EN 60601 - Use of Laptops, Computers, PCs placed in a Patient Environment
E
Eggsn
I understand that per EN 60601, a computer/laptop/PC if placed in a patient environment has to meet the standard as it is considered now a medical device.
My confusion here is what about those laptops that have the cleared/approved software in them that manufacturers give out and is placed near the operting room (OR) for use? How are manufacturers able to get clearance or approval from a system that uses a laptop to operate the procedure or imaging system? Are there other standards I am missing as well?
Any help will be appreciated. Thank you.
sreenu927
Generally, laptops and PCs won't be an accessory of the Medical device. Only the SW will be a part of the device. If IVD, an IVD symbol will be placed on SW CD or on the SW user manual. Verification of this device SW on particular Operating Systems will be performed and documented.
When u submit for registration, you submit the system with the SW, not with the particular laptop or PC. You hv provide information on the available configuration, for eg., this medical device system is supplier along with the Laptop as option 1 and PC as Option 2. Customers can select their choice of configuration.
When SW or OS is changed, then it will affect the performance of the device, but not the change of laptop or desktop.
Rgds,
Sreenu
Peter Selvey
Under the 2nd edition (IEC 60601-1:1988, or EN 60601-1:1990), items like PCs are handled under IEC 60601-1-1 (systems standard).
In principle, the components of the "system" should meet the appropriate standards (e.g. IEC 60601-1 for the medical device that contacts the patient, IEC 60950 for a PC that may connect to the medical device), and the leakage currents of the whole system should stay below the EN 60601-1 limits. The leakage current part can be met by a number of strategies, e.g. isolation transformers, earth bonding, use of low leakage laptop, isolated signal connections etc.
There are a couple of other considerations, for example, check connectors are not dangerously compatible, e.g. an medical ECG that uses a D15 plug that can also be accidentally plugged directly in the back of the PC would be dangerous.
For the 3rd edition (IEC 60601-1:2005, EN 60601-1:2006), the principles are the same, but the requirements have been incorporated into Clause 16 of the standard.
As the other poster have mentioned, the software in the PC can be a medical device, if the software is specifically written for the medical purpose. Other software on the PC (e.g. operating system, MS office etc) is not a medical device even if used for a medical purpose, since the "manufacturer" of that software did not intend it for a medical purpose.
M Are laptops part of ME SYSTEMS? Reading of IEC 60601-1 IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
E Accredited vs. non-accredited labs for 60601 compliance in the US IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
E Accredited vs. non-accredited labs for 60601 compliance in the US Other Medical Device Related Standards 0
M Class II type machine , and its compliance with 60601-1 IEC 60601 - Medical Electrical Equipment Safety Standards Series 14
Ed Panek 60601-1-2:2015/A1:2021 IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
E 60601-1 - Tilt testing - Tensile safety factor IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
JoCam IEC 60601-1 and 60601-1-2 retest after PCBA change IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
A 60601-1 : Integrated Dry ECG Electrodes = 2 Patient connections inside 1 applied part? IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
A 60601-1-2 : Integrated Dry Electrodes = PATIENT COUPLED PORT? IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
N 60601-2-2 Ed 6 Clause 201.8.8.3.102 - HF instrument leakage IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
N Maximum mains voltage used when applying 60601 IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
J IEC 60601-1-11 Home Class II With Ballasts IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
A Coverage and differences: EN 60601-1:2006+A12:2014 Vs AAMI/IEC 60601-1:2005+AMD1:2012 IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
T IEC 60601-1-8:2020 Is it necessary to change the alarm melody? IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
S Applicability of 60601 vs. 60335 IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
S IEC 60601-2-30 - Is it mandatory to claim alarms? IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
A 60601-1 understanding of stationary device IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
A Outsourcing IEC 60601-1 Ed 3.2 Testing IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
R Complex IEC 60601-1 gap assessment IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
D SINGLE FAULT CONDITION, short circuit and open circuit of any component (IEC 60601-1 3.1) IEC 60601 - Medical Electrical Equipment Safety Standards Series 9
H IEC 60601-1 ME equipment or ME system IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
A ANSI/AAMI versions of 60601-1-2 and related testing requirements Other Medical Device Related Standards 3
R IEC 60601-1:2005+AMD1:2012+AMD2:2020 CSV IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
B IEC 60601 - Creepage Distance - Relay that acts as a means of physical mechanical protection Process Maps, Process Mapping and Turtle Diagrams 0
M What to Expect from Next IEC 60601-1 and IEC 60601-1-2 Amendments? IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
D IEC 60601-1 - Service life testing IEC 60601 - Medical Electrical Equipment Safety Standards Series 8
R Hand transmitted vibration 9.6.3 of IEC 60601-1 IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
shimonv Minimum 60601 requirements for a clinical trial IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
W IEC 60601 - Essential performance c.2.34 IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
A IEC 60601-1 Dielectric Strength test for battery operated devices IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
JoCam Failure to test Class I medical device to IEC 60601-1-11 IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
