Equipment Qualification of a CNC Mill Center
caprica
Hello everyone!
I have a question regarding the equipment qualification of a CNC mill center (typically known as installation qualification and operation qualification with regard to the machine).
What is the best way to prove the machine has the accuracy to produce the parts I want?
- measurements of all axes, that show the high accuracy, that the machine is capable of, is there
or
- produce parts and show that they hold the tolerances needed (referring to the part drawing)
Is there any gold standard about which tests to use or which accuracies to hold? I would like to get a more thorough understanding of CNC manufacturing machine validation.
Your help and knowledge is appreciated!
Best regards
caprica
Ronen E
Problem Solver
Moderator
Hello Caprica and welcome to the Cove :bigwave:
You are validating a process, not the machine in general; i.e. you have to show that it works in the specific combination of the machine and the part(s) you're validating. Your measure is not "accuracy" in general but only the dimensions and characteristics that you define upfront as important in the device context. You don't need to show that the machine is "accurate" in general.
IQ is not so much about producing parts and dimensions. It is more about a proper installation. For this stage you can also rely on documentation / testing done (and supplied to you) by the CMC machine manufacturer.
OQ is about production throughout "normal" conditions. All you need to show is that the parts produced are within the required tolerances.
In PQ (about which you didn't ask) the process is challenged and its capability established. Again, this is done based on measuring / inspecting the produced parts for the characteristics deemed important.
Please refer to the attachment here for some general FDA guidance on Process Validation.
Cheers,
Ronen.
caprica
Hi!
Thanks for your replies.
I was more thinking of the equipment qualification (installation qualification and operational qualification for the equipment part). All part and therefore process-specific things come later (like operational qualification for the process and process validation).
The CNC machine must be shown to fulfil acceptance criteria (e.g. accuracy along x1 x2 y .....axes, rotational axes, spindle speed, etc).
I am somehow lacking the arguments why this cant be done in simply producing 30 parts and evaluating their characteristics according to their drawing.
The machine itself must be measured, are these arguments comprehensible and correct or can arguments be added?
- so many different parts will run on the machine, it would be too complex to derive why one part covers all need for the other parts
- if the machine is regarded as a black box with good parts coming out of the process, later on it cant be assured that a state of control is maintained if the equipment itself is not measured
- the machine axes are used only at special points, only a measurement of the whole traveling distance can make sure that it works correctly (and will later on with new or other parts being manufactured on the machine)
- in case of a repair or replacement the whole part measuring must be repeated, when the machine itself is evaluated/measured only the isolated measurement covering the repair part can be repeated
Thanks for your help!
Ronen E
Problem Solver
Moderator
In my understanding this is a wrong interpretation of what process validation is and how it is structured. I'm not familiar with "equipment qualification". The first stage in process validation is installation qualification. It's true you look at the equipment in that stage, but it is in the context of a specific process and therefore also specific parts. I'm not aware of an "equipment validation" during which a blanket coverage for the equipment - no matter what parts it produces - is achieved. I'm also not aware of an operational qualification other than that of the a specific process and parts.
Yes, this is something that would normally be looked at during installation qualification, but typically through records from the machine manufacturer and provision of evidence that your specific installation has been carried out and completed according to all instructions from the machine manufacturer; such instructions are supposed to guarantee that the machine will perform accurately within its specification. It's the machine manufacturer's responsibility to establish such specification and instructions, and ascertain that they will produce the required results (part of the machine development). Good manufacturers will either install the machine for you or escort / support / supervise whoever else is installing, and will eventually sign-off that the installation is satisfactory. They might take necessary measurements of the machine and/or reference machined part to verify. All these should become records in your IQ.
Whatever measurements are taken, at whatever stage, the analysis must be statistically rigorous and there should be justification on record why those measurements are representative of what you're trying to establish. 30 parts are sometimes statistically enough, but this should be shown in every individual context.
This is true; normally you have to validate every process (part) on the machine, unless you can justify bundling some in "families".
A state of control is proven through proper analysis of the process parameters and noises and proper design of the validation runs; and through statistical rigor. To an extent the process is always treated as a black box, because when noise is concerned the influences are never fully understood (in the physical or causal sense) and of course never controlled. Regardless, processes can and should be shown to be under control (and capable). If not, the process has to be substantially modified.
The process should be validated across the entire machining envelope that is intended to be used in production (typically, in the center and at the corners), and this should be captured in the analysis and report. You're not supposed to use the machine for a specific process/part outside the validated envelope.
If the repair is substantial, the entire validation might have to be repeated. If it's more focused, perhaps a subset of activities would suffice, backed by a strong documented justification. This is applicable for each and every validated process (part / family) running on this machine. Typically you'd be able to justify revalidating just a few processes and argue that given the nature of the repair they are representative of all current processes.
Cheers,
Ronen.
