Endotoxin testing - Raw materials and components of a Class III medical device
jampot
Would anyone be able to advise of the regulatory requirements for endotoxin testing raw materials/components of a medical device.
We are developing a Class III device and in addition to endotoxin testing the final manufactured device also are also considering testing the two main components for endotoxin content.
Is the testing of the latter actually necessary?
Many thanks in advance:)
Jampot
CertifiedDataJunkie
Just to start the discussion ...
Definition of a Class III Medical Device ...
Class III - Premarket Approval
Class III is the most stringent regulatory category for devices. Class III devices are those for which insufficient information exists to assure safety and effectiveness solely through general or special controls.
Class III devices are usually those that support or sustain human life, are of substantial importance in preventing impairment of human health, or which present a potential, unreasonable risk of illness or injury.
Premarket approval is the required process of scientific review to ensure the safety and effectiveness of Class III devices. Not all Class III devices require an approved premarket approval application to be marketed. Class III devices which are equivalent to devices legally marketed before May 28, 1976 may be marketed through the premarket notification [510(k)] process until FDA has published a requirement for manufacturers of that generic type of device to submit premarket approval data.
Class III devices which require an approved premarket approval application to be marketed are those:
regulated as new drugs prior to May 28, 1976, also called transitional devices.
devices found not substantially equivalent to devices marketed prior to May 28, 1976.
Class III preamendment devices which, by regulation in 21 CFR, require a premarket approval application.
Examples of Class III devices which require a premarket approval include replacement heart valves, silicone gel-filled breast implants, and implanted cerebella stimulators.
Class III devices which can be marketed with a premarket notification 510(k) are those:
postamendment (i.e., introduced to the U.S. market after May 28, 1976) Class III devices which are substantially equivalent to preamendment (i.e., introduced to the U.S. market before May 28, 1976) Class III devices and for which the regulation calling for the premarket approval application has not been published in 21 CFR.
Examples of Class III devices which currently require a premarket notification include implantable pacemaker pulse generators and endosseous implants.
When is endotoxin testing required?
The FDA Center for Devices and Radiological Health requires devices in contact with circulating blood or cerebrospinal fluid to be nonpyrogenic. Intraocular lenses also are required to be nonpyrogenic. Requirements for other products are decided on a case-by-case basis by the FDA. Manufacturers planning to use the Limulus Amebocyte Lysate (LAL) test as a pyrogenicity test for devices must validate and test according to the FDA draft LAL guideline or submit data from an alternate method to FDA for review. Traditionally, nonpyrogenic water or saline is used to rinse devices for LAL testing. Data from our initial studies on endotoxin recovery from devices using sodium lauryl sulfate demonstrate higher recovery than with nonpyrogenic water. This method, which provides an alternate rinse solution for recovery of endotoxin from medical devices is undergoing collaborative study.
Endotoxins and Medical Devices
Given the stringent nature of Category III devices and the likelihood that they meet the requirements for endotoxin testing, it is a conservative recommendation to consider the raw materials and components of the device as a source of endotoxins.:caution:
I would have liked to find a more current citation for these requirements, but it is a starting point.:2cents:
jampot
Many thanks for this.
So if I interpret correctly, there is no regulatory requirement to test components of a medical device for their endotoxin content. The key point is that the final product is tested using a validated method.
Jampot
P
Paragon
Dear Jampot,
I am interested to know about your products as we are dealing in Endotoxin products...
Where you are getting Blood of Horse Shoe Crab?
P
Paragon
Hi Jampot !
There are only 3 producers of Endotoxin products;
Cape Code
BioWhittaker™ is Cambrex
Charles River
I have very good experience working in Pharmaceutical, sterile area designing and construction.
lindal
Hi Jampot !
Cape Code
Charles River
Cape Cod recently withdrew some of their Pyrotell Multitest LAL (http://www.fda.gov/cber/recalls/lalacc030907.htm) and is not selling/ will not sell us the LAL that we purchase, which has a different product code.
How much revalidation/ qualification will be required to switch to an equivalient product by Lonza (Cambrex) or Charles Rivers?
Incidentally, we never received a change notification and there isn't anything on their website about this.
Has anyone had to deal with a similar situation? If so, what did you do?
