Hello, relatively new to 60601-1 with regards to making use of AC power supply. Please bear with me while I fumble through this question:
The device is classified as medical weigh scale. The scale is separated into 2 components:
1) Display Fixture that is embedded into the wall
2) Weighing platform Frame consisting of load cells that is embedded into the floor
There are no motors, or heating devices.
The device has a UL purchased power supply which drops it to 12Vdc which is used to power the load cells, display electronics, and printer.
I am questioning the cable that goes from the display fixture to the weighing platform frame which is contained within conduit. The voltage in the wire is less than 12V and the current is less than 12mA. The cable is a circular DIN style connector on each end.
What type of insulation voltage rating is required to meet the EN 60601-1 specification?
Thank you for your time
Qu1nn
Qu1nn