E Equipment Qualification - IQ/OQ per ISO 13485:2016 section 7.5.6 Process validation ISO 13485:2016 - Medical Device Quality Management Systems 7
D ISO 13485 - Equipment validation , qualification Qualification and Validation (including 21 CFR Part 11) 6
P CMM Equipment Validation and Qualification Approach ISO 13485:2016 - Medical Device Quality Management Systems 11
M Chosing a procedure title - "Validation of equipment" or "Qualification of equipment" Document Control Systems, Procedures, Forms and Templates 8
W Qualification of Design Verification Equipment 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
V Is non-conformance (incident) required for any observation in equipment qualification Nonconformance and Corrective Action 5
G Determining Sample Size for Equipment Qualification Studies Qualification and Validation (including 21 CFR Part 11) 10
H Cooling Equipment Qualification for Medical Device Manufacturing EU Medical Device Regulations 3
R Risk Assessments, Packaging Qualification and Equipment Modifications Manufacturing and Related Processes 3
V At what Stage of Equipment Qualification (IQ-OQ-PQ), must we sign-off the SOP? US Food and Drug Administration (FDA) 4
C Equipment Purchase Procedure which includes Qualification of Manufacturers Other Medical Device Regulations World-Wide 6
W Mobile equipment qualification? Manufacturing and Related Processes 1
R Process Qualification, Equipment Qualification, Operator Qualification - Sequence? Manufacturing and Related Processes 10
R Equipment / Utility Qualification Flow Requirements Qualification and Validation (including 21 CFR Part 11) 4
S Details to be covered under Equipment Qualification for Pharmaceutical Products? Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 1
M Process Validation and Qualification of Legacy Equipment ISO 13485:2016 - Medical Device Quality Management Systems 10
M Process Validation/Equipment Qualification - Class 1A (Sterile) Medical Device ISO 13485:2016 - Medical Device Quality Management Systems 12
E Equipment Qualification - IQ, OQ and PQ Qualification and Validation (including 21 CFR Part 11) 2
W Classes and Applied Part IEC60601 Electromedical Equipment IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
A PPAP Alternate Equipment IATF 16949 - Automotive Quality Systems Standard 10
Q Measurement Equipment Revocation - Looking for a Disposal Form with Risk Assessment IATF 16949 - Automotive Quality Systems Standard 10
E Comparison of Personal Protective Equipment Standards EN 14605 vs GB24539 and ISO 13982 vs GB 24539 Occupational Health & Safety Management Standards 0
E Comparison of Respiratory Protective Equipment Standards (China Standard Compare with EU standard of EN149 Occupational Health & Safety Management Standards 2
M Calibration of equipment IATF 16949 - Automotive Quality Systems Standard 4
P 7.5.10 Customer property - applies to leased/rented equipment? ISO 13485:2016 - Medical Device Quality Management Systems 10
S Class I Equipment with mobile power inverter IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
U Calculate acceptance of equipment reading after calibration General Measurement Device and Calibration Topics 2
K Ground Bond Test for Class I Medical Electrical Equipment - calibration problems IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
W Equipment Bracketing Approach US Food and Drug Administration (FDA) 0
H Still having trouble as to what equipment falls under 8.5.1.1 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
S Medical device equipment calibration Qualification and Validation (including 21 CFR Part 11) 1
J Register of the monitoring and measuring equipment AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
B Do CTQs need to be equipment specific? FMEA and Control Plans 8
M IATF 16949 SI # 10: Integrated self-calibration of measurement equipment- Needs for explanation IATF 16949 - Automotive Quality Systems Standard 2
B Risk analysis for defective measuring or measuring equipment out of calibration General Measurement Device and Calibration Topics 2
C Revalidation of Process Equipment for Equipment Transfered to New Facility. ISO 13485:2016 - Medical Device Quality Management Systems 5
V Clause 7.1.3.1 Plant, facility, and equipment planning Lean in Manufacturing and Service Industries 0
A Canadian Safety Labels for medical electrical equipment Canada Medical Device Regulations 3
lanley liao Question regarding the calibration of monitoring and measure equipment. Oil and Gas Industry Standards and Regulations 3
P Equipment URS, pFMEA and dFMEA ISO 14971 - Medical Device Risk Management 3
D Question on equipment - when to use reference only or research only stickers ISO 13485:2016 - Medical Device Quality Management Systems 5
L Gage RandR on automated equipment. IATF 16949 - Automotive Quality Systems Standard 7
W How long do you keep information about equipment no longer used? Document Control Systems, Procedures, Forms and Templates 2
B 4DINSPEC Inspection Equipment General Measurement Device and Calibration Topics 0
D Equipment Register and PM question ISO 13485:2016 - Medical Device Quality Management Systems 2
R Classification of USB DC operated medical equipment IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
H IEC 60601-1 ME equipment or ME system IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
D Definition of equipment for ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 1
J Confusing on Harmonic Emissions/Voltage Fluctuations/Flicker test for CISPR 11 Class A Equipment IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
C 8.5.1.1 Control of Equipment, Tools, and Software Programs - Questions about the extent of control of NC programs AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
