Engineering changes for customer notification - PPAP Submission
ROOTS
As per PPAP 4th Edition clause no. 3.1 i.e. customer notification, the organization should notify the changes with regard to design, process or site to their customers by submitting the PPAP documents as per clause 3.2.
With reference to the above point, kindly clarify the following things.
Whether the customer notification / approval is required, if we done some changes in the internal construction, which does not affect the customer requirement / specification including the outer shape / sizes. (This question arised because we have done some value engineering / cost reduction in the internal construction to compensate the sudden price hike in the raw materials.)
Can anyone pl. help.
regards,
S. Kavitha
Howard Atkins
Forum Administrator
Please remember
7.1.4 Change control
The organization shall have a process to control and react to changes that impact product realization. The effects of
any change, including those changes caused by any supplier, shall be assessed, and verification and validation
activities shall be defined, to ensure compliance with customer requirements. Changes shall be validated before implementation.
For proprietary designs, impact on form, fit and function (including performance and/or durability) shall be reviewed with the customer so that all effects can be properly evaluated.
When required by the customer, additional verification/identification requirements, such as those required for new product introduction, shall be met.
NOTE 1 Any product realization change affecting customer requirements requires notification to, and agreement from, the
customer.
NOTE 2 The above requirement applies to product and manufacturing process changes.
The question is can you prove that the change that you made has no effect on the customer.
Have you properly validated the change?
Wes Bucey
Speaking as a purchaser, I want to know of ANY changes after the first PPAP, including something as minor a changing to a newer, more efficient production process. I DEFINITELY want validation the product I receive is the same or better than the one I bargained for when accepting the first PPAP.
Wes Bucey said:
:soap: soapbox time - I believe a basic failure in most supply chains is the unwillingness of the links to share information and keep up a continual communication channel among the links for the sake of the efficiency of the entire chain. Top dog OEMs have fostered this distrust by stealing info from one link and sharing it with a "different" player, who subsequently takes the business from the first link.
This has been a particularly egregious activity in recent years as some OEMs steal trade secrets from domestic suppliers and give them to off-shore suppliers who "make the same thing, only cheaper" (ask pet food and toothpaste buyers if that is REALLY true!)
Back on topic: Even with the possibility of a link in the supply chain being a traitor, changing a process STILL requires notice to the next link in the chain.
The current AIAG PPAP manual describes the default requirements for notification and resubmission; if you want to supersede the defaults you can, but it's a matter of explicitly stating the exception(s) in the contract.
Maybe yes, maybe no. According to the 4th Edition PPAP manual, which I assume to be normative in this case because the OP cites it, notification is required in the case of
Product and process changes related to components of the production product manufactured internally or manufactured by suppliers
And under "Clarifications" for this requirement, it says,
Any changes, including changes at the supplier to the organization and their suppliers, that affect customer requirements, e.g., fit, form, function, performance, durability.
The manual also requires notification when there is
Use of other construction or material than was used in the previously approved part or product.
And the "Clarification" says,
For example, other construction as documented on a deviation (permit) or included on a note on the design record and not covered by an engineering change...
What this means is that if the change is something that would normally require a change in the design specifications, notification is necessary. In some instances, and "black box" applications come to mind, there is no need to notify if there are internal changes that don't affect design intent such as input/output and durability requirements.
Nonetheless, Wes's point is well-taken; when in doubt, notify. There are times when a change might seem innocuous but could have unexpected consequences in light of things the supplier has no way of knowing. The only exception to this might be in the case of black box applications that involve proprietary information, and the customer has already explicitly indicated lack of interest in changes so long as specified values remain unchanged.
ROOTS
Dear Mr.Howard Atkins,
Thanks for your reply.
Whenever we do any changes in the product, we will validate the product as per customer requirement / standards / specifications to verify the quality of product. We will also compare the results with the existing design results and if it is equal to the existing results, then only we will implement the changes.
For example if we do some cost savings in our product, to compensate the present market competitiveness, we could not able to inform the changes to the customer as the customer approval was getting delayed and due to that implementation for the changes are also got delayed. One more thing, the customer also expects the price reduction in the product. But actually as told already we are compensating the loss incurred due to hike in raw material price.
Regards,
S. Kavitha
Howard Atkins
Forum Administrator
One question,are you actually obliged to us the PPAP handbook, for example if your customer is Maruti, the customer requirements say FMEA but do not refer to the handbook. If I remember the PPAP requirements are also different.
Check the actual requirements.
The problem with cost reductions is that you are dammed if you do and dammed if you don't. You have a price hike, you return that to yourself and if you tell your customer then he demands to share it.
In the end I think that the dilemma should be put to the management for them to decide.
