EN 10204 3.1 Inspection Certificate - Machine Shop
I have read various threads on this forum in regards to EN 10204 3.1 certificates. With the information that I have read, I just wanted to make sure I understand the process correctly.
If a customer specifies that an Inspection Certificate in accordance to EN 10204 3.1 is required for a machined component, example a manifold, this is how the process would work, correct?
Raw Material and a Material/ Mill Test Report EN 10204 3.1 would be procured by the Machine Shop. After receipt, the machine shop would perform the necessary machine shop operations per the customer's specifications/ drawings. The machine shop would then generate its' own Inspection Certificate in accordance to EN 10204 3.1. The machine shop would then copy and include the information provided on the original MTR onto that certificate and send it to the customer? I am not exactly sure what other "Test Results" could be included on the Machine Shop's Inspection Test Certificate.
Any help would be appreciated. Thank you!
Al Rosen
Holed-up in a Hotel in South Florida
Look at this thread EN 10204 Clause 3.1B - Definition, Summary and Form
Al Rosen
You would supply the machine shop's inspection results on the cert and the original mill test results.
If the product that is being supplied is a machined component, could the machine shop's inspection results just be a statement that the dimensions verified are in accordance to the applicable print? I am not sure what all would need to be included in the machine shop's inspection results that would be on the certificate.
Al Rosen
Speak with your customer. It may be acceptable. Also, you may be able to reference the original cert from the material supplier and attach a copy along with your statement.
K Inspection Certificate EN 10204 2.1 - Distribution company Other ISO and International Standards and European Regulations 4
J Is there an ISO doc that is similar to DIN EN 10204? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
B QCP (Quality Control Plan) from client with EN 10204 type 3.1 Material Certificates Various Other Specifications, Standards, and related Requirements 2
C Certificate EN 10204 for Elastomer (materials other than metals)? CE Marking (Conformité Européene) / CB Scheme 6
D Is EN 10204 3.1 an Equivalent Standard to 'COD QC 3.1 Rev 7 2009'? CE Marking (Conformité Européene) / CB Scheme 5
L Is En 10204:2004 (e) 3.1 equivalent to ASTM A788? Various Other Specifications, Standards, and related Requirements 4
J Compliance to EN 10204 Type 3.2 Certification Various Other Specifications, Standards, and related Requirements 3
B EN 10204 type 3.1 question - Chinese Steel Mill Certificate Various Other Specifications, Standards, and related Requirements 3
N EN 10204 3.1B Material Certification and Identification Various Other Specifications, Standards, and related Requirements 19
ScottK Is there a US equivalent to BS EN 10204? Various Other Specifications, Standards, and related Requirements 3
M EN 10204 type 2.2 certificate example - Titanium component - Aerospace Industry Various Other Specifications, Standards, and related Requirements 2
RoxaneB EN 10204 Clause 3.1B - Definition, Summary and Form Various Other Specifications, Standards, and related Requirements 29
P Need a programmer for QVI's VMS software for optical inspection machine Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
silentmonkey How to decide what characteristics need to be verified during incoming inspection? ISO 13485:2016 - Medical Device Quality Management Systems 5
Y What are different Special Inspection Level 1-4 and General spesification 1-3 ? AQL - Acceptable Quality Level 0
J Mechanical inspection techniques of close tolerance parts Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
T Help to Suggest name for a new certification and inspection company Coffee Break and Water Cooler Discussions 7
B GM GP-12 Exit Criteria - Additional Safe Launch Inspection - (Also see GM1927-28 ) Customer and Company Specific Requirements 2
S Process Inspection -Sub assembly process inspection sheet Lean in Manufacturing and Service Industries 3
C OEE and In-process Inspection Manufacturing and Related Processes 2
R AS9100 - 8.4.2 - Receiving Inspection Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
I Mother bobbin final inspection criteria Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
Marc Visual Inspection - Color Vision Coffee Break and Water Cooler Discussions 15
G Inspection Logs - Asked to remove an Inspection Sheet ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
Skooma Receiving Inspection - Boss trying to save money AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
T Sample of 1st Article Inspection Report wanted APQP and PPAP 3
T Nonconforming product at customer detected by a routine inspection by field service Nonconformance and Corrective Action 9
A Definition of customer in ITP (Inspection & Test Plan) Contract Review Process 3
A DCMA inspection for a drop-shipment AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
S QUALITY OBJECTIVEs for third party garments factory inspection ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
D Lean and Elimination of QC Inspection Points in a New factory Lean in Manufacturing and Service Industries 9
F FDA-registration and inspection cost 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
I Receiving Inspection Requirement in IATF IATF 16949 - Automotive Quality Systems Standard 3
R Supplier related drawings and verification of process requirements - Source Inspection AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
D AS9100 Inspection records - Is there a requirement to have gauge ID and calibration status AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
D Good Acceptance Activity/Inspection flowchart for reference - Wanted Please Process Maps, Process Mapping and Turtle Diagrams 2
S Improving Quality inspection gate in one piece flow manufacturing process Manufacturing and Related Processes 0
M Loss of a Quality Record - FDA Inspection Records and Data - Quality, Legal and Other Evidence 4
S Need Assistance in Visual Inspection - Tiny electronic components AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
S. Moore Is an Annual Layout Inspection the same as an Annual Re-validation? Internal Auditing 1
D Incoming (Receiving) Inspection - General form for incoming part inspection Document Control Systems, Procedures, Forms and Templates 17
K First Article Inspection (FAI) - Equipment used - Dimensions vs. Go/No-Go ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
M Informational USFDA Draft Guidance – Review and Update of Device Establishment Inspection Processes and Standards Medical Device and FDA Regulations and Standards News 0
S Inspection/sampling economics Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
C Is a First Article Inspection (FAI) Procedure required by ISO 13485? ISO 13485:2016 - Medical Device Quality Management Systems 3
A Doubt on multiple inspection carrying out for same balloon number during Stage Inspection and Final Inspection? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
M 3rd Party Sorting and Inspection Company Certification Service Industry Specific Topics 4
D FDA QSR task checklist based on inspection citations 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
