Entering Assemblies containing Welds into IMDS
Kimmy
Hi Everyone,
Can anyone offer me advice on how to submit an assembly into IMDS that contains steel plates welded together using a tiq welder? Not sure how to enter the weld portion of the assembly.
Thank you for any help you can provide!
Kales Veggie
People: The Vital Few
The chemical composition and the amount of the filling rod has to be added to the MDS.
There are several options. The best option is to add the filler rod material node to the component node (say one component node with a material node for the steel plate and the filler rod, for example).
Depending on how you created or received the steel plate MDS and the filler rod MDS you may have to use semi-components (2nd option) or use component nodes for the steel plate and the filler rod (least preferred option)
TPMB4
What if you do not have an MDS for the filling rod from your supplier (perhaps since they are not registered with IMDS or don't normally supply into automotive sector)?
Can you look up the material in the steel lists for example? Or do you have to get an MDS sent to you from the actual manufacturer if the supplier can't send one?
Sorry to break into this thread but it seemed a reasonable follow on question to Kales' posted answer.
Kales Veggie
IMDS standard materials include many welding rods and many manufacturers have published their catalog products.
If the material is not standard, there are two options:
- the manufacturer enters the material and either publishes it or submits it to your account (preferred)
- you enter it based on the received chemical analysis of the wire (note: IMDS requires material declaration in the "shipped" state, not the received state)
M Entering the Italian Market - Implantable Medical Device EU Medical Device Regulations 1
D OASIS and Auditor Entering Data - Where is the authority? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
S Is entering a Date against Initials a requirement? Document Control Systems, Procedures, Forms and Templates 14
M NCA-3800 Requirements and Costs - Entering the Nuclear Market Various Other Specifications, Standards, and related Requirements 15
L What are the next steps for a Medical Device entering Canada? ISO 13485:2016 - Medical Device Quality Management Systems 11
S Gage R&R Excel Format For Entering The Data - 3rd Edition needed Excel .xls Spreadsheet Templates and Tools 3
E AS9102 FAI - What makes a COTS modified? (PCB assemblies) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
E IPC/WHMA-A-620C: Requirements and Acceptance for Cable and Wire Harness Assemblies Other ISO and International Standards and European Regulations 2
K FOD (Foreign Objects and Debris) - AS9100 & Hook Assemblies AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
M Help with SCAR - Not all sub-assemblies had properly received a First Article Nonconformance and Corrective Action 2
R Accounting for Alternate Parts in AS9102 FAIs for Assemblies AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
T FAI (First Article Inspection) of Large Assemblies/Tooling after move to new building AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 12
W Contracting Sub-assemblies From Suppliers US Food and Drug Administration (FDA) 1
L Automate GR&R using Minitab on complex, multi-measurement assemblies Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 13
M Using a label bearing CE Mark on Machine Sub-Assemblies CE Marking (Conformité Européene) / CB Scheme 2
D Nadcap Certification for Printed Boards Assemblies AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
M Drilling thru sealant? Aerospace assemblies Manufacturing and Related Processes 5
M RoHS for Disposable Medical Device Assemblies RoHS, REACH, ELV, IMDS and Restricted Substances 1
S Serializing Circuit Card Assemblies (CCAs) in EPICOR Misc. Quality Assurance and Business Systems Related Topics 2
F Specification for how to measure lengths of hose assemblies Various Other Specifications, Standards, and related Requirements 1
P The use of multiple EASA FORM 1 for Multiple Assemblies EASA and JAA Aviation Standards and Requirements 2
K Implementing AS9100 Rev C - Electrical Harnesses and Cable Assemblies AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
JoCam Nadcap AC7120 (Audit Criteria for Circuit Card Assemblies) - Acceptance Criteria AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
P PPAP Requirements for Sub-Assemblies APQP and PPAP 6
S FAI (First Article Inspection) during Assembly of Sub-Assemblies Only AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
K AS9102 Form 3 for Assemblies - Verification that the Assembly is Correct AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
V HALT vs. HASS (acronyms) - Tests for PCB and Cable Assemblies Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
P Loctite as Manufacturing Material use in Medical Device Assemblies 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 12
K Using a Tape Measure for +/- 1/16" Tolerance - Large Welded Assemblies (6 to 12') Inspection, Prints (Drawings), Testing, Sampling and Related Topics 12
I Traceability Method for Assemblies in a Continuous Production Line Manufacturing and Related Processes 3
M Preventing Missed Welds on Assemblies Manufacturing and Related Processes 4
Q Traceability by Physical Marking for Cable Assemblies Manufacturing and Related Processes 3
B Revision Control of PCBs (Printed Circuit Board) and Printed Circuit Board Assemblies Manufacturing and Related Processes 6
somashekar Wavelength Shift in Emitter Assemblies - Causes Manufacturing and Related Processes 1
R Customer Audit - C.A.S.E. Standard 1-A vs. AS9110 - Aircraft Assemblies Maintenance AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
S Go/No-go Length Gauges - Length checking of beam assemblies General Measurement Device and Calibration Topics 2
R Grandfathering assemblies under FAI - Aerospace suppliers AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
G APQP (advanced product quality planning) for cable assemblies APQP and PPAP 1
N Inspection Criteria for Foreign Objects in LCD Assemblies needed Various Other Specifications, Standards, and related Requirements 2
D Torqueing assemblies Inspection, Prints (Drawings), Testing, Sampling and Related Topics 13
Z Non Conforming Material Process for Mechanical and Electrical Assemblies Nonconformance and Corrective Action 2
apestate Working with part numbers in assemblies - Is there a standard for part numbers? Document Control Systems, Procedures, Forms and Templates 6
M How Many Expected Defective Assemblies? Six Sigma 1
J Interchangeability analysis - Interchangeability between units and its assemblies Various Other Specifications, Standards, and related Requirements 1
P What is Milliohms Typical? Cable assemblies for vehicles Manufacturing and Related Processes 6
W How do I manage Suppliers of raw materials, parts and/or assemblies? Supplier Quality Assurance and other Supplier Issues 17
M 8.2.4 Monitor and Measure Question - Re: Sub-Assemblies and Level of Detail Required ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
E Clause 7.3 - Verification and validation of the sub assemblies and the final product? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
M Electrical Assembly Standards - IPC-A-610 "Acceptability for Electronic Assemblies" Various Other Specifications, Standards, and related Requirements 7
X Need help / feedback on Xbar/R charts and Cpk/Ppk applicability - Assemblies Capability, Accuracy and Stability - Processes, Machines, etc. 11
