You should evaluate the size, thermal coefficient of expansion of the material to be measured and temperature difference from the calibration environment. If this is not significant compared to the specifications, you are good to go. If it is significant, you should consider thermally compensated gages or soaking the part and gage in the controlled environment before measuring. The gages are usually more cost-effective than the soak option.
