Equipment Qualification - IQ/OQ per ISO 13485:2016 section 7.5.6 Process validation
ECHO
I haven't spent much time working in manufacturing and I was hoping someone could help me understand a bit more about equipment qualification.
Having read a number of existing threads, I understand that per ISO 13485:2016 section 7.5.6, process validation is only required when "the resulting output cannot be or is not verified by subsequent monitoring or measurement".
1. If a MPI (Manufacturing Process Instructions) requires someone to cut a wire to length using a ruler/caliper (calibrated), does the ruler need an IQ/OQ?
My first thought is IQ would be covered by the calibration and the OQ would be required. I am thinking that the OQ will mainly be discussing rather the ruler is "appropriate" for this task. However, if the MPI later verifies the length of the wire using the same ruler, does this mean IQ/OQ can now be justified as not necessary?
2. How about fixtures that aid in the manufacturing process, like a microscope for soldering? or a clamp fixture that helps in the soldering process?
Again, I am pretty new to the regulations around manufacturing and please excuse me if these are simple questions. I am thankful for any help.
Ronen E
Problem Solver
Moderator
First, make a distinction between manufacturing (production) processes, and measurement/monitoring.
IQ, OQ, PQ, ISO 13485 s. 7.5.6 etc. apply to the former only.
Second, I recommend that you look at IQ and OQ (to the extent necessary) in a complete specific production step context, rather than in a single equipment item context. In your example, think how you will validate the soldering process, not the microscope or the clamp (they will come in as possible factors, through the soldering process risk analysis).
Tidge
Ronen E makes two excellent points. I will echo that (in the context of medical device manufacturing*) validation is for processes, not for measurement or monitoring equipment.
The methodology for using measurement equipment has to be appropriate: This is referred to as "test method validation". Only extremely rarely have I seen anyone question straightforward methodologies such as using a gradiated rule to measure linear distances, but for less obvious test methodolgies you can conform to accepted (industry) standards maintained by ASTM, etc. Equipment used in test methods needs to be calibrated and maintained. Potentially absurd examples: No one would question the use of a stopwatch to measure (appropriate intervals of) time, but if the stop watch is used to measure fluid flow, you can believe that there had better be a validated test method backing that up.
Specific to the question about a piece of manufacturing equipment that is supporting a process (such as a clamp used to assist hand-soldering): There are questions like: Is the tool always required, and if so what are the different adjustments of the tool? This would likely be worth exploring through OQ because it is variability you explicitly designed into the process. If the use of the tool is left up to the discretion of operators, then this sort of thing is probably best explored through the PQ challenging different operators and/or individual techniques.
As a one-time certified assembler of PCB and cable assemblies, I'd subject adjustable temperature soldering irons to the OQ, but simply identify the ancillary equipment allowed within the procedure and examine the variability due to trained operators and techniques to the PQ.
(*) NB: There is a slight difference in IQ/OQ/PQ terminology between pharma and medical device manufacturing process validation. All of this discussion is distinct from medical device design validation.
LUFAN
Would sub-processes of injection molding be required for process validation? Obviously, the molding itself is a no brainer, but say the DI Water system used in the manufacturing process of a stamper which ultimately is used in the molding process?
Ronen E
Problem Solver
Moderator
Not sure what exactly you refer to. By "stamper", do you mean the injection moulding tool?
There is no explicit requirement to validate the production of production equipment (other than supplier qualification). You do need to look into the resultant production equipment itself, yes (typically in IQ).
It was good to read a detailed answer. Being new to manufacturing, I also struggle with equipment validation and sub-processes like software validation and don't know what should they really check in regard to SW in equipment.
Quality engineers in my plants do some SW validation as part of FAT and SAT where they do not challenge the system and very much depends upon vendor assessment. They feel it's good enough since the output samples are already verified. It is difficult for them to see SW as a separate entity and thinks that it is integrated into HW and if we are validating a system during process validation then there is no need to do extra work.
SW validation documentation is also integrated with process validation and every change is managed through change management.
I guess, my question is more about their thought process. I have been an SW developer myself and know very well, how the coding happens and how the developer thinks so my trust is very limited. How do I explain the importance of running thorough SW validation in equipment?
