Engineering purchased a new Caliper - 7.6 - Initial Calibration Required?
Q
QACen
Hello - Engineering purchased a new caliper. It has the new certificate of inspection from the manufacturer but it is not necessarily calibrated. If Engineering verifies the equipment as uses the Certificate of Inspection from the manufacturer as evidence, is that acceptable? It is one of those moments where it is immediately needed and to calibrate the equipment would take 4 weeks.
Thoughts?
Thanks for your wisdom and incite!
BradM
Re: 7.6 - Initial Calibration Required?
Hello there!
In my opinion, most of the certificates of inspection are usually not worth the paper they are written on. There is no date, no traceability to the specific instrument, and usually is some general reference to a lot of instruments. Sometimes they may make 1000 of them, test three, and if they pass, they're all good! :D
Saying all that to suggest one needs to be leery about those certificates, and inspect the information on them carefully.
Performing a verification in-house is another matter. If you can verify with traceable blocks and demonstrate there is no (or insignificant error) before and after use, then (IMHO) that would satisfy in demonstrating it's confidence.
You posted this in a 13485 forum. Is this used in Medical Device arena? Would this be considered a GMP piece of equipment? If so, I would not use it if your procedures state that it is to be calibrated. Or, do you have an alternated method specified in your procedures to perform a verification like you suggest? Also, do you have a procedure for using equipment "at risk"?
insect warfare
QA=Question Authority
I tend to agree with Brad on the worth of manufacturer's certs...the manufacturer may not even be 17025 certified, or the information on the cert is not NIST-traceable. I usually look for this information right off the bat, and even if I find it, I usually err on the side of caution anyway and ensure calibration / verification is done by a more reputable organization.
I don't know the exact requirements for medical devices or for this company, but the idea of performing in-house verification appears to be a viable solution, provided all requirements were met, plus it would save you those 4 weeks lost through outsourcing. Check the applicable standard plus your internal procedures, and see if this is acceptable.
sitapaty
Why should you suspect a brand new M.T.I?.A good guarantee for accuracy is to buy from a reputed brand.As for as the auditors are concerned The certificate from manufacturer should be acceptable for a certain period.
Sitapaty
BradM
Hi there! Thanks for contributing! :bigwave:
To an extent, yes; you're correct. However, even a new piece of equipment should be initially verified prior to use to assure something hasn't changed. I have seen instruments shipped international that accumulated some error by the time I received them to use.
My experience (so... it's probably not worth a lot :D) is to perform a verification (calibration, etc.) prior to use. It is worth the confidence gained.
Sitapaty
Again, I would agree with you to an extent. If it is a legitimate certificate of calibration, I would accept for a certain period. Along with other information, it would contain standards, tolerance assessment, and a direct link to that specific instrument.
I have seen "certificates" that were useful, and certificates that were essentially useless. Useless in that they provided no confidence for that particular instrument, and to me, appeared to be more of a sales job than anything.
Q
QACen
Thank you for the comments to my question. Your answers definitely confirmed my doubts about accepting an Engineer's decision to accept the manufacturer's certification of inspection (not calibration). We are in the middle of revising our SOP to further elaborate the verification process. It lacked verbage to actually document the verification. You definitely gave me ideas and further guidance for wording.
Thanks a million! :bigwave:
You earlier mentioned having to wait several weeks for calibration, but it doesn't have to be like that. Buy a set of gage blocks and do it yourself. Even if it's just for a initial verification (which is still calibration) for new devices, the set of blocks is something that should always be on hand when calipers and micrometers are being used.