S How Do I Handle Customer Engineering Specification Changes? IATF 16949 - Automotive Quality Systems Standard 33
S Ballooned Drawings and Engineering Changes Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
J Class 1 Medical Device ECR (Engineering Change Request) Changes 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
2 First Article Requirements for Revision Changes of Engineering AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
N Engineering Changes (ECR, ECO, ECN) and how they should be Structured Document Control Systems, Procedures, Forms and Templates 6
M 7.6.2 Revisions following Engineering Changes - What is the right meaning? IATF 16949 - Automotive Quality Systems Standard 4
Q Filtering ECR/ECO by quality management? Managing Engineering Changes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
B DuPont plans Engineering Changes for Tyvek 1073B & 1059B - 2011 Other Medical Device and Orthopedic Related Topics 3
A ISO 13485 Risk Analysis - Class II Medical Device Engineering Changes ISO 13485:2016 - Medical Device Quality Management Systems 9
A When to review an FMEA - At engineering changes? FMEA and Control Plans 5
T SOP Dates - What to put in for the Start of Production date on engineering changes IATF 16949 - Automotive Quality Systems Standard 2
M Implimentation of Engineering changes QS-9000 - American Automotive Manufacturers Standard 2
Marc Engineering Technician - Suspense 5 April 2021 Job Openings, Consulting and Employment Opportunities 0
Marc Engineering Technician - Suspense 11 February 2021 Job Openings, Consulting and Employment Opportunities 0
Bev D Essential References for Practical Quality Engineering Misc. Quality Assurance and Business Systems Related Topics 0
Revision36 Engineering Change Order Industry Standards Other Medical Device and Orthopedic Related Topics 4
D ECO (Engineering Change Order) process questions ISO 13485:2016 - Medical Device Quality Management Systems 7
D Engineering Change Order (ECO) metrics to track ISO 13485:2016 - Medical Device Quality Management Systems 6
J UCLA extension Medical Device Engineering Program Training - Internal, External, Online and Distance Learning 0
G Engineering retest in line - Machine stability issues IATF 16949 - Automotive Quality Systems Standard 8
A FDA and NB audit of Engineering Drawings in DHF and DMR. Medical Device and FDA Regulations and Standards News 1
I Good resources for learning statistics (quality engineering related) Statistical Analysis Tools, Techniques and SPC 10
B Lessons Learned Implementing ISO 50001 (Chemical Engineering Progress) Other ISO and International Standards and European Regulations 0
G Engineering Specifications - APQP APQP and PPAP 5
O Vendor vs Engineering Document Control ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
C E signatures on Engineering Change Notes AS9100 / AS9116 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
Icy Mountain Engineering Change Order...Modification Order Document Control Systems, Procedures, Forms and Templates 18
J Implementing Machine Replacement Part Reverse engineering technology Manufacturing and Related Processes 3
T Why do most companies have Quality reporting to Engineering or Operations and not to CEO? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 45
I Document templates required for ISO ISO 45001 - Engineering Construction company Occupational Health & Safety Management Standards 5
R The alignments and contradiction in Quality Engineering and management between the Automotive and Aerospace industry AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
D Engineering Drawing Review and Approval Requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
V Thinning percentage in sheet metal forming per SES (Suzuki Engineering Standard) Manufacturing and Related Processes 1
P Usability/human factors engineering requirement (standard) for IVD medical device Other Medical Device Related Standards 2
R Creating WIs for a Heavy Civil Engineering Services company Document Control Systems, Procedures, Forms and Templates 19
P Tactics to work with Design Engineering on CAR Nonconformance and Corrective Action 3
D Are detailed engineering requirements Design Inputs or Design Outputs 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 14
S Engineering change order versus a design change request ISO 13485:2016 - Medical Device Quality Management Systems 1
C Applicability of ISO 9001:2015 Section 8.5 - Engineering company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
T Setting up a quality department in an Engineering Firm Quality Management System (QMS) Manuals 11
C ISO 9001 2015 Documentation for Engineering and Design ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
I Engineering Drawing = Record or Document? Document Control Systems, Procedures, Forms and Templates 8
G ISO 9001:2015 8.3 Design and Development (in Civil Engineering) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
G FAI (First Article Inspection) Responsibility - QC or Engineering? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
Q M-282 - Engineering Standard for Tolerances - Is it ASTM, DIN? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
L Supplier Revision Confirmation of Received Engineering Documents ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
S Document Control Guidelines in Engineering Projects - Excel sheets with VBA coding Document Control Systems, Procedures, Forms and Templates 3
A Software Suggestions for Engineering Change/QMS Design and Development of Products and Processes 2
M New MHRA guidance on Human Factors - Usability Engineering IEC 62366 - Medical Device Usability Engineering 1
