EO Production Batch Failure
Balachander
We have products which undergo ETO sterilization by an outside vendor. It looks like there was a power outage and it causes malfunctioning to the software which resulted in erratic readings.
Max EO concentration (715 gm/L) was more than the required limits of 480-680 gm/L. EO gas weight was also more than the acceptable limit. But calculated value for gas concentration in the cycle by reference to the pressure differential, ΔP, between the beginning and the final EO gas injection into the chamber before the onset of the exposure was within the limits.
The vendor told us this batch is acceptable due to:
  • SAL of 10-6 was verified in the half-cycle, so there can be no question regarding efficient sterilization of the load, the exposure being double that of in the half-cycle.
  • There is a slight possibility of exposure of the load to an additional amount of EO, vendor suggests added acceleration aeration of up to 24 hours.
  • The load has been in quarantine undergoing ambient aeration in the warehouse already for an additional 72 hours.
  • The biological indicator (EPCD) results show no positive growth whatsoever.
  • The positive control shows growth as expected.
Is the justification acceptable? any thoughts on this
Thanks,
Bala
planB
Bala,
per ISO 11135:2014, section 9.5.4. (f) (2), calculation of the EO gas concentration is not a valid approach for designating conformance to the specified injected EO quantity.
Excessive EO will not adversely cycle efficacy / SAL - in contrast; here, you contractor is right. However, you would have to evaluate the impact of excessive EO to your residual levels and maybe, but less likely, the functionality of your device.
Some options that might help you built the case:
  • Does you vendor have objective evidence that the extended aeration is adequate to dissipate any potential excessive EO in the product?
  • Does you validation contain evidence that the extended aeration is adequate to dissipate any potential excessive EO in the product?, e.g.
    • Have you derived a residuals dissipation curve during validation of the residuals?
    • Are you reasonable far below specified residuals limits in your validation that you could conclude in a risk assessment that a limit excursion of 5% in EO concentration together with extended aeration would not lead to non-conforming product?
    • Did you employ challenges in your validation of EO residuals that would still be worst-case to the excursion you encounter?
No matter how you decide on the batch, you may want to request your supplier to initiate his CAPA process and request him to communicate back the results of his root-cause investigation, plus related corrective and preventive actions.
HTH,
S How do you record your Nonconforming product? Batch production of staged processes Nonconformance and Corrective Action 2
S Looking for templates of Master Production Record and Master Batch record Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 3
K Production Batch Documentation based on Filling Manufacturing and Related Processes 5
N Statistical Quality Improvement Action for Small Batch Production Statistical Analysis Tools, Techniques and SPC 17
I Is Sample Retention for Batch Production a TS 16949 Requirement Records and Data - Quality, Legal and Other Evidence 4
J How to Control Production Batch Records Document Control Systems, Procedures, Forms and Templates 4
R How do I use SPC in Batch Production? Statistical Analysis Tools, Techniques and SPC 2
G Clause 8.5.1 -- Is non Identification evidence of ineffective control of production ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
D 10.2.3 Problem Solving - What to look for at a non production remote site? IATF 16949 - Automotive Quality Systems Standard 4
C Production not following AS9100 std AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
J API Q1 - 5.7.1.5 - Validation of Processes for Production and Servicing Oil and Gas Industry Standards and Regulations 4
J Non_GMP (PIC/S 010) production in a GMP area ? Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 0
P KPI Template for Daily Production Manufacturing and Related Processes 6
A Production for same product at two production sites AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
K ISO 2859-5 (single run production) control plan issues FMEA and Control Plans 2
E Do anyone have document of automotive production risk and control of risk? Lean in Manufacturing and Service Industries 1
H Pre-production units & Purchasing/Supplier/Material controls ISO 13485:2016 - Medical Device Quality Management Systems 6
T Design Transfer & use of "prototype" components in production devices. ISO 13485:2016 - Medical Device Quality Management Systems 10
T Cease Production Sample Procedure Manufacturing and Related Processes 1
S Exclusion of chapter 7.5 production for clinical investigation ISO 13485:2016 - Medical Device Quality Management Systems 1
M Quality Manager and Production Manager Advice Quality Manager and Management Related Issues 19
W Posting Non-Quality System instructions on the Production Floor Manufacturing and Related Processes 13
Z PSW approval process for production IATF 16949 - Automotive Quality Systems Standard 2
B How to satisfy clause 5.7.1.5 process validation for valve production API 6D Oil and Gas Industry Standards and Regulations 13
B Documents for production process IATF 16949 - Automotive Quality Systems Standard 8
Watchcat When to begin putting together postmarket production QMS for a mobile app? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 13
H Production Validation- CE Mark ISO 13485:2016 - Medical Device Quality Management Systems 3
S Wooden Pallets in Production Clean Room Food Safety - ISO 22000, HACCP (21 CFR 120) 5
A Production line for medical devices Other Medical Device Related Standards 1
O PPAP'ed part manufacturer has discontinued production Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 7
I Static Mixer on Solution production Mixer Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 0
A Traceability unequal lots/batches delivery production IATF 16949 - Automotive Quality Systems Standard 8
qualprod Setup time only at starting production? Lean in Manufacturing and Service Industries 5
J ISO 9001:2015 Clause 8.5.1 Control of Production and service provision - Help with Work Instruction Access ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
DuncanGibbons Pre FAI production terminology AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
C Validation of process for production and servicing 5.7.1.5 API Spec Q1, 9th Edition Oil and Gas Industry Standards and Regulations 9
O Production run inventory sell-by expiration date? APQP and PPAP 3
A ISO 9001 Internal Audits - No production right now due to furloughs Internal Auditing 5
DuncanGibbons Process flow & PFMEA for production planning and simulation activities? Process Maps, Process Mapping and Turtle Diagrams 9
D 6.1.2.3 Contingency Plan - Dispositions to restart production after an unplanned stoppage IATF 16949 - Automotive Quality Systems Standard 3
S Production Work Order Procedure 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
Techilady Ford Special Characteristics Communication and Agreement Form (SCCAF) provides production requirements? FMEA and Control Plans 4
thisby_ Post Market/Production Risk Assessment ISO 14971 - Medical Device Risk Management 0
Felony Melony Project Milestone Plan-Development to Mass Production APQP and PPAP 2
M Difference between "Production Trial Run" and "Run at Rate" IATF 16949 - Automotive Quality Systems Standard 8
M Material incoming to the production process reflected in PFMEA FMEA and Control Plans 9
C Scrapping on production floor - Setup parts 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
G Dealing with non conformity caused by Supplier Components detected in the production line IATF 16949 - Automotive Quality Systems Standard 14
T IATF Rules for sharing production space with another company IATF 16949 - Automotive Quality Systems Standard 10
qualprod Best practice to ensure inputting of data in production Lean in Manufacturing and Service Industries 19
