Environmental Management Program - Reducing electric and fuel use, waste management
SuzieKSB
:nope: :nope: :nope:
Got no idea for EMP..
anybody with ideas for reducing electricity usage..fuel usage and waste management?
help please..
Wes Bucey
Prophet of Profit
Have you established a baseline for your current usage and amount of waste material produced?
Do you have any benchmarks from government, utilities, or other organizations which can tell you how your organization compares to others?
Have you talked to the executives at the utilities and suppliers of your electricity, fuel, water, to see what tips they can provide for being more efficient?
Sometimes (often) the answer is right on your own doorstep.
I have seen companies switch to different lighting for energy savings. Some lighting companies will structure the cost based on savings. Also, some have reduced their air compressor pressures. Others have installed automatic sensors that will shut off lights when no one is in the room. Although, be careful. I had a client who installed motion detectors. I was giving a test following an internal auditor class, and there wasn't enough movement, so the lights shut off even though there was a room full of people. :eek:
I
IEGeek - 2006
I am not sure how it works where you are so bear with me.
I have contacted (in the past) our local energy providers and they always seem to have incentive systems for energy reduction. PG & E has a system called "Savings by Design" where they evaluate your current facility, then recommend changes, then review your changes and give you a nice big fat check (for us in a 107,000 sq. ft facility it was $33,200) The city of Anaheim has "Incentive" which they essentially do the same thing. (for us again in a 215,000 sq ft facility we maxed out the incentive at $45,000)
For interim savings right away, switch to new fluorescent lighting, add occupancy sensors to offices, hallways and restrooms (surprising how much this saves) instruct people to turn off workstations at night, try swamp coolers vs. AC or try BigAss Fans (that is the company name, great website too)
As for tracking changes, ask your energy provider to give you the last full years Kwh used, total cost of Kwh (or have your AP person complete with a lot of research, it is on the bill) then that is your benchmark, then say you spent $790,000 on 1.2 million Kwh total, now you can set a reduction level.
This is actually pretty simple to do if you can afford to give it some time and effort.
Just some thoughts....
tarheels4 - 2007
Nice job IEGeek.
Also consider power factor. I don't know much about electricity but I think it is a measure of efficiency. Some companies monitor this with measuring devices installed by the utility. The closer to 1.0 the more efficient you are. I have been told that a power factor of 0.85 or better is good. One way to improve power factor is to add capacitors. Or to not start all of your equipment at the same time.
I
IEGeek - 2006
You can also switch to VSD motors on equipment, that saved us 13% of our total energy bill in one year. Not bad considering we had only set a benckmark of saving 10% the first year.
Totumfrog
I agree you need to know where to are at to know where you are going. Consider the same type of things you would consider in your home. High effeciency lighing (we use the T-8). Caulk around windows. Central air instead of multiple window units. Seals around doors and dock doors. Recycling aluminum cans and paper (FYI.....recycling paper saved us $17,000 per year in waste disposal costs). Regularly changing filters on heat and air units. Motion detectors on lights, toilets and wash stations. EMS is also about recycling / reclaiming oils, solvents, proper use of MSDS. Also look into having your machine oils tested instead of automatically changed every 6 months per se. That saved us over $6,000 last year in oil, disposal and downtime.
tarheels4 - 2007
For natural gas use monitoring, facilities that use gas for heating only, take heat degree day in to account when comparing use from year to year. An example of this is attached in a spread sheet.
Randy
Hey guys as an auditor that just made a recommendation against registration to ISO 14001 I wouldn't buy off on any of the targets and numbers you y'all have given. Not 1 of you provided any information on how "environmental" performance was being improved, how pollution was being prevented or how you were complying with applicable legislative requirements. You were saving money and KW hours. I have yet to see where a $ or a KW has directly impacted the environment.
Now if you can show where the reduction in KW hours relates to "x" tons of coal (or other natural resource) not being used to generate electricity, or to the reduction of "x" tons of emissions, ash and so forth, then your numbers would have real meaning.
I couldn't care less how much money you save, but I am interested in what you are doing for the environment. What you do has to reflect that.
