Engineering/Document Change Notice Procedure required?
jonedm
I'm helping a small manufacturing firm achieve 9001:2008 registration. They do no design work, only manufacturing. They're small and trying to document a minimal set of formal procedures. They passed their Stage 1 audit, Stage 2 coming in mid-March. Is a formal procedure (and form) required for changing documents? Or can change requests be verbal with a summary of the change recorded in the signoff section of the document? The current Doc Control procedure, which the auditor reviewed and said looks fine, does not mention the need to use a form, only that changed documents must go through the same approval process as the original document before being implemented. Thanks in advance for your thoughts.
Big Jim
Follow the guidance of your auditor. It is not a procedure that is required to be documented. The six required ones are for control od documents, control of records, internal auditing, control of nonconforming product, corrective actions, and preventive actions.
No other procedures have to be documented as long as you have an effective method to handle it.
Ajit Basrur
Welcome to the Cove :bigwave:
Google gave these SEARCH results :)
DrM2u
Like Jim said, there are only (6) procedures that are required to be documented per ISO 9001:2008 ... and a document can address more than one procedure (see Note 1 under 4.2.1)! Usually a procedure identifies/defines WHAT you do. So your doc control procedure is fine if it specifies that "changed documents must go through the same approval process as the original document before being implemented". This was also confirmed by the auditor, most importantly.
Now the question becomes HOW you do it (control document changes). It is up to you if you want to document an instruction and/or a form on HOW to control document changes. I have previously attached a procedure and a form that you can review for reference. The procedure is called 'Change Control' and the form is called 'Change Request'. You can find them by searching the Post Attachment List. There you will find other examples of related procedures and forms to review & evaluate. Pick something that makes sense and you can build on to meet your roganization's needs. Have fun!
jkuil
As you state that they do only manufacturing and no design I asume that they are a contract manufacturer? Therefore you may not be the owner of the product or manufacturing process specification, the contacting client is. In the contract between your firm and their clients they need to include procedures how change requests must be handled. Their clients may not be happy when the product does not meet their requirements, or due to a change in manaufacturing procedures they have a higher risk of non-conforming products. Therfore, there clients may have requirements for recording and submitting change requests.
Q Document Control ECO (Engineering Change Order) or QMS? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
M Definition Engineering Change and Document Change - Definitions Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 2
M Engineering Change Request/Order (ECR/ECO) or Document Change Request/Order (DCR/DCO) Document Control Systems, Procedures, Forms and Templates 30
O Vendor vs Engineering Document Control ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
I Document templates required for ISO ISO 45001 - Engineering Construction company Occupational Health & Safety Management Standards 5
I Engineering Drawing = Record or Document? Document Control Systems, Procedures, Forms and Templates 8
S Document Control Guidelines in Engineering Projects - Excel sheets with VBA coding Document Control Systems, Procedures, Forms and Templates 3
L How to document use of wrong engineering drawing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 22
S Design and Development Document evidence for Engineering Consultant ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
S MDR (Master Document Register) for Planning of Documents in Process Engineering Document Control Systems, Procedures, Forms and Templates 2
Q Method of Document Management (Control) in Engineering - Please Review ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
Q Document Control in an Engineering Company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 18
Y Applying Human Factors and Usability Engineering - FDA Guidance Document 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
S Quality Engineering and Document Control Manpower Level Quality Manager and Management Related Issues 2
J Medical Device Engineering, Manufacture, and Servicing Document Storage US Food and Drug Administration (FDA) 1
B How to document Reverse Engineering - We do Reverse Engineering ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 18
J Engineering Orders & Document Control Processes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
D What companies do a great job at engineering document management systems and control? Document Control Systems, Procedures, Forms and Templates 3
A Is there a Guideline document of ISO 9001 for Civil Engineering Services Service Industry Specific Topics 3
D Document Control Software - Small engineering firm - Reviews or Recommendations? Document Control Systems, Procedures, Forms and Templates 10
Marc Engineering Technician - X-ray Imaging - Suspense 30 Nov 2020 Job Openings, Consulting and Employment Opportunities 0
Revision36 Engineering Change Order Industry Standards Other Medical Device and Orthopedic Related Topics 4
D ECO (Engineering Change Order) process questions ISO 13485:2016 - Medical Device Quality Management Systems 7
A Quality engineering positions in US - question Job Openings, Consulting and Employment Opportunities 1
D Engineering Change Order (ECO) metrics to track ISO 13485:2016 - Medical Device Quality Management Systems 6
J UCLA extension Medical Device Engineering Program Training - Internal, External, Online and Distance Learning 0
G Engineering retest in line - Machine stability issues IATF 16949 - Automotive Quality Systems Standard 8
A FDA and NB audit of Engineering Drawings in DHF and DMR. Medical Device and FDA Regulations and Standards News 1
I Good resources for learning statistics (quality engineering related) Statistical Analysis Tools, Techniques and SPC 10
B Lessons Learned Implementing ISO 50001 (Chemical Engineering Progress) Other ISO and International Standards and European Regulations 0
G Engineering Specifications - APQP APQP and PPAP 5
C E signatures on Engineering Change Notes AS9100 / AS9116 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
Icy Mountain Engineering Change Order...Modification Order Document Control Systems, Procedures, Forms and Templates 18
jjmusicjr Implementing Machine Replacement Part Reverse engineering technology Manufacturing and Related Processes 3
T Why do most companies have Quality reporting to Engineering or Operations and not to CEO? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 45
R The alignments and contradiction in Quality Engineering and management between the Automotive and Aerospace industry AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
D Engineering Drawing Review and Approval Requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
V Thinning percentage in sheet metal forming per SES (Suzuki Engineering Standard) Manufacturing and Related Processes 1
P Usability/human factors engineering requirement (standard) for IVD medical device Other Medical Device Related Standards 2
R Creating WIs for a Heavy Civil Engineering Services company Document Control Systems, Procedures, Forms and Templates 19
S Ballooned Drawings and Engineering Changes Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
J Class 1 Medical Device ECR (Engineering Change Request) Changes 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
P Tactics to work with Design Engineering on CAR Nonconformance and Corrective Action 3
D Are detailed engineering requirements Design Inputs or Design Outputs 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 14
2 First Article Requirements for Revision Changes of Engineering AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
S Engineering change order versus a design change request ISO 13485:2016 - Medical Device Quality Management Systems 1
C Applicability of ISO 9001:2015 Section 8.5 - Engineering company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
T Setting up a quality department in an Engineering Firm Quality Management System (QMS) Manuals 11
C ISO 9001 2015 Documentation for Engineering and Design ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