Y Creating Equipment qualification protocol Qualification and Validation (including 21 CFR Part 11) 2
D ISO 13485 - Equipment validation , qualification Qualification and Validation (including 21 CFR Part 11) 6
P CMM Equipment Validation and Qualification Approach ISO 13485:2016 - Medical Device Quality Management Systems 11
M Chosing a procedure title - "Validation of equipment" or "Qualification of equipment" Document Control Systems, Procedures, Forms and Templates 8
C Equipment Qualification of a CNC Mill Center ISO 13485:2016 - Medical Device Quality Management Systems 5
W Qualification of Design Verification Equipment 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
V Is non-conformance (incident) required for any observation in equipment qualification Nonconformance and Corrective Action 5
G Determining Sample Size for Equipment Qualification Studies Qualification and Validation (including 21 CFR Part 11) 10
H Cooling Equipment Qualification for Medical Device Manufacturing EU Medical Device Regulations 3
R Risk Assessments, Packaging Qualification and Equipment Modifications Manufacturing and Related Processes 3
V At what Stage of Equipment Qualification (IQ-OQ-PQ), must we sign-off the SOP? US Food and Drug Administration (FDA) 4
C Equipment Purchase Procedure which includes Qualification of Manufacturers Other Medical Device Regulations World-Wide 6
W Mobile equipment qualification? Manufacturing and Related Processes 1
R Process Qualification, Equipment Qualification, Operator Qualification - Sequence? Manufacturing and Related Processes 10
R Equipment / Utility Qualification Flow Requirements Qualification and Validation (including 21 CFR Part 11) 4
S Details to be covered under Equipment Qualification for Pharmaceutical Products? Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 1
M Process Validation and Qualification of Legacy Equipment ISO 13485:2016 - Medical Device Quality Management Systems 10
M Process Validation/Equipment Qualification - Class 1A (Sterile) Medical Device ISO 13485:2016 - Medical Device Quality Management Systems 12
E Equipment Qualification - IQ, OQ and PQ Qualification and Validation (including 21 CFR Part 11) 2
W Strategy for determining which components from a system should be "ME EQUIPMENT" -- home healthcare environment IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
M Do i need to have equipment validation if 100% testing is completed? Qualification and Validation (including 21 CFR Part 11) 4
K Brazil (INMETRO) for Medical Electrical and IVD Equipment? Other Medical Device Regulations World-Wide 0
R Suggest modern equipment/instrument for plastic bottle inspection? Quality Tools, Improvement and Analysis 1
S Certification of equipment after move General Measurement Device and Calibration Topics 14
B Building my own measurement equipment General Measurement Device and Calibration Topics 3
J Process Capability - Determining the process capability of certain equipment Lean in Manufacturing and Service Industries 6
W Classes and Applied Part IEC60601 Electromedical Equipment IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
A PPAP Alternate Equipment IATF 16949 - Automotive Quality Systems Standard 10
Q Measurement Equipment Revocation - Looking for a Disposal Form with Risk Assessment IATF 16949 - Automotive Quality Systems Standard 10
E Comparison of Personal Protective Equipment Standards EN 14605 vs GB24539 and ISO 13982 vs GB 24539 Occupational Health & Safety Management Standards 0
E Comparison of Respiratory Protective Equipment Standards (China Standard Compare with EU standard of EN149 Occupational Health & Safety Management Standards 2
M Calibration of equipment IATF 16949 - Automotive Quality Systems Standard 4
P 7.5.10 Customer property - applies to leased/rented equipment? ISO 13485:2016 - Medical Device Quality Management Systems 10
S Class I Equipment with mobile power inverter IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
U Calculate acceptance of equipment reading after calibration General Measurement Device and Calibration Topics 2
K Ground Bond Test for Class I Medical Electrical Equipment - calibration problems IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
W Equipment Bracketing Approach US Food and Drug Administration (FDA) 0
H Still having trouble as to what equipment falls under 8.5.1.1 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
S Medical device equipment calibration Qualification and Validation (including 21 CFR Part 11) 1
J Register of the monitoring and measuring equipment AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
B Do CTQs need to be equipment specific? FMEA and Control Plans 8
M IATF 16949 SI # 10: Integrated self-calibration of measurement equipment- Needs for explanation IATF 16949 - Automotive Quality Systems Standard 2
B Risk analysis for defective measuring or measuring equipment out of calibration General Measurement Device and Calibration Topics 2
C Revalidation of Process Equipment for Equipment Transfered to New Facility. ISO 13485:2016 - Medical Device Quality Management Systems 5
V Clause 7.1.3.1 Plant, facility, and equipment planning Lean in Manufacturing and Service Industries 0
A Canadian Safety Labels for medical electrical equipment Canada Medical Device Regulations 3
lanley liao Question regarding the calibration of monitoring and measure equipment. Oil and Gas Industry Standards and Regulations 3
P Equipment URS, pFMEA and dFMEA ISO 14971 - Medical Device Risk Management 3
D Question on equipment - when to use reference only or research only stickers ISO 13485:2016 - Medical Device Quality Management Systems 5
L Gage RandR on automated equipment. IATF 16949 - Automotive Quality Systems Standard 7
