Engineering Drawing Review and Approval Requirements
DietCoke1953
Our external auditor cited us with a minor finding because our Design & Development process does not require a person separate from the one who created an engineering drawing to review and approve it.
Is the separate review and approval of a drawing required by ISO 9001:2015?
Thank you for your input.
In issuing the NC, the auditor is supposed to cite the requirement from the standard. Was this done? Can you post the entirety of the NC statement?
Not that I am aware. Does your internal procedure specify an independent review?
I'm with Jim Wynne and many auditors are failing to back up their NCs with any substance.
DietCoke1953
CAT2 (Minor) Drawing approval Requirement: Engineering drawings/sketches required to be checked by someone other than drawn personal.
Nonconformity: Drawing checking box not completed for the issued drawings.
Evidence: E.g. Skid fabrication drawing - HFP-CT-011 3115 Rev.1 issued to vendor
ISO 9001:2015 7.5.3.2
Eredhel
Quality Manager
You should be able to appeal this pretty easily. Plus the auditor is even calling out document control rather than design stuff anyway.
Pancho
wikineer
I would rather not hang the auditor just yet.
Hopefully the OPs documented information makes clear which drawings need or not approval. If that is not specified in the system, then there’s certainly an unidentified risk, or an opportunity for improvement, perhaps even a nonconformity.
Many drawing templates have a “checked” or “approved” box that, if left empty, may imply that a check or an approval is missing rather than simply not required. I can see it leading to confusion in suppliers, clients or consultants. I think it may be good practice to mark such box with N/R if such check is not required. This way no one can be confused as the auditor may have been.
So, in summary, at least two small improvements can come of this: (1) clarification in the system of which drawings need approval, and (2) a documented distinction between drawings where approval is not required and those where approval has not yet been done.
Sidney Vianna
Post Responsibly
If that were the case the CB auditor should have referenced the source of the requirement, accordingly.
The CB audit and reporting protocol allows for a few categories of audit findings, ranging from noteworthy efforts to major nonconformities, passing through observations, opportunities for improvement, etc.
When a CB auditor reports a finding as a nonconformity, s/he HAS to tie the evidence to a VALID requirement. In this case, s/he has obviously failed to comply with the protocol. It is that simple and if we allow CB auditors to ignore the standards they have to follow we are injecting valueless disruption into the process.
I Engineering Drawing = Record or Document? Document Control Systems, Procedures, Forms and Templates 8
T Engineering Drawings - Once a customer has signed off on an engineering drawing ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
L How to document use of wrong engineering drawing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 22
K Engineering Drawing Convention for Units of Measure Other ISO and International Standards and European Regulations 8
C Engineering Drawing Pre-Release/Advance Release Process Document Control Systems, Procedures, Forms and Templates 5
J Drawing Approvals vs. Engineering Order Approvals Document Control Systems, Procedures, Forms and Templates 2
M Engineering Drawing Number Procedure Requirement - ISO 13485:2003 4.2.1 d)? Document Control Systems, Procedures, Forms and Templates 3
Y What shall we do on Engineering Drawing mentioned in APQP APQP and PPAP 8
B Drawing Title Blocks - Control / Number them? Engineering Drawing Practices Y14.100M Document Control Systems, Procedures, Forms and Templates 14
Marc Definition Critical Characteristic Symbol - ASME Y14.100 Standard (Engineering Drawing Practice) Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 8
Bev D Essential References for Practical Quality Engineering Misc. Quality Assurance and Business Systems Related Topics 0
Marc Engineering Technician - X-ray Imaging - Suspense 30 Nov 2020 Job Openings, Consulting and Employment Opportunities 0
Revision36 Engineering Change Order Industry Standards Other Medical Device and Orthopedic Related Topics 4
D ECO (Engineering Change Order) process questions ISO 13485:2016 - Medical Device Quality Management Systems 7
A Quality engineering positions in US - question Job Openings, Consulting and Employment Opportunities 1
D Engineering Change Order (ECO) metrics to track ISO 13485:2016 - Medical Device Quality Management Systems 6
J UCLA extension Medical Device Engineering Program Training - Internal, External, Online and Distance Learning 0
G Engineering retest in line - Machine stability issues IATF 16949 - Automotive Quality Systems Standard 8
A FDA and NB audit of Engineering Drawings in DHF and DMR. Medical Device and FDA Regulations and Standards News 1
I Good resources for learning statistics (quality engineering related) Statistical Analysis Tools, Techniques and SPC 10
B Lessons Learned Implementing ISO 50001 (Chemical Engineering Progress) Other ISO and International Standards and European Regulations 0
G Engineering Specifications - APQP APQP and PPAP 5
O Vendor vs Engineering Document Control ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
C E signatures on Engineering Change Notes AS9100 / AS9116 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
Icy Mountain Engineering Change Order...Modification Order Document Control Systems, Procedures, Forms and Templates 18
J Implementing Machine Replacement Part Reverse engineering technology Manufacturing and Related Processes 3
T Why do most companies have Quality reporting to Engineering or Operations and not to CEO? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 45
I Document templates required for ISO ISO 45001 - Engineering Construction company Occupational Health & Safety Management Standards 5
R The alignments and contradiction in Quality Engineering and management between the Automotive and Aerospace industry AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
V Thinning percentage in sheet metal forming per SES (Suzuki Engineering Standard) Manufacturing and Related Processes 1
P Usability/human factors engineering requirement (standard) for IVD medical device Other Medical Device Related Standards 2
R Creating WIs for a Heavy Civil Engineering Services company Document Control Systems, Procedures, Forms and Templates 19
S Ballooned Drawings and Engineering Changes Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
J Class 1 Medical Device ECR (Engineering Change Request) Changes 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
P Tactics to work with Design Engineering on CAR Nonconformance and Corrective Action 3
D Are detailed engineering requirements Design Inputs or Design Outputs 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 14
2 First Article Requirements for Revision Changes of Engineering AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
S Engineering change order versus a design change request ISO 13485:2016 - Medical Device Quality Management Systems 1
C Applicability of ISO 9001:2015 Section 8.5 - Engineering company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
T Setting up a quality department in an Engineering Firm Quality Management System (QMS) Manuals 11
C ISO 9001 2015 Documentation for Engineering and Design ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
G ISO 9001:2015 8.3 Design and Development (in Civil Engineering) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
G FAI (First Article Inspection) Responsibility - QC or Engineering? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
Q M-282 - Engineering Standard for Tolerances - Is it ASTM, DIN? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
L Supplier Revision Confirmation of Received Engineering Documents ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
S Document Control Guidelines in Engineering Projects - Excel sheets with VBA coding Document Control Systems, Procedures, Forms and Templates 3
A Software Suggestions for Engineering Change/QMS Design and Development of Products and Processes 2
M New MHRA guidance on Human Factors - Usability Engineering IEC 62366 - Medical Device Usability Engineering 1
S Process Map for an Engineering Consulting Firm Process Maps, Process Mapping and Turtle Diagrams 6