B EMP (Environmental Management Program) for an Office Miscellaneous Environmental Standards and EMS Related Discussions 8
P A Procedure for an Environmental Management Program Miscellaneous Environmental Standards and EMS Related Discussions 8
O Environmental Management Program, sample Miscellaneous Environmental Standards and EMS Related Discussions 1
L ISO 14001 - Environmental Management Program - To govern continual improvement? ISO 14001:2015 Specific Discussions 6
D Templates for Environmental, Safety and quality Management System wanted Document Control Systems, Procedures, Forms and Templates 3
A Environmental Management System Lead Auditor Competence ISO 14001:2015 Specific Discussions 2
S Question about environmental control - Pest control management procedure ISO 13485:2016 - Medical Device Quality Management Systems 5
T Guidance - Setting up an integrated quality & environmental management system Career and Occupation Discussions 12
I Environmental - Office Recycling and Waste Management Programme and Objectives Quality Manager and Management Related Issues 2
R Quality and Environmental Management System Integration Benchmarking 11
T What are the best books on Environmental Management Systems to ISO 14001 Book, Video, Blog and Web Site Reviews and Recommendations 11
B How do you combine Quality Management and Environmental Management? Quality Management System (QMS) Manuals 3
Sidney Vianna ISO Standard for Phased Implementation of Environmental Management Systems - SME's ISO 14001:2015 Specific Discussions 2
D ISO 9001:2008 and Environmental Management System (EMS) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
somashekar Environmental and OH&S Management Continual Improvement Miscellaneous Environmental Standards and EMS Related Discussions 7
D EMS (Environmental Management System) related criteria for Design Works Miscellaneous Environmental Standards and EMS Related Discussions 3
S Environmental Management System (EMS) Employee Handbook example wanted Miscellaneous Environmental Standards and EMS Related Discussions 7
Sidney Vianna Examples of Preventive Actions in an EMS (Environmental Management System) ISO 14001:2015 Specific Discussions 16
P EMS (Environmental Management System) ISO 14001 Audit example wanted ISO 14001:2015 Specific Discussions 16
B How to increase integration between our Quality & Environmental Management Systems Miscellaneous Environmental Standards and EMS Related Discussions 8
D EKOAward - For Students of Environmental Management Training - Internal, External, Online and Distance Learning 0
A Key Differences and Similarities between Environmental and Quality Management Systems Miscellaneous Environmental Standards and EMS Related Discussions 1
N Environmental/Waste Management SOP (Standard Operating Procedure) Miscellaneous Environmental Standards and EMS Related Discussions 6
T Environmental Management System (EMS) "101" Basics Brochure to Share? Miscellaneous Environmental Standards and EMS Related Discussions 2
D How do you think of this EMS (environmental management system) scope? Miscellaneous Environmental Standards and EMS Related Discussions 7
G Examples for Process Orientation - Core Process in Environmental Management System Miscellaneous Environmental Standards and EMS Related Discussions 9
K Article about Discipline Related to Quality/Environmental Management System The Reading Room 2
A What are the steps for EMS (environmental management system) implementation? Miscellaneous Environmental Standards and EMS Related Discussions 2
E Integration of six sigma and environmental management systems Miscellaneous Environmental Standards and EMS Related Discussions 1
T Incorporating green purchasing into federal agency environmental management systems Sustainability, Green Initiatives and Ecology 2
J Merging EMS (Environmental Management System) with QMS (Quality Management System)? Miscellaneous Environmental Standards and EMS Related Discussions 9
L Environmental Management (M.Sc degree) Career advice needed: Auditor Career and Occupation Discussions 6
RoxaneB ISO 14000 EMS (Environmental Management System) Surveillance Audit Results Miscellaneous Environmental Standards and EMS Related Discussions 23
M ISO 14001 EMS (Environmental Management System) Training ISO 14001:2015 Specific Discussions 6
A ISO 14001 - 4.4.4 Environmental Management System ISO 14001:2015 Specific Discussions 2
S ISO 19011 (Quality and/or environmental management systems) has been published by ISO General Auditing Discussions 5
C MSDS & EMS (Environmental Management System) Linkage Miscellaneous Environmental Standards and EMS Related Discussions 5
Raffy Defining the Environmental Management Group - Where do I start? Miscellaneous Environmental Standards and EMS Related Discussions 3
Randy Environmental Management Representative Miscellaneous Environmental Standards and EMS Related Discussions 10
D IQA's (Institute of Quality Assurance) Unit C5 - Environmental Management Misc. Quality Assurance and Business Systems Related Topics 1
Marc Integrated Quality, Safety and Environmental System management - The Future? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
W Non Sterile Medical Device Environmental Tests Other Medical Device Related Standards 4
F Environmental Requirements E-Lab General Measurement Device and Calibration Topics 0
A Environmental Compliance obligations and risks (ISO 14001:2015 6.1.3) ISO 14001:2015 Specific Discussions 3
R Calibration lab environmental monitoring General Measurement Device and Calibration Topics 4
S Laboratory Environmental Conditions Outside of limits ISO 17025 related Discussions 4
A How to address Environmental & OHS Opportunities? ISO 14001:2015 Specific Discussions 6
T Advice needed - Environmental MS - unwritten but customer requests policy document ISO 14001:2015 Specific Discussions 5
I Environmental Policy Content - ISO 14001 Clause 5.2 ISO 14001:2015 Specific Discussions 2
dhuot1990 Issues with REES Environmental Monitoring System Manufacturing and Related Processes 1
