tell me how would you reduce severity for a said failure mode?
As per best of my knowledge even if you improve the design, you can reduce occurrence and not severity.
I am looking forward to serious discussion as to how would you reduce the severity.
Thanks and regards,
Hardik Someshvar
Thanks and regards,
Hardik Someshvar
You can change a design to eliminate the failure mode entirely, or by adding a backup.
An example would be a bonded metal to rubber engine mount. Most modern designs include a mechanical interlock such that if the rubber fails (e.g., tears, delaminates from metal, etc.) the metal components keep the engine from dropping.
The severity changes from engine falls to pavement to harsh vibration and noise. A clear drop in severity.
Thanks and regards,
Hardik Someshvar
Any design improvement that reduces risk of injury (for example) would likely reduce the severity factor. I understand the confusion; it stems from the idea that if some phenomenon x has an explicit risk of y, no matter what you do, the phenomenon as defined will have the same degree of risk. Reduction in the severity factor assumes that the problem will be redefined such that the former condition has been reasonably mitigated. Think of automobile airbags as an example. The risk of serious injury inherent in the pre-airbag design is significantly mitigated by introduction of the airbag, thus a reduction of the severity factor would be justified. This doesn't mean that the risk in a car without airbags has changed, however.
R DFMEA/PFMEA mitigation of high severity (9-10) in low volume products IATF 16949 - Automotive Quality Systems Standard 1
silentmonkey How to measure severity if my product is designed for emergency use and failure would result in death? ISO 14971 - Medical Device Risk Management 9
S The Severity of a Medical Device Hazard - Risk Analysis Clarification ISO 14971 - Medical Device Risk Management 6
MrTetris Informational Risk Register - Same hazardous situation, different severity of harms ISO 14971 - Medical Device Risk Management 7
A PFMEA severity score different applications FMEA and Control Plans 11
X Customer Service FMEA - Specifically Customer Care / Severity Rankings Service Industry Specific Topics 3
D How to fill a Process FMEA - Three columns - Severity, occurrence and Detection FMEA and Control Plans 16
R DFMEA Severity 9-10 with Occurrence 3 and Detection 3 - Actions FMEA and Control Plans 3
S What should the FMEA Severity for SC & CC Characteristics be? FMEA and Control Plans 4
N AIAG 4th ed. FMEA Manual "Fit" Changed to "Appearance" - Fit severity? FMEA and Control Plans 2
G Severity in Process FMEA for Rework Process FMEA and Control Plans 1
O PFMEA - Reducing Severity (S) Ranking - Manufacturing Process Design Changes FMEA and Control Plans 4
S FMEA's - Severity and Classification of Print Characteristics FMEA and Control Plans 1
N Risk Severity Estimation for Medical Devices as per ISO 14971 ISO 14971 - Medical Device Risk Management 12
C Determining PFMEA Severity for Armored Parts FMEA and Control Plans 5
C FMEA DOGMA about Severity - Am I right or Wrong? FMEA and Control Plans 2
K 4th Edition AIAG FMEA Occurrence, Severity and Detection Criteria for Plastics FMEA and Control Plans 1
F Risk = Likelihood * Severity - Can we mitigate the Severity? Occupational Health & Safety Management Standards 44
M Severity Reduction in a Design FMEA (DFMEA) FMEA and Control Plans 25
E Risk Management selection Probability of Occurrence and Severity ISO 14971 - Medical Device Risk Management 24
S Severity of 9 or 10 should be identified as Special characteristic? FMEA and Control Plans 10
G Internal vs. External PFMEA Severity Rankings FMEA and Control Plans 12
R Risks which must be Distinctly Identified - Harm, Hazard, Severity ISO 14971 - Medical Device Risk Management 7
C Severity of Effect on Process (Manufacturing/Assembly Effect) Scrap or Reworking FMEA and Control Plans 3
W Severity Rating CORRECTIVE ACTIONS - Opinions Wanted Please Nonconformance and Corrective Action 15
H DFMEA Severity Ranking of Non-Compliance to EMC Standards FMEA and Control Plans 2
P Chemical Purity Testing - FMEA Severity Scale FMEA and Control Plans 2
T FMEA Severity 9 &10 - Example of "with warning?" FMEA and Control Plans 6
E Harms Severity Scoring - Combination of Hazards ISO 14971 - Medical Device Risk Management 4
B The Distribution that represents the Severity of Nonconformances Nonconformance and Corrective Action 2
A AIAG Design FMEA Severity Rankings - Noncompliance Government Regulation? FMEA and Control Plans 9
D Severity or Occurrence? Performing an FMEA on Motorcycle Operation FMEA and Control Plans 9
L FMEA Occurrence, Severity and Detection Criteria FMEA and Control Plans 3
I Ford FMEA requirements for Severity and Occurrence Rankings Customer and Company Specific Requirements 1
G FMEA Severity Ranking for an Automotive Audio System FMEA and Control Plans 9
Chennaiite FMEA Severity Rating for Potential Manufacturing Effect mentioned in the FMEA manual FMEA and Control Plans 9
kedarg6500 FMEA Severity Scale - Higher for Failure at Customer's or End-Customer's place? FMEA and Control Plans 19
M FMEA Severity Ratings for Health Care Information System FMEA and Control Plans 10
C Does the PFMEA Severity have to match the DFMEA Severity? FMEA and Control Plans 3
P Measuring Severity of Construction Nonconformance Report Nonconformance and Corrective Action 3
L Standard for process control level depending on gravity (severity)? FMEA and Control Plans 7
I Defining a Severity Level of a non-conformance Nonconformance and Corrective Action 13
Y Severity, Occurrence and Detection FMEA Ranking Tables - Guidelines? FMEA and Control Plans 8
L FMEA - Should a severity of 9 or 10 be always followed by recommended actions? FMEA and Control Plans 2
J Severity of Finding for "Past Due Gage" found on the shop floor General Measurement Device and Calibration Topics 40
S FMEA Severity of 9 or 10 - Shower does not operate FMEA and Control Plans 13
J Ranking Severity of Non-Conforming Material Defects Nonconformance and Corrective Action 5
R Severity, Occurance and Detection ratings seem qualitative FMEA and Control Plans 14
M FMEA: Which Severity, Occurrance, Detection scale in healthcare? FMEA and Control Plans 3