L
S Medical Device Endotoxin Testing for ANSI/AAMI ST72:2011/2016 Other Medical Device Related Standards 1
I Bioburden and Endotoxin (LAL) Testing proposal help 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
S Mouse Embryo Assay and Endotoxin Testing Requirements and Costs US Food and Drug Administration (FDA) 3
B BioBurden and EndoToxin Questions Other Medical Device Related Standards 6
E 60601-1 - Tilt testing - Tensile safety factor IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
V Setup for testing against ISO14708 clause 16 (protection of the patient from herms caused by heat) Other Medical Device Related Standards 0
gramps What do you think about automated QA testing For software app industry? Misc. Quality Assurance and Business Systems Related Topics 5
B In house NIOSH pre Testing accepted by NIOSH? US Food and Drug Administration (FDA) 1
M Bacteriostasis/Fungistasis Testing Other Medical Device and Orthopedic Related Topics 6
P Sample Size for Distribution Simulation Testing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 11
N EN 813, EN 12277, EN 1497 - Testing some harness prototypes to an EN standard Various Other Specifications, Standards, and related Requirements 0
D Essential performance and EMC immunity testing IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
J Biocompatbility testing on Class 1 device requirements Other US Medical Device Regulations 12
Q Summative Usability Evaluation Testing: prior or during Clinical Investigation? Human Factors and Ergonomics in Engineering 6
B NIOSH Approval for Surgical N95 Respirators - Required testing US Food and Drug Administration (FDA) 2
M ECG lead leakage currents - How to specify ECG leads during electrical safety testing IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
C Stress / Challenge Conditions for Design Verification Testing to Reduce Sample Size 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 11
D CFR Title 14: Aeronautics and Space PART 120—DRUG AND ALCOHOL TESTING PROGRAM Federal Aviation Administration (FAA) Standards and Requirements 3
lanley liao Purchase Acceptance Criteria - Tensile testing Oil and Gas Industry Standards and Regulations 2
M Device mounted at IV pole - what about mechanical stability testing? IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
A Outsourcing IEC 60601-1 Ed 3.2 Testing IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
J Cochlear Implant Testing 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
A Class I (exempt) testing requirements Other Medical Device Related Standards 0
JoCam Electrical Testing for Japan, PSE or CB Scheme Other Medical Device Regulations World-Wide 0
M Who are the go to companies for non-destructive hardness testing? General Measurement Device and Calibration Topics 3
P Testing cloud-based backups IT (Information Technology) Service Management 7
I IATF Lab Scope Testing Qualification and Competency Documentation IATF 16949 - Automotive Quality Systems Standard 3
N Chemical Testing on Medical Devices - Solutions in a container closure system (bag) EU Medical Device Regulations 1
M Comparing data from destructive testing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
T Flammability testing Reliability Analysis - Predictions, Testing and Standards 0
E Manufacturers should develop a testing device for covid19 Service Industry Specific Topics 0
K When is Bioburden Testing Required? Other Medical Device Related Standards 4
K IEC 62304 - Testing Independance IEC 62304 - Medical Device Software Life Cycle Processes 5
A ANSI/AAMI versions of 60601-1-2 and related testing requirements Other Medical Device Related Standards 3
C Surgical mask stability testing (CE mark) EU Medical Device Regulations 2
Beliz Biocompatibility Testing for Laser Epilation Device EU Medical Device Regulations 2
C One Time Service Supplier - Temperature and Humidity Testing Service ISO 13485:2016 - Medical Device Quality Management Systems 5
D IEC 60601-1 - Service life testing IEC 60601 - Medical Electrical Equipment Safety Standards Series 8
P Flammability Testing of Aircraft Interior Materials Federal Aviation Administration (FAA) Standards and Requirements 0
N Usability testing required for FDA IDE (investigational device exemption)? Human Factors and Ergonomics in Engineering 8
E ASTM F2118 - Fatigue testing of bone cement - Changes between the 2003 and the 2014? Other Medical Device Related Standards 1
K Biocompatibility Testing - Multile products of different sizes and shapes US Food and Drug Administration (FDA) 2
S Requirement to Conduct New Shelf-life Testing? (re-do testing for design change) EU Medical Device Regulations 3
JoCam Mobile Patient Hoists and Electrical Testing Other Medical Device Related Standards 0
T Interlaboratory comparison or proficiency testing in destructive testing of welded joints ISO 17025 related Discussions 3
B ASTM E18-2020 - Rockwell testing standard changes? General Measurement Device and Calibration Topics 2
U Medical Device Design finalization testing ISO 13485:2016 - Medical Device Quality Management Systems 2
Jane's Like-for-like critical raw material change qualification - type of testing/ number of lots required ISO 13485:2016 - Medical Device Quality Management Systems 4
