Engineering Change order vs. Change Control
duff999
Hi Folks
More questions, just looking for a high level of understanding.
I am developing an SOP for the ECO process stating - specifically the ECO process applies to released work instructions, materials, packaging and labeling, production equipment and software and other specific documentation.
In a scenario where a piece of software has a revision update - this SW may be used in production or calculating results, would this fall under the ECO process?
Or
Is it better to create a Change Control SOP - rather than locking it down to just ECO?
Any help is appreciated
Ed Panek
QA RA Small Med Dev Company
If the software could affect product quality the software should be controlled. If you modify it should have a revision level. It should be processed as a change via the ECO process and V&V tested prior to release (similar to the initial release). You should document in the batch record which version(s) of software was used for that batch.
your Change Control SOP will define how changes are managed. Some changes like typos may just require a single signoff. Major ones likely need a lot of testing and Design Review before release.
John C. Abnet
Teacher, sensei, kennari
Good day
Good day @duff999 ;
In my experience, "degrees" or "categories" of change is never a very effective approach (and generally causes confusion with associates).
A change to a controlled process (how the product is processed) or product (change to the product itself), is generally a good / effective / and all encompassing definition of required change point control.
If we identify what/when/who in regards to that definition, then you've created the mechanism for providing the organization and customer..
a) awareness
b) traceability
c) limited exposure (if/when a problem occurs)
Why would an "engineering change" be treated as one type of change control (and of course , what exactly constitutes an "engineering change" ? [Let's assume that this is a product drawing change.] ) be treated any different than a process change?
Doesn't the organization (and in most cases, the customer), want to know what/when/who ?
Doesn't the organization (and in most cases, the customer), want to ...
a) to be "aware" through the required approvals, notifications, training...
b) have traceability to which product is affected (and which is not)...
c) limit exposure by knowing exactly when a change was applied and to which product has been impacted?...
...regardless of whether it is a product or process change?
While on the subject, does not a change to a controlled product or process generally require a change to documentation? (process standard, work instruction, PFMEA, control plan, product drawing, etc..etc... )? Therefore, does not this approach also apply to those documents associated with a controlled product or process?
Simple and concise is good. My experience.
Hope this helps.
Be well.
Revision36 Engineering Change Order Industry Standards Other Medical Device and Orthopedic Related Topics 7
D ECO (Engineering Change Order) process questions ISO 13485:2016 - Medical Device Quality Management Systems 7
D Engineering Change Order (ECO) metrics to track ISO 13485:2016 - Medical Device Quality Management Systems 6
Icy Mountain Engineering Change Order...Modification Order Document Control Systems, Procedures, Forms and Templates 18
S Engineering change order versus a design change request ISO 13485:2016 - Medical Device Quality Management Systems 1
M ECO (Engineering Change Order) Record Filing Question Records and Data - Quality, Legal and Other Evidence 1
T Need help developing an ECO (Engineering Change order) procedure Document Control Systems, Procedures, Forms and Templates 3
C Documents not controlled by the ECO (Engineering Change Order) process ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
J ECO (Engineering Change Order) Control for Unreleased Products Document Control Systems, Procedures, Forms and Templates 3
Q How to close the circle QMS and ECO (Engineering Change Order)? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
Q Document Control ECO (Engineering Change Order) or QMS? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
D ECO (Engineering Change Order) Risk Management Criteria and QA Document Control Systems, Procedures, Forms and Templates 19
M ECO (Engineering Change Order) Tracking and Status Report Document Control Systems, Procedures, Forms and Templates 1
T ECO (Engineering Change Order) Implementation checklist/work instruction Document Control Systems, Procedures, Forms and Templates 6
V How to measure ECO (Engineering Change Order) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
M Engineering Change Request/Order (ECR/ECO) or Document Change Request/Order (DCR/DCO) Document Control Systems, Procedures, Forms and Templates 30
R ECO (Engineering Change Order) presentation Document Control Systems, Procedures, Forms and Templates 2
R ECO (Engineering Change Order) Question for all experts (fill the blanks) Document Control Systems, Procedures, Forms and Templates 4
K ECO (Engineering Change Order) Revision - Letter change or part number change? Manufacturing and Related Processes 13
M Using M-1 Software for Quality - Manual Engineering Change Order Entry Quality Assurance and Compliance Software Tools and Solutions 1
CarolX Preventive Action (PA) - Employee Suggestion Box, Engineering Change Order? Preventive Action and Continuous Improvement 12
Raffy ECN (Engineering Change Notice) / ECO (Engineering Change Order) System Document Control Systems, Procedures, Forms and Templates 1
C E signatures on Engineering Change Notes AS9100 / AS9116 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
J Class 1 Medical Device ECR (Engineering Change Request) Changes 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
A Software Suggestions for Engineering Change/QMS Design and Development of Products and Processes 2
Q Change of fields - Quality Engineering Electronics Vs medical Devices Career and Occupation Discussions 20
T Engineering Change Management Systems Document Control Systems, Procedures, Forms and Templates 3
M Engineering Change Management Generic Procedure Manufacturing and Related Processes 3
S Ford Motor Engineering Change Level definition Customer and Company Specific Requirements 6
D How to process Customer ECO's (Engineering Change Orders) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
Q ECR (Engineering Change Request) or NCR (Nonconformance Report) in Fabrication? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
L Engineering Change Control Software Systems - Recommendations? Document Control Systems, Procedures, Forms and Templates 2
L The Perfect Engineering Change and Concessions Management System Document Control Systems, Procedures, Forms and Templates 8
M Formula for Prioritizing Engineering Change Requests (ECR)? Document Control Systems, Procedures, Forms and Templates 1
D Management of Change - MOC Procedure and Forms - Engineering, Project, Safety Systems Manufacturing and Related Processes 1
Q ECR?s (Engineering Change Requests) in Engineering? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
M Is ECN (Engineering Change Notice) Necessary for Part Number Change IATF 16949 - Automotive Quality Systems Standard 4
Q How to monitor Engineering Change Requests? Document Control Systems, Procedures, Forms and Templates 7
D Launch Change Request Form vs. Engineering Change Form Document Control Systems, Procedures, Forms and Templates 5
J Engineering/Document Change Notice Procedure required? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
P How to specify criteria for TECN (Temporary Engineering Change Notice) Document Control Systems, Procedures, Forms and Templates 3
T From ECR (Engineering Change Request) to ECN (Engineering Change Note) - double work! Document Control Systems, Procedures, Forms and Templates 2
M Definition Engineering Change and Document Change - Definitions Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 2
9 ECR (Engineering Change Request) process - Please critique / review Document Control Systems, Procedures, Forms and Templates 10
P Managing ECN (Engineering Change Notice) Blueprints Database..any solutions? Document Control Systems, Procedures, Forms and Templates 2
Q How to implement an External Engineering Change ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
W Engineering ECR (Engineering Change Request) and ECN (Eng Change Notice) Procedures Document Control Systems, Procedures, Forms and Templates 3
K When to use an Engineering Change Request (ECR) Document Control Systems, Procedures, Forms and Templates 8
J Automated Engineering Specification Change Notifications? IATF 16949 - Automotive Quality Systems Standard 5