Marc Engineering Technician - Suspense 5 April 2021 Job Openings, Consulting and Employment Opportunities 0
Marc Engineering Technician - Suspense 11 February 2021 Job Openings, Consulting and Employment Opportunities 0
Bev D Essential References for Practical Quality Engineering Misc. Quality Assurance and Business Systems Related Topics 0
Revision36 Engineering Change Order Industry Standards Other Medical Device and Orthopedic Related Topics 4
D ECO (Engineering Change Order) process questions ISO 13485:2016 - Medical Device Quality Management Systems 7
D Engineering Change Order (ECO) metrics to track ISO 13485:2016 - Medical Device Quality Management Systems 6
J UCLA extension Medical Device Engineering Program Training - Internal, External, Online and Distance Learning 0
G Engineering retest in line - Machine stability issues IATF 16949 - Automotive Quality Systems Standard 8
A FDA and NB audit of Engineering Drawings in DHF and DMR. Medical Device and FDA Regulations and Standards News 1
I Good resources for learning statistics (quality engineering related) Statistical Analysis Tools, Techniques and SPC 10
B Lessons Learned Implementing ISO 50001 (Chemical Engineering Progress) Other ISO and International Standards and European Regulations 0
G Engineering Specifications - APQP APQP and PPAP 5
O Vendor vs Engineering Document Control ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
C E signatures on Engineering Change Notes AS9100 / AS9116 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
Icy Mountain Engineering Change Order...Modification Order Document Control Systems, Procedures, Forms and Templates 18
J Implementing Machine Replacement Part Reverse engineering technology Manufacturing and Related Processes 3
T Why do most companies have Quality reporting to Engineering or Operations and not to CEO? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 45
I Document templates required for ISO ISO 45001 - Engineering Construction company Occupational Health & Safety Management Standards 5
R The alignments and contradiction in Quality Engineering and management between the Automotive and Aerospace industry AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
D Engineering Drawing Review and Approval Requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
V Thinning percentage in sheet metal forming per SES (Suzuki Engineering Standard) Manufacturing and Related Processes 1
P Usability/human factors engineering requirement (standard) for IVD medical device Other Medical Device Related Standards 2
R Creating WIs for a Heavy Civil Engineering Services company Document Control Systems, Procedures, Forms and Templates 19
S Ballooned Drawings and Engineering Changes Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
J Class 1 Medical Device ECR (Engineering Change Request) Changes 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
P Tactics to work with Design Engineering on CAR Nonconformance and Corrective Action 3
D Are detailed engineering requirements Design Inputs or Design Outputs 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 14
2 First Article Requirements for Revision Changes of Engineering AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
S Engineering change order versus a design change request ISO 13485:2016 - Medical Device Quality Management Systems 1
C Applicability of ISO 9001:2015 Section 8.5 - Engineering company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
T Setting up a quality department in an Engineering Firm Quality Management System (QMS) Manuals 11
C ISO 9001 2015 Documentation for Engineering and Design ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
I Engineering Drawing = Record or Document? Document Control Systems, Procedures, Forms and Templates 8
G ISO 9001:2015 8.3 Design and Development (in Civil Engineering) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
G FAI (First Article Inspection) Responsibility - QC or Engineering? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
Q M-282 - Engineering Standard for Tolerances - Is it ASTM, DIN? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
L Supplier Revision Confirmation of Received Engineering Documents ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
S Document Control Guidelines in Engineering Projects - Excel sheets with VBA coding Document Control Systems, Procedures, Forms and Templates 3
A Software Suggestions for Engineering Change/QMS Design and Development of Products and Processes 2
M New MHRA guidance on Human Factors - Usability Engineering IEC 62366 - Medical Device Usability Engineering 1
S Process Map for an Engineering Consulting Firm Process Maps, Process Mapping and Turtle Diagrams 6
S Quality Measure for Engineering Services Misc. Quality Assurance and Business Systems Related Topics 1
G Senior Project for BS Mechanical Engineering Student Career and Occupation Discussions 4
L BSI White Paper on Human Factors/Usability Engineering IEC 62366 - Medical Device Usability Engineering 12
M More than canned audit check-sheets? Auditing the Engineering Department Process Audits and Layered Process Audits 5
A Remote Support Location Audit - Engineering prototyping and process evaluation Internal Auditing 2
M Engineering Release Process Owner Manufacturing and Related Processes 4
jkuil Cleanroom Equipment and Furniture Engineering Standards Other Medical Device Related Standards 2
N Inspection Requirements & Engineering Drawings - Measuring Shaft Dia. Inspection, Prints (Drawings), Testing, Sampling and Related Topics 16
